Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 05-14-2012, 03:38 PM   #1 (permalink)
Default Check that A-Arm!
I think I remember someone posting a similar advisory a while back, but I couldn't find it offhand. So here's another one:
Check your A-Arm for free-play as part of your pre-flight checklist!
For the last several outings, I've had some weird drifting (either forwards or backwards) from my F50 while in a hover. I blamed this on a recent servo gear replacement, and figured my swash wasn't quite level. I even checked it once and turned a few links to get it level. However, a few flights later the drift was back.
After flying it this weekend, I decided to go over the whole setup, and I found the problem: With the radio powered on I was able to rock the swash fore-aft several degrees! The reason? BOTH of the screws that clamp the A-Arm to the shaft were loose. Very loose. I removed them, cleaned them really well with alcohol, and re-applied liberal amounts of threadlock upon reinstallation.
I figure I used up quite a few Karma points avoiding disaster with this one. It is definitely something I'll wiggle more often to make sure it's still secure.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 03:57 PM   #2 (permalink)
Thanks Chris I'll check mine before my next flights.
Old 05-14-2012, 09:16 PM   #3 (permalink)
Dumb question - What is an A-Arm?
Fusion 50 - 6S, CC100, SK720, Trex 450 Pro - SK720, E-flite MCPx & MSRx, Spektrum DX8
zorax2 is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 09:24 PM   #4 (permalink)
The manual calls it the "Elevator A Arm Assembly". It's that A-shaped part and the other bit that connects to the rear of the swashplate and pivots on the rear control rod that goes through the frame.
What was loose on mine are the two M3x5mm cap screws that secure the elevator arm to the control rod. Luckily they were still tight enough that it couldn't rotate past the flat spots on the shaft, but they were loose enough to cause slop and control issues.
Chris Boultinghouse
Old 05-14-2012, 09:35 PM   #5 (permalink)
Yeah. Don't have a Fusion yet, but this is something I check weekly on my 550.
Grok is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 09:43 PM   #6 (permalink)
Thanks for the heads up. I just checked both of mine which were ok, but I'll continue to monitor them.
Compass 7HV
Compass Atom 500E
Outrage Fusion 50
AeroMattics is offline        Reply With Quote Quick reply to this message
Old 05-14-2012, 09:46 PM   #7 (permalink)
I have had to tighten them once so far--103 flights.
MQX---TREX 450 PRO FBL---TAROT 450 PRO FBL/AIRWOLF Fuse---FUSION 50 FBL--TDR---RotorMast V-22 Osprey----Mini-V--Beastx--Full V-Bar --Scorpion -- Kontronic Jive --- Pyro----DX8
FLYING IS SIMPLE---NOT HITTING THE GROUND IS HARD
airbound is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 06:48 AM   #8 (permalink)
thanks a bunch..
will check mine today
Outrage Fusion 50 FBL / Futaba 8FG / Beastx / Scorpion HK4025
sansone is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 09:57 PM   #9 (permalink)
good catch - but not just the elevator arm should be checked. On regular basis the other small screws should be checked as well.
im4711 is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 10:05 AM   #10 (permalink)
check the elevator bell crank set screws too.. they have a habit of backing out
Team Fun / Heli Canada
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 10:10 AM   #11 (permalink)
Chris, Solaris,
Thank you.
I will check both on my ship before I fly it again.
This type of information regarding preventative actions/maintenance could save a great deal of money and time.
Old 05-17-2012, 10:40 AM   #12 (permalink)
Originally Posted by Ah Clem View Post
Chris, Solaris,
Thank you.
Indeed, I consider myself very lucky to have found the issue before it came completely loose.
I've had a few questions about what exactly was loose, so here's a picture from the manual to clear up what screws were wiggly.
Chris Boultinghouse
Old 05-17-2012, 07:58 PM   #13 (permalink)
Just found mine loose today also, probably going to use red this time.
Mark
Outrage Fusion50 FBL 12s
Logo 10 6s FBL
3DMP-V50 FB nitro
spence46 is offline        Reply With Quote Quick reply to this message
Old 05-19-2012, 09:27 AM   #14 (permalink)
Here was the thread. My buddy just finished his build and the same thing happened to him too. So make it a best practice to check them before every flight.
https://www.helifreak.com/showthread.php?t=314163
I've gone to the dark side....planks. For now....
JR XP9503 at the controls!
tonyxwing is offline        Reply With Quote Quick reply to this message
Old 11-07-2014, 05:58 PM   #15 (permalink)
Does anybody know a way to tighten the screws without disassembling the half heli?
SkyIsTheLimit is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 04:10 PM   #16 (permalink)
+1
I've seen this happen repeatedly. I started putting a set screw on both sides of the elevator bell crank.
Brandon Gaither is offline        Reply With Quote Quick reply to this message
Old 01-11-2015, 08:14 AM   #17 (permalink)
Originally Posted by Brandon Gaither View Post
+1
Same here - I had a crash this summer, I found the elevator set screw loose afterwards. I can't prove if that was cause or effect; but now I have two set screws, one of each side of the elevator bell crank.
* Goblin 700C, iKON, Torq 9180/9188, Quantum 4530-500, Edge HV160, Cyclone 695
* Outrage Fusion 50, SK-540, Torq 9180/9188, Quantum 4135-530, Edge HV80, SAB 630 Blk 3D
* Align T-Rex 500E DFC, SK-540, ICE 75
* Futaba 14SG
Arcturus97 is offline        Reply With Quote Quick reply to this message
