Old 11-04-2010, 03:45 PM   #21 (permalink)
If someone else has YS56 pls post your needles....!
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 04:37 PM   #22 (permalink)
Originally Posted by MaSt0RaS View Post
on 2000 iam on 55% throttle... ..
YOu can have 2100 on 90%.... PLs check your taco..!
Ight ill check and get some Vids of me flying and ill get your guys opinion on it
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote Quick reply to this message
Old 11-06-2010, 10:23 AM   #23 (permalink)
at the end... ON high Needle ( the one that you need a screwdriver) is on 1 turn and the mid is 1.80-2 turns...!
SOmeone else to compare our needles??
thx!
Old 11-06-2010, 10:34 AM   #24 (permalink)
Ok guys going to the field nice come.day so do some vbar trim flights and HS checking... and ill make some vids and ill tach my HS and then Adjust my throttle curve and see if I can get it running better not gunna lean it out yet since it a rebreakin just a little paying around untill I get at least 2 gallons threw it
Just want to reverify the pinion is 14t and stock main gear is 129 t right need that Info to accurately tach my HS
Old 11-06-2010, 03:44 PM   #25 (permalink)
just got back but no video cause it was cold and no one wanted to do it...but i did lower my V curve to 90 - 87 - 80 - 87 - 90 and at about 85% just in a hover my HS was 2032 rpm's and it was flying good didn't try any loops cause my hands were freezing just rolls and flips and was pretty good just trying to burn fuel to get past break-in so i can lean it out cause my climb outs feel a little weak so soon as im done breaking in ill get some better needle settings to get it running right
Old 11-06-2010, 03:46 PM   #26 (permalink)
read post above
Old 11-06-2010, 03:51 PM   #27 (permalink)
Originally Posted by AnTi Taco View Post
read post above
Something is rong here i think...i dont think that if your motor works well you will be on 2032 with 85%... you must me on 2200 i think..!
YOur needels are rich...
in order to work well on velocity with multigov and outrage pipe i have to put the high on 1 turn and the mid on 1.75-2!!
Old 11-06-2010, 04:04 PM   #28 (permalink)
i used my heli tack app on my DROID and on graph it shows 2018 through 2078 so i just averaged the high and low and said 2032 in my 2 min hover im not really sure if it was 85% it was just a little over half stick just enough collective for a 2 foot hover... plus who know how accurate the APP it but im sure it was in the ballpark...
Old 11-06-2010, 04:16 PM   #29 (permalink)
THis app is not good for the nitros.. its good for the electrics... but i am not sure check it with the optical tachometer..!
Old 11-06-2010, 05:01 PM   #30 (permalink)
I gotta buy a optical tach then ....do they sell a point and shoot tach kinda like a radar gun police use? I don't like how you gotta look through a viewfinder and click a button to get the HS with those sky tachs
Old 11-06-2010, 05:05 PM   #31 (permalink)
Nop... only optical tachometer
No one on your field has one???!
Old 11-06-2010, 05:08 PM   #32 (permalink)
I'm like the only real heli guy there only like 2 others I see but they like 65 year old men with 450's and training gear that's been one them for years they said lol
Old 11-06-2010, 05:16 PM   #33 (permalink)
The Capi
You cannot fly and use the tach at the same time, just buy yourself a gov that lets you set the RPM, like the ATG or MGP.
Old 11-06-2010, 05:19 PM   #34 (permalink)
I was going to but I just put the new full-size vbar on my velocity and it has a Gov sensor port so I was gunna use that ....beta was just released for the Gov today or yesterday but I think I still need a optical tach to set it
Old 11-06-2010, 05:22 PM   #35 (permalink)
a tach is usefull.. IS a must have tool..
Buy the bantam Checker 2..
iT has temp meter voltage meter amp meter optical tack and prop tack...
its great..!
Old 11-06-2010, 05:41 PM   #36 (permalink)
The Capi
Blah must have tool, had my tach for like 3 years and never used it.
Old 11-06-2010, 06:16 PM   #37 (permalink)
Old 11-06-2010, 06:34 PM   #38 (permalink)
True don't need.one.if you have something like a multi gov only need them if you have a ar7100r or like align gov stuff like that my Droid app has a setting for nitro and electric it askes what's you pinion and how main gear teeth you have..so I'm the thinking its designed for nitro too ill make a thread asking how accurate it is
Old 11-06-2010, 06:41 PM   #39 (permalink)
yeap but it can record the blades sound as ti has to do because of the engine noise..1
Old 11-06-2010, 08:46 PM   #40 (permalink)
made a thread about the app https://www.helifreak.com/showthread.php?t=255154
the app works on the motor noise and the pinion and main gear info i enter...i just looked at my app and the log of my rpm flight today and it looks pretty accurate i can see on the graph when i spooled down and up to landed then went into a hover so in that regards its picking up the rpms but how accurate it is i dunno
