Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-06-2012, 04:04 AM   #1 (permalink)
Default Gyro Menu question!
Hi friends...
Got a question on dx7se gyro menus. You can asign the gyro channel to get a GYRO SENSE MENU OR TRAVEL ADJUST MENU. I just want to understand which menu is giving easily the correct gain input. Are they both the same or?
Rudder servos are getting hot(61 degC...ambient temp 41degC!). Am tryng to look for what is causing the heating. I changed the bl9188 to bl251 still the same issue
saeed09 is offline        Reply With Quote Quick reply to this message
Old 05-08-2012, 02:26 AM   #2 (permalink)
Ok..i guess there are no dx7se users here!?!!
Old 05-08-2012, 06:09 AM   #3 (permalink)
i used to had this transmiter and use with the gyro sense...
i realy dont like the the travel adj setting.
now i have the dx 8 and i am using the gyro sense.
keep in mind that the best way is by according to manufacturer instructions.
so use the gyro sense.
Dx 8
T-Rex 700N LE
Ikon FBL
Ys 120Sr
sagiadir is offline        Reply With Quote Quick reply to this message
Old 05-08-2012, 12:09 PM   #4 (permalink)
Thanks for the reply
Ok thats what i have always been using but i just wanted to comfirm the best way and then try to understand further why are the servos getting very hot. What gyro,tail servo are you using on your 700?
Would you mind to share on how you setup your tail for hard 3d?
Old 05-08-2012, 01:47 PM   #5 (permalink)
i use the mks 980 with the gp790 ....
and i order beastx....(flybarless system)
check your limits and the pulse....
i use 760 us for the mks.
most of the servos use 1520.
here one of my flights with all stock
[ame]http://www.youtube.com/watch?v=9g2lh6y_W-s[/ame]
Dx 8
T-Rex 700N LE
Ikon FBL
Ys 120Sr
Old 05-08-2012, 04:26 PM   #6 (permalink)
Very nice flyng
The frame rate is correct with my settup but am not sure about the gain issue. Please see my vid below you might pin point the problem from the tail. There is a strange sound on the tail when i make tail stops. I cant understand also how to determine if the stops are reasonable or too much or less. Can these stops cause servos to over heat?
[ame]http://m.youtube.com/watch?v=loxjKky1Hcs[/ame]
Old 05-08-2012, 05:58 PM   #7 (permalink)
Check your boom brace
and the brings of the rear tube.
I had it too and find that the
Barings was out they place
And so the boom brace was free.
Dx 8
T-Rex 700N LE
Ikon FBL
Ys 120Sr
Old 05-08-2012, 06:36 PM   #8 (permalink)
Yap am aware about the brace issue but mines are intact. The problem is when the servo gets hot, the tail start to get loose waging slightly, i mean you start to fight to keep it straight.
Here the outside temperature is 41degC and above in summer. It might be the reason the electronics to get hot and starts to mulfunction.
It would be nice if we get an expert on electronics to veryfy this. I believe these Rc electronics are never tested in reall life of such weathers but they are just rated to certain lab test temp ranges.
Old 05-08-2012, 07:42 PM   #9 (permalink)
in 41 deg i stay at home under the shower
i cant fly in that temp.....
allso here in the summer its arround 41+ so i fly early in the morning.
when the temp is arround 30 or less.
in 41 deg i dont think elec can work
Dx 8
T-Rex 700N LE
Ikon FBL
Ys 120Sr
