Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 04-28-2012, 08:57 AM   #61 (permalink)
There are a couple of ports on the Total G that are used for a separate Rx setup, those are limited to 5.5V if you're using them to power the unit. The rest of the ports are good up to 10V, if you want to run more than 5.5V, you have to power it through one of them. You can also power it through the programming port, the pin closest to the other ports on the unit is neg. and the next one out is pos.
John Barta
Michigan Whirlybirds Heli Club
http://www.michiganwhirlybirds.com
j bomb is offline        Reply With Quote Quick reply to this message
Old 05-30-2012, 02:44 AM   #62 (permalink)
I have 4 Total Gs and of the 4 only one programmed as it should. The other 3 had issues that were unique to each and I sent one back to CYE to rectify the problem. I've enjoyed the Total G that works as advertised, but having spent so much time playing with the 3 others with only inconsistent performance that I can't tust them, I'm removing them all and destroying them. They are so bad, in my opinion they could hurt someone. I wish I could sell them but my conscience won't let me. The GOV and Tail side all work great, but the FC side has been inconsistent.
The instuction sheet which CY said throw away and the videos with minimal info are all well done, but do nothing to help troubleshoot the Total G.
I bought a AR7200bx and instant success. So good and easy that I bought 3 more. I have 2 N5Cs that I bought each a CY750.
I do have a RAVE ENV FBL Nitro and a Rave 3D FBL and they are incredible helis. I highly recommend them. My CYE ATG v3 are great govenors and my favorite.
It's not like a death in the family, just get another one.
ch47c is offline        Reply With Quote Quick reply to this message
Old 05-30-2012, 04:50 AM   #63 (permalink)
I recently pulled the TotalG out from my Rave 450 and replaced it with a MiniVbar. I never experienced any loss of control but I did experience some initialization problems, described in previous posts here. It wasn't the issues I discovered that made me decide to switch. It was more a case of I had got used to the flight characteristics of Vbar on my Logos and I wanted to keep a consistent feel on all my helis. I do still have a BeastX on my T-Rex 250 but that's only because Vbar doesn't fit.
Like you I am unwilling to sell my TotalG to just anyone, incase they have an accident with it. I would only sell it to someone who has quite a lot of experience with TotalG and is able to work around the initialization issue without harming themself or anyone else.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 05-31-2012, 10:45 AM   #64 (permalink)
i must say i am loving my total g...
rotor head33 is offline        Reply With Quote Quick reply to this message
Old 05-31-2012, 03:12 PM   #65 (permalink)
Ditto, on my two Total G's....
Don C
Sky Dancer is offline        Reply With Quote Quick reply to this message
Old 05-31-2012, 09:10 PM   #66 (permalink)
I am pretty new to the FBL scene and have a pair of Total Gs. I am really liking them. Rather than trash them, I will take one. Need it for a Ballistic. Nice thing is I don't live far from Bryan so I can go see Curtis if I need to.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 06-02-2012, 03:17 AM   #67 (permalink)
I have two total g's. While I had a long learning process to get the feel i wanted. I never had issues with either one. They have been replaced by vbars at this point and the reason is a long one but not due to total g problems. As a matter of fact I prefer the feel of the total g still.
I do have one extra total g if anyone is interested. the other i am keeping.
Dave Williams
Team Align
dws6 is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 04:36 PM   #68 (permalink)
I'm beginner/intermediate and so far my Total G has been very good. I would recommend it, however, the programming interface is not very intuitive.
My newest heli has a Mikado Vbar and I like that interface much better.
I'm happy with both.
mjcelli is offline        Reply With Quote Quick reply to this message
Old 06-05-2012, 10:22 PM   #69 (permalink)
The thing about the TG programming is that it seems difficult until you really understand fbl theory. I was having a hell of a time with the gyrobot style of programing, which is similar to the TG method, but had my Erica moment with the TG.
although some high end gyros have wizards, essentially, you set the gyro's defection end points first with you travel adjust settings at 100. Then you set your manual deflection end points by reducing the travels adjust. In short, gyro's compensate more precisely that humans, so they can handle excess of 11+/- at mid stick deflection... which is added, =/-, to your collective... so if you had 11d (d=deflection) at mid stick and ran 11c (c=collective), you would have 22d at max positive collective. obviously an uncontrollable setting for human fingers.
so the only real difference in programing any fbl head is that you have to set you deflection twice, once for the gyro (per your units recommended parameters) and once for your fingers as with a conventional ccpm fbl head..... all of which should be done when the gyro is in set up mode or in the case with the TG, at zero gain.
fbl furion 6, fbl gaui 200 v2, FBL Stretched Align 450 pro V2, fbl t-rex 500, fbl beater 450...and some planks.
Stuff for sale
CF_Machete is offline        Reply With Quote Quick reply to this message
Old 07-05-2012, 12:27 PM   #70 (permalink)
Unfortunately I have now developed an issue (after over 2 years) which may or may not be TG related but I'll throw it out there anyway. During initialization the swash will jump and then a few seconds later I get the "wave". Then the cyclic servos do not seem smooth in movement with very slow cyclic inputs on the ground although this is not noticeable in flight. Then inflight I have had the swash jump (all 3 servos at once) it will do this on the ground too it I push on the swash or slowly cycle the collective it will suddenly jump. Needless to say the Rave is grounded... JR8717/LiFe3000
VBCE / TDR Evo / Blackout Mods Specter 700V2 NM TRM gasser Neo / Goblin 700N YS91SR Neo / Goblin Kraken 580 Neo / Goblin Buddy Neo / Goblin Comet Neo / Logo 200 /// Plank lifer, quads, got lots...
husafreak is offline        Reply With Quote Quick reply to this message
Old 07-05-2012, 02:14 PM   #71 (permalink)
Are you initializing with some fc active? TG likes to have fc on during initialization.
Compass 6HV, TotalG, BLS251, DX7S.
Kasama Srimok, Scorpion HK-4525-520KV, TotalG, BLS251, DX7S.
...and the rest...
Corrari is offline        Reply With Quote Quick reply to this message
