Old 10-02-2013, 04:10 PM   #41 (permalink)
What head speeds (max and min) are pilots using on this heli ??
Garry
Logo 600SE/Uvular Electric with Microbeast
Rave Ballistic Electric with Microbeast "Get Outa Here !!"
Logo 690SX with Demon 3SX
SAB Goblin 500 with Microbeast
Garry Bagridge is offline        Reply With Quote Quick reply to this message
Old 10-08-2013, 06:50 AM   #42 (permalink)
HF MR Support
Local supplier doesn't have the 4530 replacement shaft.
Bought myself a 5030 shaft instead. Needed minor modification to fit.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 10-08-2013, 09:20 AM   #43 (permalink)
Are you worried about boom strike using the lower head and shaft? I know you said Timo flew with the 600sx head and lower shaft. Last night i finished installing all these mods so i will keep my fingers crossed
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 10-09-2013, 01:25 AM   #44 (permalink)
HF MR Support
I believe for speed run you should be fine.
If you are doing extreme 3D, best to stick to 690s blades.
Lynh
Old 10-10-2013, 07:03 AM   #45 (permalink)
HF MR Support
Final installation of all electronics components before permanent placement of fuselage.
Lynh
Old 10-12-2013, 11:29 PM   #46 (permalink)
HF MR Support
Flight tests completed on chassis. Everything is holding well together . Time to install fuselage.
Lynh
Old 10-13-2013, 06:25 AM   #47 (permalink)
HF MR Support
Very easy to install, everything just fits perfectly.
Love the German precision.
Lynh
Old 10-13-2013, 06:26 AM   #48 (permalink)
HF MR Support
Compared to a carbon frame SE
Lynh
Old 10-14-2013, 05:16 AM   #49 (permalink)
HF MR Support
Compared to a speed machine
Lynh
Old 10-14-2013, 04:52 PM   #50 (permalink)
Wow looks like some heavy duty redundancy for the RX. Do you have any info somewhere on the internet about your radio gear on this bird? Are you just using Capacitors and a Scorpion backup guard and a BEC somewhere?
Mike
maarset is offline        Reply With Quote Quick reply to this message
Old 10-15-2013, 05:44 AM   #51 (permalink)
HF MR Support
Mike
Hi Mike,
I am using the CC Pro Bec v3 as primary power supply. The Scorpion BUG is a backup and the Capacitors are recommended by Mikado when using with Savox servos.
Lynh
Old 10-15-2013, 05:47 AM   #52 (permalink)
HF MR Support
Garry
Hi Gary,
Using Vbar Gov, 11t pinion on 5030 LE 540Kv Speed edition motor, I am running the following head speed via my JR11X which allows 5 selectable idle up:
1600
1800
2000
2100
2250
Lynh
Old 10-15-2013, 09:59 PM   #53 (permalink)
HF MR Support
FFF feel is amazing, the heli is sleek and sliced through the air with ease. Today's 70km/hr wind gust does have an effect on the side profile and tends to push the heli sideways.
Lynh
Old 10-16-2013, 03:42 AM   #54 (permalink)
TommyBear,
That heli is sweet. I really don't want a 700 size heli but my desire for that Uvula body will probably win out. If I started with a 600SX kit,
http://www.readyheli.com/MIK2249-Mik...s_p_40712.html
and the Uvula body,
http://www.readyheli.com/MIK4752-Mik...E_p_41446.html
what else would be required to complete the airframe and body setup?
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
bradg is offline        Reply With Quote Quick reply to this message
Old 10-16-2013, 07:39 AM   #55 (permalink)
HF MR Support
Hi Brad,
You will need the SE upgrade kit.
http://www.perthrc.com.au/logo-600se-upgrade-kit.html
The aluminium pulleys and tail belt driver are optional but highly recommended.
That's it. Make sure you heli flies perfect before you install the fuselage.
It is very visible in the sky, it is also so light you don't feel any differences on air performance
It is suitable for big air and speed flying style. I had 65mph winds today and it had no problems dealing with the gusts.
Cheers
Lynh
Old 10-16-2013, 10:27 AM   #56 (permalink)
Dont forget bigger main & tailblades
Regards Arnaud
Mikado Logo 550SX | Mikado Logo 600SE V2
catzjes is offline        Reply With Quote Quick reply to this message
Old 10-16-2013, 11:55 AM   #57 (permalink)
Thanks guys.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 10-23-2013, 04:38 AM   #58 (permalink)
HF MR Support
Should I or shouldn't I ?
If anyone has this motor, your shared experiences are most welcome.
Lynh
Old 10-23-2013, 07:59 AM   #59 (permalink)
I love this motor and thats what i have right now, 12 S , 12 tooth pinion. Comes down cool, you can't beat Kontronik with effeciency and their built in fan in the motors are the best out there. Have it even rewound by Mauro can only be better.
_____________
Old 10-23-2013, 08:13 AM   #60 (permalink)
I have a Pyro 6+7 YY 1.25mm. It kills the Logo OWB in just a few flights even on 603's.7
This is '3D' flying though, might be oK for speeding, might not. Very strong motor even in my 7Hv it hauled ass and that's go at least 2lbs on a 600SE.
If you are proficient with Auto's have at it. If not maybe avoid, would hate to see that Fuse trashed going in from a blown OWB / stripped Main Gear.
GimpyGolden is offline        Reply With Quote Quick reply to this message
