Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Cypher 3D
Cypher 3D EF Cypher 3D
Old 03-16-2010, 10:04 AM   #1 (permalink)
Default Cypher 3d Setup
Boy do I feel DUMB. Just finished putting in the servos in my Cypher 3D and see it uses CCPM 120 deg. I not sure where the servos even plug in, what a mess. My Challenger just uses the normal setup. First my Transmitter is a Futaba 9CHP. I looked in the book and think it should be set to SR-3?? Basically I need HELP.
1-What channels on my Futaba receiver do the servos go into? Ail, EL, TH, RUD. ect.
2-I want to use EXPO to tame it (new fly-er) do I put it on all channels?
Last anyone who can suggest a basic setup so I don't burn things up I will be in your dept for years. Can't believe I would start this at 68 years old. Been flying since 1970 so I do know what goes up will come down. Even have the garbage bag ready. Thanks much Doc in Potter PA.
wa3itz is offline        Reply With Quote Quick reply to this message
Old 03-19-2010, 11:24 PM   #2 (permalink)
SR3 120deg swash setting
Aileron: channel 1
Elevator: channel 2
The other aileron: channel 6. Also known as pitch.
ESC is channel 3. REVERSE this channel now. and then on your endpoints make the low side 110 instead of 100. This will ensure that your system will arm when you plug in the battery.
Your gyro will plug into channel 4 and the other wire from the gyro with only one wire in the plug will go into channel 5.
If you want to use expo, I would not use more then 20% and use it on Aileron, Elevator, and rudder.
Do a search for different settings and look at what others use. There is not a single one that works for everyone. I would say to use a pitch gauge and set up your heli with a total of -4deg of pitch and +10.
This will keep you from slamming into the ground if you get into trouble and panic
I hope this helps..
Trex 600E FBL....Trex700DFC...Trex700FBL
more to come.....
crashagain is offline        Reply With Quote Quick reply to this message
Old 05-07-2010, 08:52 PM   #3 (permalink)
EXPO--- use a NEGATIVE value during the set up on your Futaba radio.
AMA/CD# 365566 AOPA# 5081747
AMA Turbine # 15130
... Intercepting the Localizer...
Guidance by Futaba 14MZ Heli 2.4 GHz ......FUTABA-- Always Imitated, Never Duplicated
sleddog7 is offline        Reply With Quote Quick reply to this message
