Old 03-28-2015, 08:28 PM   #1 (permalink)
Default Wicked Tail (?) Vibration Sk-720 Trex 600 DFC
Good Evening,
I am getting a wicked tail vibration in my trex 600 DFC. It is hard to tell if it is up or down or side to side but I can hear it at speed. The vibration analyzer shows it off the charts. There seems to be something right around 200 Hz and 400 Hz. Is this the tail and the torque tube? Log 24 is with tail blades on, Log 27 is without. Any thoughts on what might be causing this? Tail blades balanced, grips seem fine.
Thanks. I know folks don't have a lot of time to be looking at vibration logs-- I guess I have been lucky not to have many bad vibes for the 4-5 years I have been in the hobby.
jamisonchang is offline        Reply With Quote Quick reply to this message
Old 03-28-2015, 09:03 PM   #2 (permalink)
are you using the gov.?
mrultralite is offline        Reply With Quote Quick reply to this message
Old 03-29-2015, 06:18 AM   #3 (permalink)
No. Mostly flat throttle curve. Thanks
Old 03-29-2015, 08:03 AM   #4 (permalink)
Originally Posted by jamisonchang View Post
Good Evening,
That is a wicked tail vibe! Classic fore/aft and up/down pattern, so its classic unbalance situation. Further proof is that it goes completely away when you remove the tail blades.
Either ditch those blades and try for some others, or you can spend some time doing a full static and dynamic balance on them, and even do a balance of the entire hub with blades attached while off the heli. Also, where is your FBL unit mounted? The spot right on top of the tail gear box at the frame will pick up a lot of vibes. I always had much better luck on my Align helis mounted down inside the frame on the lower skid mount.
The other vibe is your motor. Pretty much all side to side indicating a slightly out of balance can, but focus on the getting the tail sorted first, and then we can recheck and go from there on the other parts if needed.
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
Old 03-29-2015, 08:26 AM   #5 (permalink)
Wow, thanks so much for your help. I really appreciate your time.
I tried two different sets of plastic blades and the same thing. The gyro is mounted on the front mounting area by the motor. Should I use CF tail blades? I'll take the hub off first and try to balance it. Many,many thanks
Old 03-29-2015, 08:36 AM   #6 (permalink)
Hard to say on the blade material......plastic can sometimes flex and vibe more than CF, yet the plastic blades were better on my 500 than CF.
It comes down to weight, and the lighter blades will vibe less. Large heli plastic blades can be very heavy compared to CF, and can vibe more. I had a set of plastic 700 size KBDD blades that were heavy and had high vibes
Tony
Old 03-29-2015, 01:07 PM   #7 (permalink)
Default Hmmm
I believe the tail rotor hub was mostly balanced when I put it on the Dubro. Still vibrating like mad.
Any thoughts?
Old 03-29-2015, 01:13 PM   #8 (permalink)
Any thoughts?
Do you have any other blades to try? No slop in the grips or anything?
Make sure the CG of the blades is also good, and not just a static balance. Static will balance fine using the teeter test, but different CGs can vibrate like crazy dynamically once spun up. Weigh each blade on a gram scale and make sure they are not way off from each other
http://www.skookumrobotics.com/wiki/...lance_the_Tail
Tony
Old 03-29-2015, 03:03 PM   #9 (permalink)
Any thoughts?
Are your blades on backwards or have you modified your tail rotor to be trailing edge controlled?
HELIDIRECT - HOBBYWING - XNOVA - XPERT - PULSE - ROTOR TECH
Colin Broughton is offline        Reply With Quote Quick reply to this message
Old 03-29-2015, 03:45 PM   #10 (permalink)
Default Thanks
Thanks X-rayted.
No, I just had the grips on my apparatus and threw the blades back on incorrectly -- they are still leading edge control on the machine.
Appreciate all the help
Old 03-29-2015, 06:47 PM   #11 (permalink)
Default Different Tail grips
Found some old plastic tail grips from my 600 N and swapped out for the metal ones that I used in the previous tests.
Tail vibration a lot better, right?
Still very pronounced vibration at 400Hz-- motor or torque tube?
Feedback appreciated.
Old 03-29-2015, 07:32 PM   #12 (permalink)
Much better, so its the blades just as we suspected!
That is your motor with an out of balance can. There are several vids around showing how to balance the can on your own using tape or similar, and member A VIKING balanced his using dots of epoxy on the outer can. Let me guess.......this is an Align motor We see out of balance issue a lot with them for some reason.
Just do a search on balancing brushless motors if you want to tackle it on your own, or you can choose to fly the heli as is and see what your overall vibe score will be. Its not going to be all that bad really, even with that motor spike.
Tony
Old 03-29-2015, 07:42 PM   #13 (permalink)
Xrayted, thanks again!!
I actually changed the grips out and kept the same blades-- so, instead of the metal align grips that I had this morning ( with the high vibes), I had an old set of plastic tail grips from by 600N. So, this leads to me believe that the align metal grips are the problem? I really don't see much play in the metal grips so I am not sure what is going on...
I was going to buy a new set of tail grips (metal).
Thanks for the tips on the motor... yep, Align 600 MX. Probably will put a KDE motor in now.
Old 03-29-2015, 07:44 PM   #14 (permalink)
Very interesting.....at least its solved one way or the other. I would have expected to see a vibe spike on the no blades run you already posted originally if the grips were the culprit, but I've learned that anything is possible.
Tony
Old 03-29-2015, 08:05 PM   #15 (permalink)
Thanks again Xrayted. Yea, that makes sense about the vibe spike.
If you have any other thoughts about what might be going on, feel free to share but I won't keep harassing you : )
Old 03-30-2015, 07:08 AM   #16 (permalink)
No worries at all
Tony
Old 03-30-2015, 10:41 AM   #17 (permalink)
...and yes I did balance my motor can with small dots of epoxy. That was a year ago and I am proud to report the epoxy is still holding on after hundreds of flights...although a little dizzy turning at nearly 20,000 RPM.
It was interesting in that during my recent first bearing change on the Quantum, the epoxy drops that I placed on the exterior of the can were in the exact same location as the putty installed on the inside of the can by the factory for balance, they just came up short by just that little bit.
See the photo: I didn't know if the epoxy would stick for very long on the painted surface of the Quantum so I sanded the paint off for one epoxy dot as an experiment. Didn't matter, the epoxy stuck equally as good on the paint as it did on the bare metal.
Vibes are still low.
I won't go through how it was done but if anyone would like to know how I did it, post a note and I will elaborate.
I don't know if this process would work good on the ribbed cans as I don't own any of those.
Velos Rotors<<SAB<<Compas<<Align<<Walkera <<Propel
A VIKING is offline        Reply With Quote Quick reply to this message
Old 03-30-2015, 11:02 AM   #18 (permalink)
Thanks A Viking. You are much better man than me--- I have a KDE motor waiting to be put in my 600
Old 03-30-2015, 12:29 PM   #19 (permalink)
...not a function of being better than, just a function of sharing ideas and discoveries. I bet you know plenty that I haven't even thought about with these ships.
I believe you'll enjoy the KDE. I have heard no bad comments only good from those who have them.
Old 03-30-2015, 12:40 PM   #20 (permalink)
Fair enough. Thanks for taking the time to respond. I am interested in how you did this-- if you have it written down, please pm me. Happy flying
