YGE YGE ESC Support and Discussion |
01-23-2012, 06:27 AM | #1 (permalink) |
How to load the current YGE HV ESC settings into the Progcard II:
Hello!
Just wonder if it is possible, and how do you do it? Its no problem on my 60 A LV on my protos, but i cant get it too work on my 90 HV. I have read and read and read this (http://elektrorc.com/article_info.php?articles_id=5) artickel - but stil i cant understand! Please help :-) Jørn |
01-23-2012, 10:36 PM | #2 (permalink) |
90 HV with two servo wires... one short (to go to prog card) one long (to go to receiver.
Prog Card has two servo-type connectors (right and left) 1. Disconnect all power* 2. Connect ESC short servo wire to "left" prog card connector 3. ESC to the Rx as for normal flight 4. Connect Servo wire from Rx (any channel to get power) to "right" Prog Card connector* 5. Power up ESC (motor disengaged from the main gear- leave it all hooked up to get the beeps) 6. Power up Rx (with 5V power source), which will power up the prog card... 7. Program...(dis, dat and the udder ting...)7.5. Cycle the power and review all settings To use the programming card you must FIRST power the ESC, then power the prog Card &RX...if you dont the programming card will not show the current ESC settings! The programming Card needs a separate 5v input for HV ESC's...(non-bec) ..you must plug your prog-cable (short cable on ESC) to the prog card and then plug your RX with a 5v power source into the RX..
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum Last edited by dpelletier; 01-31-2012 at 10:23 AM.. Reason: corrections |
01-29-2012, 09:39 AM | #3 (permalink) |
Which way up are you looking at the ProgCard when you say connect the programming lead to the right connector on it?
My card has connectors at the bottom and the left one has esc written under it, the right has Rx. Other instructions I have seen say connect the, unhelpfully, short programming lead on the ESC to the left connector on the card. The instructions are not clear about whether the ESC throttle lead must be disconnected - it would seem odd since it is not used for programming but must be connected somehow to enable throttle end point programming (aka Stop and Full Speed on Prog Card II). Cheers, Nigel. Sent from my GT-I9100 using Tapatalk |
01-29-2012, 09:42 PM | #4 (permalink) |
I just finished doing mine...
Instructions I had were all wrong. Here is what worked: Everything is powered off. ESC short lead goes to the left side prog card connection ESC long lead goes to the RX (throttle output) Use another servo wire to go from any other port on the Rx to the right plug on the prog card... this one is only to supply power to the prog card (5volts only). disengage the motor from the main gear Power up the ESC Power up the Rx, which in turn powers up the Prog card. ESC being powered first is what allows the prog card to get the current ESC settings when the prog card is powered up.
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum |
01-30-2012, 07:54 AM | #5 (permalink) |
When you power up the rx do you have your TX powered up and do you have throttle high or low?
Thanks, Nigel. Sent from my GT-I9100 using Tapatalk |
01-30-2012, 08:51 AM | #6 (permalink) |
There's also this method from the directions:
On startup of the progcard, one LED on the left edge of the ProgCard II will light indicating menu option. If no top lights are not lit indicating current value of setting, hold down Select button. This will load the current values from the ESC to the ProgCard II.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep. |
01-30-2012, 09:29 AM | #7 (permalink) | |
I always start the Tx with F-Mode switch to Idle 2(100%) selected and T-Hold on (0%) Then program STOP T-Hold is already on (T-Hold 0% for the STOP) and flip T-Hold off goes to IDLE 2 (100% for the FULL SPEED)
01-30-2012, 09:30 AM | #8 (permalink) | |
Which of the two left buttons is the Select you are talking about? The Top Left, or Bottom Left?
01-30-2012, 09:58 AM | #9 (permalink) |
I believe it is the top left. You will see the LEDs march or go through some sort of blinking if I remember correctly.
01-30-2012, 10:18 AM | #10 (permalink) |
I believe it is the Enter button. It makes my leds flash across and down.
So you start the rx with throttle low, I'll give that a try asking with the latest instructions above. With everything I have tried so far I either get no flashing lines of leds, or flashing but no retrieved settings being displayed so I cannot verify the ESC is setup how I wanted. Thanks, Nigel. Sent from my GT-I9100 using Tapatalk |
01-30-2012, 11:15 AM | #11 (permalink) |
Today I Put the ESC programming cable in the left connector, powered up the ESC and in the same second I connected the RX to the left connector the chip on the programming card blew up.
