HobbyWing ESC's HobbyWing ESC Support |
10-03-2016, 11:51 PM | #1 (permalink) |
HW 120a V4 Plus Vbar Neo Throttle Calibration Issue
After I perform the throttle calibration, I can only get the motor to start up after I hit the 50% mark with the throttle stick.
What am I overlooking? I have checked my curves and they are fine. I did not have any issues calibrating the same ESC with the SK720 on the 600L. Thanks
Trex 600L--Goblin 420--Trex 760x--Synergy 516--Synergy 516 Stretch--Synergy N7 Last edited by sawacs; 10-04-2016 at 05:01 PM.. |
10-04-2016, 04:52 AM | #2 (permalink) |
Are you in gov store/ elf gov? If so that is as expected: the motor will spool up after 40% or so. Under that range is where bailout is active (25-40%).
Goblin Black Thunder TGY 725MG, BK 7006HV, XNOVA 4525-560KV, Spirit Pro Goblin 500 Sport - KST, HW 100V3, Quantum 1200KV, Spirit Pro, Trex 450L, Spektrum DX9 |
10-04-2016, 04:59 PM | #3 (permalink) |
I have tried a few different things. I have my throttle curve set to norm and the esc in "fixed wing" mode
When I plug the power in with the throttle stick at the upper position, the get the lipo cell count beeps follow by a couple other beeps. When I move the throttle stick to the low setting, I never get confirmation that the throttle has been calibrated. When I begin moving the throttle stick forward, the motor will not start turning until I hit the 50 to 60% mark and this is in fixed wing mode on the ESC. I have tried setting the throttle travel from -100 to + 100 along with 0 to +100 with no luck. Thanks
Trex 600L--Goblin 420--Trex 760x--Synergy 516--Synergy 516 Stretch--Synergy N7 |
