Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 07-22-2013, 01:37 AM   #21 (permalink)
Originally Posted by kalleh View Post
The picture is from my thread here https://www.helifreak.com/showthread.php?t=542707 </threadhijack>
Nice try. You picked a 40A ESC when logs show people are pulling 50+ then, you replaced your own can and the motor was litterally gutted a few flights later. If it feels better go ahead and blame Kontronik but excuse me if I question your credibility and that's not how statistics work.
For the record, I think YGE is damn good stuff. I would have bought the 90LV but they were out of stock (upgrading a problem with signal loss - by the way). I had the funds so I got Jive (not a Koby). I didn't bother searching for all YGE or Koby failure issues and I am not keeping track.
That's my story and I sticking to it
California Cabernet & Cuban Cigars
Warp 360 | HC-3SX | JIVE 80+ | HK 2520-1360 | MKS DS92A+/95i | Radix | DX8 | PL6 | GP 6S 1500
Mr-Mike is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 04:40 AM   #22 (permalink)
What
ScotY is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 05:46 AM   #23 (permalink)
Default Re: New warp
The Koby 40 should have been plenty capable for the Warp. ESC ratings are based on continuous output and should handle peak spikes much higher. My average current draw on the Warp is usually only around 10 to 20A while spikes can be 40+. On my 3s Trex I routinely draw 65 to 80A spikes from the Ice Lite 50. I would have to look at my jlogs to remember what I pull through my Jives, but it's a lot! I would have to blame that motor.
Sent using Tapatalk 2
Danny Dugger is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 07:48 AM   #24 (permalink)
Member
A 40A ESC is just fine for this bird, especially on 16T. It's the Koby firmware that has a problem.
Old 07-22-2013, 09:15 AM   #25 (permalink)
Maybe I missed something... Can you point out where Kalleh specifically blamed his ESC? It looked to me like he was pretty diplomatic not to point fingers at any one component and more-or-less said it could have been anything.
Check out some of Lazor22's videos with his Warp 360. Last I heard he was running a Hobbywing Platinum 40A ESC.
radu7 is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 09:24 AM   #26 (permalink)
First, I was comparing the YGE to a Jive.
There was/is a Koby firmware problem (I saw that), like many other brands. Bob, you feel certain that's what caused Kalleh's BBQ? Interesting, then I will not challenge.
Also, if you guys say 40A is sufficient, I guess I will back-off with my opinon. You have my utmost respect and I am glad it's working out for you. I will make this one last comment though. For me, "peak" value specs are not what I use to make equipment selections (in any category of any type of equipment). I do not think it is wise to be operating near thresholds of continuous values, let alone peak values, and to deliberately choose a component based on its peak capacity and running at or near spec'd limit's is simply not good sense. I am sorry, maybe heli's are different.
Anyway, I am far from being a Heli (or ESC) expert so I will fade back into the crowd and try to minimize embarrassing myself
Old 07-22-2013, 09:37 AM   #27 (permalink)
Lots of koby failures, it was the firmware. That sound the original compass motors made had to do with it being able to speak to the koby correctly. Thats why the scorpion and new can compass motors sent them up in flames until they upgraded the firmware.
I am running a hw40, which is more then you'll ever need on a 6s 450. 40's run fine on 3s 450s and remember higher voltage means less amps.
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 09:48 AM   #28 (permalink)
Sorry didn't see this come in.
Your right! I was originally joking with Frito (well that was my intent). Completely lost track of that it was Kalleh who responded to my response to Frito (and not Frito). There was an implied argument (argument in a good sense) which appeared to suggest that the burnout picture suggested the ESC was the cause - when taken in context to the other post. Did that make sense?
Iazor22 is an amazing pilot!! But, I still wouldn't pick 40A ESC nor would I recommend it based on specs. I doubt the manufacturer would recommend it either (more likely they would recommend the next size or two up). If you guys want to recommend that, that's fine.
Old 07-22-2013, 09:53 AM   #29 (permalink)
Originally Posted by lazor 22 View Post
Lots of koby failures, it was the firmware...
