Old 10-13-2008, 06:05 AM   #1 (permalink)
Default *** Testing the PROTOS CF frame and new ESC ***
Video of Dario Neuenschwander testing the new CF frame and ESC at Heli Alpine Smackdown.
Dario Neuenschwander Alpine Smackdown
Right click "save as"
Sorry for the bad quality of the video.........
Corrado
www.msheli.com
HighFreq is offline        Reply With Quote Quick reply to this message
Old 10-13-2008, 09:30 AM   #2 (permalink)
Corrado
Ciao Corrado
More info and photos please!!
uragano47812 is offline        Reply With Quote Quick reply to this message
Old 10-13-2008, 11:17 AM   #3 (permalink)
Wow, great flying by Dario, Protos is looking good!.
Eric
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRÔTOS
EricW is offline        Reply With Quote Quick reply to this message
Old 10-13-2008, 06:01 PM   #4 (permalink)
Corrado
Are these your carbon frames, or the ones that were reviewed in this forum already? Or are those yours too?
Jimmy! is offline        Reply With Quote Quick reply to this message
Old 10-13-2008, 06:11 PM   #5 (permalink)
Prototype MSH carbon frames.
Corrado
www.msheli.com
Old 10-14-2008, 12:50 AM   #6 (permalink)
Corrado will you be looking at an SE package once these CF frames and all the new grips for various blades and all new parts are available that have been improved?
Old 10-14-2008, 01:50 AM   #7 (permalink)
All improvements are in the kits now.
we are working on the mold for 10mm blade grips and will be ready in a month or so. CF Frame december/january. ESC december/january.
We will have a carbon kit in the first quarter of 2009.
Conversions kit to carbon will be available before the carbon kit.
Corrado
www.msheli.com
Old 10-14-2008, 03:15 AM   #8 (permalink)
Ok when you get Carbon kit in that has all of this together I will revisit the heli then, thanks for response.
Old 10-14-2008, 06:10 AM   #9 (permalink)
Some pics, we didn't want to show them yet but they leaked out at the last funfly we had so.......enjoy
Plastic parts are still fast prototyping so they don't have a nice finish.
All hex screws have brass inserts just like in the servo frame.
We will release CF frame kit in January.
Same weight as plastic frame (maybe 2-3 grams less).
Kit will include:
2 - CF (or G10) side Frames
1 - Plastic battery tray
1 - Plastic lower plate
1 - Plastic third beairing support
1 - All screws needed for the conversion
DO NOT KNOW PRICE YET BUT WILL BE PRICED COMPETITIVELY AS ALL OUR PRODUCTS.
Corrado
ID:	65591   Click image for larger version
ID:	65592   Click image for larger version
www.msheli.com
Old 10-14-2008, 08:17 AM   #10 (permalink)
Great video, Corrado It's just amazing how lighting fast the Protos is Kudos to the pilot too! Think I might name my (future) Protos Blitzschrauber
Old 10-14-2008, 03:10 PM   #11 (permalink)
It looks like the CF frames add a little more protection to the ESC. Is that something that was given consideration? I love the clean, low cost plastic frames but to do not like my $250.00 ESC sticking out unprotected.
Osprey is offline        Reply With Quote Quick reply to this message
Old 10-14-2008, 07:18 PM   #12 (permalink)
Corrado,
how much headspeed, cyclic pitch, collective pitch, and what size of lipo is Dario running in that video?
ktm520 is offline        Reply With Quote Quick reply to this message
Old 10-15-2008, 01:55 AM   #13 (permalink)
Headspeed 2900
+-13° collective
10° ciclic
2500 6S Desire Battery
Corrado
www.msheli.com
Old 10-16-2008, 09:47 AM   #14 (permalink)
Corrado,
I found there is a serious binding issue of mixing arm at the lowest pitch (-12 degree) with 8 degree cyclic
And now I need to inverse the ball inside out to solve the binding issue
ID:	65767   Click image for larger version
ID:	65768   Click image for larger version
ID:	65769   Click image for larger version
rscrc is offline        Reply With Quote Quick reply to this message
Old 10-16-2008, 10:28 AM   #15 (permalink)
Wow! Something doesn't look right, there. Even with +/-12 and 10 deg cyclic and link lengths set per manual with calipers, I did not have the problem your pic shows. I would recheck things... then (what I did) close the smallest links all the way together and adjust the long ones accordingly. Use a good pitch gage and be sure you are using it properly. It is important to have the swash and servo arms level at mid stick, of course, then be sure +pitch is the same as -pitch.
MSH runs 13/13 and 10 degrees without flipping the ball outward. One more thing to note: You should never need to put the stick in an extreme corner anyway--that wouldn't be good (21-23 deg) even if there is a bit of binding! I do have a slight bit of binding, but not as bad as your pic seems to show. Maybe you have more pitch than you think?
What a great hobby...even better, its people! Be blessed, friends.
Caleb White is offline        Reply With Quote Quick reply to this message
Old 10-16-2008, 11:23 AM   #16 (permalink)
Are you also pushing down the swashplate to -12 degree and at the same time push elev. to 10degree? Is the flybar free to move?
Old 10-16-2008, 04:02 PM   #17 (permalink)
Im binding too, but I too dont think you will ever need that swash attitude.
Wesp
wespen is offline        Reply With Quote Quick reply to this message
Old 10-17-2008, 11:43 PM   #18 (permalink)
If you move the flybar that parallel to the swashplate at -12degree collective and 8degree elev., you will find the binding I mentioned above
Old 10-25-2008, 05:32 PM   #19 (permalink)
I never see my flybar get to that position in flight.
-J
T-Rex 600 - 12s - 4025-630kv - 14T - 6965HB - 770-3D - S9254
Protos - 6s - MSH - 14T pinion - DS3405MG - HG-5000 - HSG-5083
T-Rex 450 - 3s - 430L - 13T pinion - 65MG - LT2100T - JR3500G
www.helichaos.com under construction?
http://www.youtube.com/profile?user=grizzlyadams72
jgoodwin is offline        Reply With Quote Quick reply to this message
Old 10-25-2008, 05:42 PM   #20 (permalink)
It never will...
Therefore It's not a problem imho.
