Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley |
02-03-2013, 08:33 AM | #41 (permalink) |
Not bad! Much better than I expected! Do you recall what it weighed in nitro form?
- James - www.RCTodayShow.com Host |
02-03-2013, 05:55 PM | #42 (permalink) |
according to the box, about 7.5lbs. My guess is with the same electronics it would be close to 8lbs
Carey Shurley Proprietor - Gas Powered Helicopters |
02-05-2013, 01:59 PM | #43 (permalink) |
Hi Carey, is the gear ratio I found online: ''Main Drive Ratio: 8.538:''1 correct for the Fury 55?
It's higher ratio than T-rex700....... I would have expected a lower ratio for 600 size? something in the 7:1 or even 6:1, no?
T-rex 600E pro T-rex 450L Coaxial Collective Pitch 550 |
02-05-2013, 05:14 PM | #44 (permalink) |
Here's the model in flying form:
7.4:1 gear ratio, 640mm blades is the current config
02-05-2013, 08:05 PM | #45 (permalink) |
I'd like you try smaller blades 600mm please.
just a question, is the ALIGN starter enough for this engine ? |
02-06-2013, 03:27 AM | #46 (permalink) |
What about 620mm asymmetrical blades with gearing around 9:1 ?
02-06-2013, 05:48 AM | #47 (permalink) |
Align Starter - I don't have one but if it will start a std .90, it will start this
600mm blades - original flights were with 620's. Its a 9.5 lb model so its quicker with the longer blades. 9:1 gearing - would limit the RPM to around 1750 if staying within reasonable engine RPM. Most of the 600's perform best above 2K rpms
02-06-2013, 06:15 AM | #48 (permalink) |
I see canopy posts,does the standard fury canopy fit ?
AMAIN Heli Team |
02-06-2013, 12:52 PM | #50 (permalink) | |
Because the model is now a little taller and a little longer its not as proportional as I would like but it does fit. I modified the rear mount positions so that they aren't as close to the edges of the canopy where its easier to crack.
02-06-2013, 12:59 PM | #51 (permalink) |
Looking forward to hearing how this thing flies. Nice work!
02-12-2013, 06:35 PM | #52 (permalink) |
I have quite a few flights on the model now
no real issues from a conversion perspective, model works as it should. Its a bit nose heavy but I'm not going to address that in this version the gear ratio isn't quite right yet, more changes this week.
02-14-2013, 08:31 PM | #53 (permalink) |
Can you share your finding with the gear ratio you use please?
If I remember it's 7.4:1 on 640mm RT blade.
02-15-2013, 08:36 AM | #54 (permalink) |
I was at 7.4 with 640mm blades
just changed to 7.92 with the same 640 RT blades
02-17-2013, 11:44 PM | #55 (permalink) |
will you post any video soon please ?
03-04-2013, 01:35 PM | #56 (permalink) |
I would love to see a video. I also would ;ove to see a conversion kit for sale
03-06-2013, 06:46 PM | #57 (permalink) |
okay you asked for it, video it is
thanks to Bobby Watts, Miniature Aircraft, Futaba, Hobbico and OS Engines
03-06-2013, 08:37 PM | #58 (permalink) |
not impressed, the .55 glow engine is much more powerful...
he said 1900-2000 rpm, if the gear ratio is 7.9 your engine was running at 16.000 rpm ???? unless Tareq try one for fun I won't buy it. I'm very disappointed! |
03-06-2013, 10:16 PM | #59 (permalink) |
Really nice....
I hope MA makes a lightweight 600 size heli for this engine. But you can get a modded RC engine for a gasser for about the same price of the GT15HZ. And after seeing the Century video of the downsized G30 with that modded engine makes making a decission on a gasser more complicated (in a good way). Excellent work Mr. Shurley. |
03-06-2013, 10:18 PM | #60 (permalink) |
gasoline models are about economy. Fly a long time for not much cost with no mess
the goal is to get them where they fly acceptably for a majority of pilots. If you want a 9HP model, nothing will meet your needs but an electric this flight used about 16 cents worth of fuel and the model was still clean after the flight.
