Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 07-27-2014, 06:59 PM   #1 (permalink)
Default kosmik jlog 2.6 and 18mz
ok i consider myself a reasonably intelligent person but this horribly translated from German manuals crap is driving me batty.
anyone have a decent walk though or video of how to make this crap work together?
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 08:10 PM   #2 (permalink)
Hi Chris,
Please be patient. I was in the same situation a few weeks ago. The system will work very effectively.
I found that a good start was to reformat the SD card using the described SDformater on www.JLog26.eu.
Everything sort of falls into place after you do that, and follow the instructions on the JLog site.
Tom on this site is also unbelievably patient and helpful.
Regards,
Andy
AndrewJHawes is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 01:32 AM   #3 (permalink)
this is a great bit of kit which I only started to use this weekend, I am no expert but I have been making some notes
I have broken down into stages the sequence for setting up the jlog which area are you having trouble with.
1. Wiring loom
2. Formatting SD Card
3. Firmware updating
4. Configurator JLC
5. Registering Sensors
6. Alarms
7. Logging
PS I am stuck on item 7 I have downloaded logview 2 but I am unable to
Vetequk is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 02:34 AM   #4 (permalink)
Install LogView v2 and do that as the user who will finally run it. (Do not install as "administrator" but run as "Vetequk".)
-> Logging, Log Viewing
Log files are imported, not opened:
The common record format used (as JLog do) is OpenFormat.
Nevertheless, LV needs to know the record (line) structure: number of items, position of each item, its name and unit, and how to evaluate it.
So before importing a log tell LV which device to use:
There is a device already included which almost fits to JLog2.6 also: "SM JLog2":
("almost": it does not fit entirely regarding JLog-own sensors.)
In download we have more device description files.
Such a file is a .ini -- to be placed in %appdata%\logview\geraete\openformat (Here's the reason why you should run LV as the user who has installed it: "%appdata%" is in the local user area.)
Much easier teaching of LV is done by opening (yes, now open) the alternatively provided device file .lov. A file of that extension is an export out of LV -- containing everything: device definition, colors etc.
Afterwards the new device appears under "OpenFormat":
This should be sufficient as quick start instruction.
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 11-29-2015, 07:58 AM   #5 (permalink)
1. Wiring loom
4. Configurator JLC
6. Alarms
7. Logging
Good day,
What am I doing wrong?
In step 5(all configured device) - when I tried to registering in 18MZ, all-time I didn't see SBS-01 sensor...
Here is my procedure:
J Log registry at Futaba (0 min 33 sec)
Pashech is offline        Reply With Quote Quick reply to this message
Old 11-29-2015, 10:35 AM   #6 (permalink)
You did the BIG RED BUTTON on JLC before finally writing to SD card and powering down? Next power on is ONLY ONCE IT IS CONNECTED TO TX.
Then you have to register 8 times in TX and 9th will fail, then all sensors should be vissible in TX.
VControl
Old hand at Planks
Peter
Old 11-29-2015, 10:49 AM   #7 (permalink)
Yes... Without this step - registry don't work.
I trying a lot of times...