Man I wish I didn't respond to that Koby post. I really just intended to give props to the JIVE. I do not think the Koby is better or in a higher category than the YGE for example.
Old 07-22-2013, 10:02 AM   #30 (permalink)
...for a given wattage.
Old 07-22-2013, 11:46 AM   #31 (permalink)
I'm sorry for causing the stir, I was just joking with you as well
Synergy E5S 606 | Synergy 516 | Goblin 380 Buddy | Oxy4
kalleh is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 11:59 AM   #32 (permalink)
Member
SNIP
"based on specs?.....What specs? And who are "you guys"? The manufacturer does IN FACT recommend a min 40A ESC when running on 6S. A 40A ESC has been PROVEN in the field to be more than sufficient.
Here are the specs for the Scorpion motor and HW40 Platinum ESC. You can see that the 40A ESC is plenty.
Scorpion 2520-1260kv Specs
HW 40 Specs
No one is talking about watts. Lincoln was saying that as the cell count (Volts) goes up, the current (Amps) goes down. Therefore you don't need a monster ESC on 6S.
Old 07-22-2013, 12:47 PM   #33 (permalink)
Mike just jokingly pointed out that amps go do when volts go up only when you speak about relatively same power I'm sure pretty sure that both amps and volts went up when I switched from my old stock Trex to scorped Warp
Goblin 700 Sport [spirit pro, hw130, xnova4525, bk kst servos, switch, gensace12s]
Warp 360 [SK540, yge v4 and other antique electronics, radix/edge blades]
uiron is offline        Reply With Quote Quick reply to this message
Old 07-22-2013, 02:14 PM   #34 (permalink)
HW 40 Specs
<snip>
Yep. Scorp peak = 40A but I thought you posted a log that showed you reached 50A (I could be wrong on that) I know that's peak and I get that the HW can peak at 60A. Me, I'll stick to the continuouos specs. I like a little more headroom that's all - it's not like certain conditions (flight stresses, manufacturer short-fallings) couldn't reasonably result in a failure (maybe a high discharge C rating - I dunno), it seems to happen frequently enough. Bob, I am not questioning yor choice or Freeko's. If I had the same experience level you guys have I would be able to make a firsthand determination as well, but i don't.
Exactly. Thank you Sir. I do understand 'current', that's why I 2 server power supplies running in series (one with a floated ground) to power my PL6 at 25 volts instead of 12. When the pack voltage drops at the end of the flight the amps increase. Of course 6S is better in that sense than 3S. V*A=W (inverse relationship).
Old 07-23-2013, 06:16 AM   #35 (permalink)
Originally Posted by frito169 View Post
... turnigy 306g hv servos
Nice find, will they do fine on cyclic and tail @ 6V?
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3, Formula swash/head
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 07:53 AM   #36 (permalink)
Default 6v
Yes they run excellent at any servo voltage.
frito169 is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 07:54 AM   #37 (permalink)
Great, do you use the same one for the tail?
And do they sell spare gearsets at HK?
Phoenix R/C v5
Old 07-26-2013, 09:10 AM   #38 (permalink)
Default New warp
It's complete! Long night for me
The yep and the bec would not fit so I removed the case and grinded the heatsink. I also shorten the bec and the esc wire. Overall i like it
Goblin 500 x2 | Gaui x3 | BD3SX | MKS | KONTRONIK | 14SG | PL8
Aeolus1 is offline        Reply With Quote Quick reply to this message
Old 07-26-2013, 09:34 AM   #39 (permalink)
Did you fit the canopy? I ended up turning my 3sX around and moving it back. The wires were too tight in the nose of the canopy when I had it like yours. I did not use the extended canopy mount, though.
Old 07-26-2013, 10:02 AM   #40 (permalink)
Remember... a 40A ESC can handle 40A of continuous current indefinitely. It can handle double that for 10 seconds.
We are not operating near any thresholds here... if anything, the same setup on 3s would be teetering on the edge.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
