Old 02-14-2013, 08:26 PM   #1 (permalink)
Default 550e 3G uneven servo throw
For some reason my ail. Servo throws farther than the pitch servo all the settings in the transmitter are equal. Could this be caused by the 3G settings?
JWILL is offline        Reply With Quote Quick reply to this message
Old 02-15-2013, 05:21 PM   #2 (permalink)
Default Maiden attempt 550 3g
Well I attempted to maiden my 550 well I find that I am having to make both cyclic and rudder corrections to keep it level well I almost got it off the ground and it tilted forward and the blades scraped the asphalt nothing broke but bottom edges did get sanded a bit. I wish I knew an experienced heli pilot in Augusta Ga right now not sure if there is an issue with me or the heli.
Old 02-15-2013, 10:15 PM   #3 (permalink)
Default 550 3g tail issues
Well I tried to maiden this bird and as soon as I begin to start applying elevator the tail begins to rotate I havent even lifted it off the ground yet. And tips would be helpful. Oh I went through and set up the gyro also when I hold the heli and rotate it, it does adjust pitch.
Old 02-16-2013, 04:01 AM   #4 (permalink)
I found it best to level swash at mid along with low and high pitch in the radio just like you would with a flybar set up before calibrating if I remeber right.
Northern California RC Unlimited RC Flyers.
www.ashcreekrcflyers.com
Turttle is offline        Reply With Quote Quick reply to this message
Old 02-16-2013, 05:31 AM   #5 (permalink)
Sounds as though your gyro is reversed or perhaps normal and needs to be reversed.
Tail slider should move the opposite way to where you push the tail when doing your preflight.
Hope this helps
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 02-16-2013, 07:07 AM   #6 (permalink)
Use the Helifreak locator or repost with title "Help in Agusta, GA". Or you can try posting in the 3GX forum as well. Or check your local hobby shop.
Sorry not more help., but I'm not too familiar with the 3GX.
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC
Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote Quick reply to this message
Old 02-16-2013, 09:12 AM   #7 (permalink)
Your swash level in DIR mode same with tail? If yes, turn your gains up slightly...
align flybarless also sensitive to vibrations, skidding on the ground, skid bumps, taking off on a hard surface etc...
razeyoshi is offline        Reply With Quote Quick reply to this message
Old 02-16-2013, 09:27 AM   #8 (permalink)
Ahh the woes of the 3g/3gx,if you don't want to fight it get a better unit like beast x or the brain. New blades and a canopy will cost about the same and all around you will have a better flying heli. My 2 cents. Good luck.
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 02-16-2013, 02:10 PM   #9 (permalink)
Well I will try turning up the gains. I guess its a good thing I happened to buy an Ar7200bx in the sale forum last night.
Old 02-16-2013, 09:50 PM   #10 (permalink)
let us know how it goes and double check and make sure your gyro is correcting in the correct direction on cyclic and tail
Old 02-16-2013, 10:12 PM   #11 (permalink)
You will like the 7200 bx update to latest firmware 3.0
Old 02-17-2013, 01:46 PM   #12 (permalink)
Ok I noticed when tilting the heli the swash plate barely moves and is slow also it moves reverse but when I use the cyclic in the transmitter it moves correctly. So it seems the issue is with the gyro? Any ideas?
Old 02-17-2013, 02:15 PM   #13 (permalink)
When you tilt the heli foward, the swash should move back. When you tilt the heli to the right the swash should move left. If the swash is barely moving turn up your gain. Check out Bert kamerers align 3G video, it should get you on the right track...
Old 03-03-2013, 07:41 AM   #14 (permalink)
No, the 3gx is fine. Very minimal movement when checking compensation is correct, especially with V3.0 firmware. Like others have said 'just as long as the swash is compensating opposite to which way you're tilting the Heli.'
Old 03-12-2013, 01:09 PM   #15 (permalink)
Your AFR's for Ail and Ele should also be equal. I run futaba and have 50, 50 in the swash menue. Like every one else said already, Make sure you run the setup at mid stick, 0 pitch, level swash, and 100% throw with no expo. Then after you can add expo. Make sure your linkage is proper. I usually have to run the DIR setup up to 3 times, releveling the swash after each time because it can change. After the 3rd time the swash usually stays level from then on.
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Rotormast V-22, Futaba 12Z controle!!
Stevendavis is offline        Reply With Quote Quick reply to this message
