Futaba Radios and Electronics Futaba Radios, Gyros, Servos, Etc. |
12-04-2014, 08:20 PM | #1 (permalink) |
14sg with real flight
Anyone know how to use the14sg on real flight? I plug cord from interlink into 14 and it doesn't turn on so I turned on. Won't read. Any ideas? Thanks.
Sent from my iPhone using Tapatalk |
12-04-2014, 10:15 PM | #2 (permalink) |
Which version of real flight
With my pilot skills I have no choice but to become a good mechanic. |
12-05-2014, 05:49 AM | #3 (permalink) |
7.5
12-05-2014, 06:28 AM | #4 (permalink) |
I will try and post my file this evening then just go through the channels on the real flight software. I will put them up later today
12-05-2014, 06:46 AM | #5 (permalink) |
Real flight doesn't even see the radio under select controller. That's what I'm having trouble w. After that I can prob figure it out. Can't b as hard as programming radio. Lol
12-05-2014, 08:04 AM | #6 (permalink) |
You have to set up a model for RF in your transmitter and have it selected when you plug in the interlink and turn the radio on. Real flight will not start if it does not see the radio it will give a message like no valid interlink, if that is the case make sure the transmitter is on before plugging in the USB. If real flight comes up then it sees the radio and you have to go into to file menu to set up the futaba controller make sure the channels are correct. I had to change some settings but do not remember what they were I will look when I get home.
12-05-2014, 08:50 AM | #7 (permalink) |
It only sees interlink controller. I did model. Not sure what's going on. I'll try again later.
12-05-2014, 12:54 PM | #8 (permalink) |
Here is a shot of my channel mapping and you have to calibrate the controller also I will try and find my cable for the interlink to see but it is set as a pass through. I have the interface link now which works differently so what I said about it not running without seeing the radio is not true since it does see the interlink radio.
