Warp 360 Compass Warp 360 Model Helicopter Discussion |
10-20-2013, 03:27 PM | #1 (permalink) |
MKS 95 uneven response to channel value
one of my MKS95 servos started acting weird. Whenever there's a change in stick movement direction, the horn would start moving very fast, then it would slow down. To test it, I connected it directly via receiver, to rule out FBL behaviour. I can clearly see that while moving stick up and down at even speed, whenever there's a change from "up" to "down" or vice versa, servo horn shoots forward, then decelerates.
The servo used to be on elevator, and as far as I remember had one gear change. In total like 200-300 flights old. From what I understand, potentiometer went crazy. Tried to open to internals, but doesn't look like there's access to clean it up, it's firmly hot glue'd. Is the servo busted? Would you replace whole set of cyclics in such case?
Goblin 700 Sport [spirit pro, hw130, xnova4525, bk kst servos, switch, gensace12s] Warp 360 [SK540, yge v4 and other antique electronics, radix/edge blades] |
10-21-2013, 01:25 PM | #2 (permalink) | |
If it can be done wrong, I will find a way to excel at it. |
10-21-2013, 01:58 PM | #3 (permalink) |
yeah, it has gone through one output gear change. After another inspection of the slot where output shaft goes in shows that the "D" shape of it is kind-of damaged, I probably pushed output shaft in in mis-aligned. What's strange though, is that it flew like this for well over 100 flights after the gear change.
Anyway, what about another part of my question - would you replace just one servo, or the whole set of cyclics in such case when one servo fails?
10-21-2013, 04:14 PM | #4 (permalink) |
i would only replace one servo, actually i would send that servo back to mks and see what they could do for me. maybe they could fix it on the cheap.
----------------------------------------------------------------- Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more. |
10-22-2013, 12:06 PM | #5 (permalink) |
Call Thomas at MKS USA. I have had the honor of spending some serious time chatting with him. Talk about superior customer service! He is the man to talk to here. He returns all his calls personally.
10-22-2013, 02:58 PM | #6 (permalink) |
yeah he will talk your ear off haha.. and he will take care of you if your servos are under warranty, i think you get a year warranty..
10-22-2013, 03:08 PM | #7 (permalink) |
I don't know, a servo few hundred flights old, had at least one crash with a broken shaft, mis-aligned replacement gear pressed in, damaging potentiometer socket.. hell I would not cover warranty myself. Also, sending it across the Atlantic twice will take too much time and money
I've already got a new servo on the way. does said Thomas have an email? Phonecall is troublesome due to time differences and me being non-native speaker
10-23-2013, 12:10 PM | #8 (permalink) | |
10-23-2013, 06:16 PM | #9 (permalink) |
thanks - I'm in the process of trying to get any response, MKS representatives in EU recently changed so it's hard to understand who to talk to.
Anyway, thanks all for help! Tomorrow mailman will hopefully bring the new servo so I can finally test my brand new second hand sk540
10-23-2013, 07:00 PM | #10 (permalink) |
I spent this afternoon tuning one up on one of my 600s. Great controller! I had one coupled up with my Mks servos on the Warp earlier. Brilliant flying heli. Razor sharp. And the proactive gov is to die for.
