Old 05-04-2014, 10:47 PM   #1 (permalink)
Default Accidentally left fuel line clamped...am I ok?
I got distracted today and missed my fuel clamp check before taking off. I flew for 2-3 mins with a few aggressive moves. Came down to check fuel level and it leaned out heavily, so I set it down and turned it off. That's when I discovered the mistake. It is an O.S. 105HZ-R so the regulator was still able to pull fuel for some time.
I got home and took off the muffler and back plate. There didn't seem to be any obvious signs of damage on the piston (muffler side) or what I could see with the back plate off . I'll probably still take it completely apart to make sure, but has anyone done this before? Anything specific I should look for to determine if the engine is damaged? Any suggestions on what I should do now (drop some after run or transmission fluid in it)?
Thanks!
AngryDragonfly is offline        Reply With Quote Quick reply to this message
Old 05-05-2014, 03:52 PM   #2 (permalink)
Your engine ran for 2-3 minutes with the fuel line clamped leading into the carburetor?
I'd be shocked if it ran for more than a few seconds if that's the case. Maybe were missig something here?
If your ring is black, and there's no vertical scoring on the piston, you're probably ok. Check your plug for any signs of lean.
dchekas is offline        Reply With Quote Quick reply to this message
Old 05-05-2014, 06:11 PM   #3 (permalink)
I am also surprised with the 2-3 minutes unless you have extremely long fuel lines you clumped well ahead of the engine...A regulator give you few more seconds until it burns the fuel it retained indeed but not 3 minutes. Check the engine as Dchekas suggested or just go fly and if the tuning and idle are same as before, no overheating, same performance and no weird noise you should be fine (at your own risk though).
RontaryUS is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 09:28 AM   #4 (permalink)
Thank you for your replies. The guys at the local heli shop had heard of it happening before. They took a look at the engine and thought it was still ok. I'm just a bit paranoid because I'm a noob and bought this heli used. About 20 flights after I bought it, the engine made some racket and it turned out shrapnel from a worn rear bearing scarred up the piston and sleeve, so I've already had an expensive repair.
They recommended I just remove the clamp considering it isn't doing me any good (other than refueling) since I have a regulator, so this shouldn't happen again.
