Old 02-08-2013, 06:30 AM   #1 (permalink)
Question Did I burn it up?? (3GX)
By mistake (poor eyesight) hooked up the bind plug to the “Batt/Aux Out” port and the servos went nuts. Now that I have it in the “S.Bus/Bind” port the servos still bottom out with noise. So the question is, did I destroy this unit for good?
Pete
E sky BELT-CP Stock / Clone 450 Times Four / Tarot 450 DFC / T-Rex 550E DFC
T-Rex 600E Pro / T-Rex 250 Pro / T-Rex 450 DFC / Blade 450 3D / Gaui 425
MCPX V2 Times Two / Clone 450 Stretch / Blade 130 X / T-Rex 500 DFC / Spektrum DX7s
4Pete2Fly is offline        Reply With Quote Quick reply to this message
Old 02-08-2013, 06:59 AM   #2 (permalink)
Default Did I burn it up?? (3GX)
Are you using digital or analog servos?
Sent from my iPod touch using Tapatalk
ferebeed is offline        Reply With Quote Quick reply to this message
Old 02-08-2013, 07:02 AM   #3 (permalink)
Align digital
Old 02-08-2013, 07:11 AM   #4 (permalink)
When you hooked it up did it evan come on when you had it wrong?
I would unplug all servos & rebind it. Then turn it on in dir. Then plug up the servos to see what they do.
Old 02-08-2013, 07:28 AM   #5 (permalink)
I had bound it previously before mounting in the proper ports. Then when I mounted it all that is when I put the bind extension in the wrong port. Not sure what I was thinking but left the bind plug in the extension when I plugged in the battery. Yes the 3GX came on & the servos went into a chicken dance mode. I ordered a new one anyway, I’m sure there will be no recovery, but will try what you suggest after work today.
PS: Hopefully the two satellites did not take a hit as well.
Old 02-08-2013, 04:26 PM   #6 (permalink)
The bat out is the SBUS port and is the port you use to bind. You mean you plugged in the bind plug while powered? or into the channel input ports you use when you wire a separate RX?
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 02-08-2013, 04:51 PM   #7 (permalink)
Had the plug in the "BATT/AUX OUT" when I powered up, not in the "S.BUS/BIND" as required.
Old 02-08-2013, 06:18 PM   #8 (permalink)
Did you get it to work?
Old 02-08-2013, 08:05 PM   #9 (permalink)
No, I tried what you suggested without luck, the servos went to the end point once I plugged them in. I decided to use a stand alone receiver (AR6115), bound it & same thing the servos moved rapidly to their end points. Could the Talon 90 have something to do with it? I still can arm it and run the motor.
Old 02-08-2013, 08:14 PM   #10 (permalink)
Just sent you a pm
Old 02-09-2013, 10:58 AM   #11 (permalink)
Just sent you a pm
I got it working Dale,
After sleeping on this and with nothing to loose, I decided to give the throttle calibration a go on the Talon 90 with the AR6115 still hooked up with no servos attach. Had to go 114% for both the high & low. Hooked the servos back up and we have normalcy with their movements. Hooked the 3GX, bound, attached servos and all is good to go. I’m assuming when I put the bind plug in the wrong port, it messed up the settings inside the Talon 90’s little brain cell.
Thanks for the help.
Pete
Old 02-09-2013, 11:02 AM   #12 (permalink)
Glad you got it going
Did you call me?
Old 02-09-2013, 11:05 AM   #13 (permalink)
Did you call me?
Yes I tried, but all is good now.