Dont mess the connections up.. BTW The ESC along with the rest seems to have the survived. I Will buy a new programming card tomorrow. I think im getting old and beginning to lose it. |
01-30-2012, 04:49 PM | #12 (permalink) |
Sorry to read that pxpep, did you connect the program cable in the Rx port and power in the esc port?
This evening I tried dpelletier's instructions:
I also tried pressing and holding each button at various points after power up but today it would not re-read the ESC - or at least do the linear flashing of the leds. Even when it did do the linear flash of the row and column of leds the Prog Card showed no led lit for any of the settings on either page 1 or 2. I'm beginning to wonder if either the ESC or ProgCard is faulty. Thanks, Nigel. |
02-01-2012, 12:42 PM | #14 (permalink) |
Are you sure that you should have the ESC lead plugged into the throttle port at all? The 120HV programming sequence says that lead should be removed from the receiver during programming.
02-01-2012, 01:03 PM | #15 (permalink) | |
But I just leave it plugged in anyway.
02-01-2012, 02:16 PM | #16 (permalink) |
I have tried esc throttle lead disconnected with lead from throttle channel to ProgCard and, separately, with lead from other channel to Progcard, and esc throttle lead connected with lead from other channel to ProgCard. All seem to work the same. No display of existing settings, but Esc seems to confirm entered settings with beeps a long as throttle is high at ProgCard power up.
02-26-2012, 06:47 PM | #17 (permalink) |
After returning the ESC and ProgCard II to YGE and it being returned to me with no fault found but with an improved HV instruction sheet for the Prog Card, I did more experimentation which again did not work. While messing around trying different things the Prog Card II suddenly started to load settings from the ESC. I had accidentally reversed the rx patch lead (from the throttle channel on the rx) on the rx port of the Prog Card II, so that the orange wire of the patch lead was plugged into the pin marked brown on the Prog Card II). The Prog Card II now powered up with the rx (as it had before also) and then after connecting the main batteries and hearing the ESC beeps from the motor I pressed the Enter button and the Prog Card loaded the settings from the ESC.
I'm not suggesting anyone else does this as it is contrary to all the instructions I have seen and contrary to what is printed on the Prog Card II itself, but for me it appears to make the Prog Card II work where before it did not. I must say a big thanks to Heino Jung at YGE who has been very patient and helpful trying to understand why I am having problems. Cheers, Nigel. |
02-26-2012, 11:40 PM | #18 (permalink) |
Program sheet
Nigel
Could you post the "improved" program sheet?
Goblin Kraken Pyro 850-40 14s, NEO, Xpert R2 Kosmik Cool 160 Goblin 700 KSE 4525-520, NEO, Xpert R2, Kosmik 160 Goblin 570 XNova 4025-860, NEO, Savox 1257, BL9288, Jive Pro 120 Goblin 380 KSE Xnova 3215-930, NEO, DS-3001HV, DS5005HV, Koby 90
02-29-2012, 04:45 PM | #19 (permalink) |
Scanned this in so may not be perfect.
YGE ProgCARD II - Programming Card Quick guide Opto controller V4 Programming: - Pull out the long controller cable from the receiver. - Pull the jumper from short controller cabel. ~ Connect the short controller cable to the left ProgCard connector (ESC) with the orange wire to the left. - Connect the patch wire to the right hand connector (Rx) of Programming Card, with orange to the (eft. - Connect the other end of the patch wire to the receiver throttle channel. (With Futaba activate analog servo output.) - Turn on the transmitter. (With Futaba activate Servo reverse on throttle channel.) - Turn on the receiver with 4 cell NiCd or BEC with maximum 6.5V because the programming card is only for max. 6.5V. - Connect the main battery. - Press Enter Bottom on the Programming Card. - Controller is read out and can be programmed afterwards. - After programming remove the main battery, programming card and patch wire. - Connect the jumper with short controller cable. Running: - Plug in the long J/R wire of the controller on the throttle channel of the receiver. - Turn on the transmitter. - Turn on the receiver with 4...6 cell NiCd, 2s LiFe, 2s Lipo or BEC with maximum 9V . - Connect the main battery. Hope this helps, Nigel. Sent from my GT-I9100 using Tapatalk |
