Old 05-28-2015, 08:58 AM   #1 (permalink)
Default Static electricity PSA
I've been flying Logos for what must be 5-6 years now and I've never done the full static mod but I've never had any issues with static either.
This winter, I switched from Spektrum (JR x9503/DSM2) to Jeti. I also decided to build a larger version of my Logo500 UltraLight. Over the past few weeks, I've been troubleshooting my 'new' 600 that was flying erratically and had logs full of 'Sensor Data Checksum Error', 'Satellite Data Out of Sync', 'Governor Input Contains Glitches'.. etc. And there were tons of them, every few seconds. Now, the vbar I was using had been in a heli fire so I was suspect of the vbar. I contacted MikadoUSA and continued to troubleshoot. So, I swapped the sensor unit... no change. Swapped the main unit... no change. So, now I'm suspecting the ESC. Ron (MikadoUSA) strongly suggested installing the static wires. I didn't want to since I'd never had any static issues in the past but I finally decided to do it and test some more.
Previously, I had tried to duplicate the errors without actually flying by running the motor backwards but this caused no errors. Then, it occured to me that if the errors were caused by static that the belt would have to be running. So, I removed the main and tail blades and spun it up with the motor running forwards. There were tons of errors in the logs so I finally had a way to test it without flying. I installed the static wires and retested a few times. No errors.
Just last night I finally figured out what was different to cause the static issues. Turns out running the Jeti antenna wires right over the tailboom was allowing static to enter the electronics and drive the Vbar completely batty. On Spektrum, I never had any wires anywhere near the tailboom, so I think the isolation prevented any issues.
TLDR: Just install the static wires.
If you like clean wiring and don't like the Mikado wires...
Replace one of your motor plate bolts with a longer one and a M2.5 10mm long unthreaded spacer to attach the ring terminal on.
http://www.mcmaster.com/#94669a618/=xdl7cz
Ring terminals
M2.5 http://www.mouser.com/Search/Product...key651-3240069
M3.0 http://www.mouser.com/Search/Product...key651-3240070
I also made some 'grounding plates' for my Logos out of some thin stainless steel to connect the idler pulley and several of the other bolts on the tail unit.
In the pictures are the Mikado static wires simply because the ring terminals are backordered at Mouser. But in a few weeks, they'll be here and I'll make up my own custom length wires to be neat and tidy.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 05-28-2015, 10:16 AM   #2 (permalink)
Amazing what a little static will do, isn't it?
I had a different but equally frustrating problem with an old Blade 500X (I know, don't say it...).
The heli would start spooling up, then pause, then start spooling up again... Replaced the ESC, tried another FBL, and did everything short of replacing the motor itself before narrowing it down to static. I had a satellite mounted on the boom and apparently the ungrounded tail generated enough static to trip everything out and manifest in a really strange way.
I've also become a fan of continuity and used the grounding kit on my 480 when I built it.
Current favorites...
Oxy 3, Goblin 380, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc..
Inverted2112 is offline        Reply With Quote Quick reply to this message
Old 05-28-2015, 12:56 PM   #3 (permalink)
Lube your tailbelt and staticks will be gone.
A moist belt cant crate any statichs.
Logo 600SX
Warp 360
Chase 360
Exo 500
Mr.Andersen is online now        Reply With Quote Quick reply to this message
Old 05-28-2015, 01:20 PM   #4 (permalink)
What do you lube the tail with? and how often?
Please provide product links
cbrkhan is offline        Reply With Quote Quick reply to this message
Old 05-28-2015, 01:40 PM   #5 (permalink)
I've used silicone spray oil to extend the life of my belts. But, at the end of the day, having your tail well grounded is cheap insurance against your fbl unit going berserk and your heli trying to kill you.
Old 05-29-2015, 08:56 AM   #6 (permalink)
They want to destroy themselves and us regardless, why give them another opportunity.
Old 05-29-2015, 11:49 AM   #7 (permalink)
I have a 500 , bought it used , has a wire from the motor to the boom , but nothing on the back , 500 has plastic tail housing , any idea how and or where to ground this tail ?
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 05-29-2015, 12:47 PM   #8 (permalink)
Can you post a photo? I'm not sure if I've ever actually seen the plastic tail in person. Either way, I would try to connect the boom to the idler somehow.
Old 05-29-2015, 11:32 PM   #9 (permalink)
I purchased my 600 used and had the ground wire. I cut it off (esc to tail boom) but left the tail wire on. I had static hits, put it back on and gone. My 480 has no static kit and never had an issue. Seems strange why one model is ok without it. Any guesses why?
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is offline        Reply With Quote Quick reply to this message
Old 05-30-2015, 09:21 AM   #10 (permalink)
Doesn't the 480 have metal tail boom clamps in the frames? Also the frames are carbon...
Old 05-31-2015, 11:09 AM   #11 (permalink)
I have used different silicone sprays but the best so far is these.
www.terjan.no and look for "silikon super glider"
Its used for plumbing and is a bit thicker then regular silicone spray and have a bit more staying power then regular one.
Sorry but im a Norvegian and use what i find locally.
I dont lube often, just one time a year.
But i think how i lube it is as well important as i spray into the tailboom from the tailboks when everything is assembled making boght belt and boom wet inside.
Logo 600SX
Warp 360
Chase 360
Exo 500
Old 06-05-2015, 06:48 AM   #12 (permalink)
Still not sufficient. I have not seen a Heli where it was yet...install the kit BTW, nice mod!
MikadoUSA Tech Support
Laughingstill is offline        Reply With Quote Quick reply to this message
