Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 02-24-2007, 12:26 PM   #1 (permalink)
Default New Readyheli.com Lepton Tail Servo Mount - Full-Size!
Guys:
We just finished up the prototype mount for our proof of concept 9254 tail servo mount for the Lepton kit....now you can mount a full-size digital servo within the frame, get the speed you need and not affect CG at all! No more goofy full-size servos hanging out of the side of the frames...
Kit will include:
Delrin Tail Servo Mount
Carbon Fiber Tail Pushrod
Threaded rods for ball links
Price TBD. We are going to start production, so if you are interested, let us know.
Thanks for looking.
John
readyheli is offline        Reply With Quote Quick reply to this message
Old 02-24-2007, 03:15 PM   #2 (permalink)
I've got a silly question. What if I want to take the servo arm off? Do I need to drill an access hole in the tail boom to do that? I'm not sure I see the point.
TM
TMoore is offline        Reply With Quote Quick reply to this message
Old 02-24-2007, 03:23 PM   #3 (permalink)
you unscrew it from above the boom block...its easy. the point? running a full-size digital protected inside the frame that doesnt affect the helis CG by running it on the boom or outside the frame.
im sorry if i didnt make that clear in my first post.
Old 02-24-2007, 07:19 PM   #4 (permalink)
How long and arm can you run and how close to the boom center is it?
TM
Old 02-24-2007, 08:44 PM   #5 (permalink)
Good question.
ckoelliker is offline        Reply With Quote Quick reply to this message
Old 02-24-2007, 09:22 PM   #6 (permalink)
we are using a full size circle, with the sides slightly trimmed...looking at your own frames you should be able to gauge the size disc...why would you want to run an arm-style horn on your tail?
as for how far is it from the boom center, it is intentionally designed to hold the servo disc ball link offset so the carbon tail pushrod is perfectly 90 degrees to the tail rotor linkage.
Old 02-24-2007, 11:44 PM   #7 (permalink)
Why would I want to run a disk? On the Lepton I use the 6 sided servo horn with the ball all the way out on the arm. This works perfectly with either a 611 Futaba gyro or a CSM 720 using the 9251/56 servo.
I guess I can assume that you aren't using the 2mm pushrod either?
TM
Old 02-24-2007, 11:58 PM   #8 (permalink)
no, im using a custom cf rod. it will be threaded and included with the mount.
Old 02-25-2007, 09:33 PM   #9 (permalink)
guys put a few updated pics up...hopefully they paint a better picture.
Old 02-26-2007, 03:14 AM   #10 (permalink)
looks sweet, as said above - few difficult issues with changes, but assume it won't happen very often, anyway I assume you would need to sell new push-rod clamps also (i.e. the ones including the tail-fin holder or separate ones), because of the fat carbon rod, or is there anyhow a possibility to still use the stock one ?
xircom is offline        Reply With Quote Quick reply to this message
Old 02-26-2007, 12:09 PM   #11 (permalink)
John put me down for one. I like the fact that I won't have that full size servo popping out the side of the frame. Great work!! Keep the upgrades coming.
Alvin
eheliflyer is offline        Reply With Quote Quick reply to this message
Old 02-28-2007, 05:54 PM   #12 (permalink)
You can put me down for one also.
Best Regards
Furron
MKS USA, Pulse Ultra, Canomod
wicked_n_raw is offline        Reply With Quote Quick reply to this message
Old 02-28-2007, 08:16 PM   #13 (permalink)
I'd take one.
clever is offline        Reply With Quote Quick reply to this message
Old 02-28-2007, 08:57 PM   #14 (permalink)
Default Re: New Readyheli.com Lepton Tail Servo Mount - Full-Size!
Count me in too!
BTW - I sent the fiberglass canopy I bought from you to Dave Yost for a custom paint job, essentially the Szabo Avant scheme reworked for the Lepton -- should be pretty cool (until it kisses the ground ). I spoke to Dave a few weeks back and he thought I might see canopy art before Spring :wink. I will let you know how it turns out (let me know if you would like pics once I receive.)
Tim
CuriousOne is offline        Reply With Quote Quick reply to this message
Old 03-02-2007, 08:45 AM   #15 (permalink)
guys, added a zip file of a 3D rendering (thanks nova) of the mount for you guys to see how it fits in the frame...we are just waiting on the rods and we should have these up on the site soon...
Old 03-03-2007, 08:11 AM   #16 (permalink)
how much will it be ?
Old 03-04-2007, 06:08 PM   #17 (permalink)
under $30 with carbon fiber tail pushrod pre-threaded...
Old 03-04-2007, 06:41 PM   #18 (permalink)
Where is the zip file?
Old 03-04-2007, 07:10 PM   #19 (permalink)
See bottom of first post
Old 03-05-2007, 09:55 PM   #20 (permalink)
John,
Will this also fit the logictech 6100 servo? While the case is the same size as the 9256, the ears make it a little longer. It's a killer gyro for the Lepton.
Tom
Give me ambiguity or give me something else
tday is offline        Reply With Quote Quick reply to this message
