Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion |
07-30-2014, 12:41 PM | #81 (permalink) |
Ok last part finally uploaded hopefully for your viewing pleasure |
07-31-2014, 12:03 AM | #82 (permalink) |
Great job on the wireless Heli chip. Looks really good.
I'm working on servos now. I decided to notch the frame brace for the elevator servo arm clearance instead of grinding on the servo arms. I love a dremel.
Align 450 L, Align 550E, Align 600 pro dfc, Goblin 700, align 700N, logo 800 extreme |
07-31-2014, 01:05 AM | #83 (permalink) | |
And very good build video series. Yet another suggestion.... With regards to your Spektrum remote sats....I noticed, in video #4, that there didn't seem to be much "strain relief" where the RX sat cable is connected to your Spektrum sat. I consider that a weakpoint...as well as at the other end, where it plugs into the VBar.. So....I used liquid electrical tape(LET...available at Home Depot or Auto parts stores).. ..carefully masking off the coverage area...and "slathered" it on.... After drying...strain relief...remember that those connector types are subject to vibrations, as they were 1st developed for PCB interconnections....no vibes. With regards to the 11/22 ms issue.... I've heard of that...with Spektrums....but with JR sats. I just chose 11ms...and there were no issues....with MiniVs with Pro 5.3.4...and MKS 9XX series servos. When I got a 700XX/800XX...with the Silverline(800XX's is "has specia firmwarel")....I had to choose "digital servos" to obtain proper "binding" and further operation. Not well documented. FWIW |
07-31-2014, 10:20 AM | #84 (permalink) |
Hi @Mark17\EEngineer
Thanks for your positive comments on the build. I really enjoyed putting this heli together. @Mark17 that notch you cut out looks much better than mine so I assume a dremel is one of those handy things to have in this instance! @EEngineer I will definitely look into getting some of that LET as I have never seen or heard of it before. And yes the sat wires are tightened up so putting this stuff on will definitely help. You live you learn they say Cheers |
08-03-2014, 03:21 PM | #85 (permalink) |
Looking very good. I use a 3300 may battery on my HV setup, and get about 8 flights out of it, though I never push them much below 60% just to protect against voltage drops. Mine is on the outside of the frame so that I can interchange several battery shapes that I have (Thunder Power, Pulse and Gens Ace). I just looked at mine and believe that larger battery will still fit where yours is. It looks better there so I'm going to move mine. Thanks. You might find the 1300 may battery in the video is a bit small for those servos. Looking forward to seeing yours fly.
Logo 800 // Logo 700 12S/14S// Logo 690 // Logo 400 // Mostro 700E's// Whiplash 700E// Gaui NX7 // Gaui NX4 // Gaui X4 // Gaui X3 //Goblin 570 // Trex 250 // TBS Discovery /Naza M2 // Jeti DS-16 // V Control // Jlog // BD3SX// VBar Neo// Lifetime AMA |
08-07-2014, 08:29 AM | #86 (permalink) |
Has anyone had an issue with main gear wobble on their 800 build. I tried to get the screws even on the one way bearing but in my first spin ups on the bench it does have a slight wobble. It can't be good with the herringbone teeth. Also the gear mesh is not consists since it gets tighter then looser.
08-11-2014, 05:53 AM | #87 (permalink) |
I wish I could help but mine has never done that.
