Old 03-27-2012, 09:57 AM   #1 (permalink)
Default 120hv. Align
Hi folks should I use ksa mode with 700m and 700mx motor.
Sent from my iPhone using Internet.
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
rapidgaz is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 10:21 AM   #2 (permalink)
Yes, better do that.
If you are lucky with the MX motors you might get away without but it's rather a longshot, I suggest running KSA mode.
http://heli.dacsa.net
Old 03-27-2012, 03:48 PM   #3 (permalink)
Is this the same for the mx on the 550e.
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
Old 03-28-2012, 02:05 AM   #4 (permalink)
trial and error, some works fine others not, seems to be a magnet spacing issue, jive dislikes motors that are not perfect. If you can auto try non ksa first as it's preferable, if in doubt follow mr mels advice and run ksa
Stolla is offline        Reply With Quote Quick reply to this message
Old 03-28-2012, 02:43 AM   #5 (permalink)
Cheers guys, will try without first, is there chance it could do any damage to esc or motor.
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
Old 03-28-2012, 04:07 AM   #6 (permalink)
Just for reference over 200 flights with KSA mode on 700MX 530kv in my 700E, no issues. Don't be afraid of KSA
ChrisH is offline        Reply With Quote Quick reply to this message
Old 03-28-2012, 04:30 AM   #7 (permalink)
Shouldnt damage esc or motor, on thick single wire d winds yes can damage esc, better to run ksa from start. If in doubt run ksa, some motors dont like ksa, they perform a lot better non ksa others not so sensitive so again trial and error sorry!
Old 03-30-2012, 03:08 PM   #8 (permalink)
Right folks, just set up my kony, tried normal mode 4 on bench no issues in starting or weirdness, also tried ksa mode same thing no issues but only bench test with no mains just tails. Should I just run ksa or normal. Motor still 700m. Would I expect to see probs on bench or not. Will ksa mode give me less power.
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
Old 03-30-2012, 03:16 PM   #9 (permalink)
Use ksa mode, you wont see it on the bench.
Yes a little less power, but its like complaining about Heavy weight of a bulletproof west, 'it does not matter if you get shot, its worth it'
Same with ksa, whats that tiny extra power worth if you crash from a shutdown?
Old 03-30-2012, 03:18 PM   #10 (permalink)
Ok will see how I go with ksa. Cheers mr mell.
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
