Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 05-17-2014, 04:11 PM   #1 (permalink)
Default New castle 6.5 connectors
Well today the 800 lost power and I had to auto down, came in a bit hard and broke a landing skid. Could have been much worse, I was inverted.. When I went to unplug lipos one was already unplugged. These connectors were hard a hell to pull off so I'm not sure how it came unplugged during flight but now it feels not as tight as before . And these are new connectors. No other damage but sucks that I put better connectors on and this happened. Happy flying all!
TREX 800 DFC PRO HV , TREXIKON 600 EFL PRO , LEAP 3D QUADCOPTER
Heli biggie is offline        Reply With Quote Quick reply to this message
Old 05-17-2014, 09:43 PM   #2 (permalink)
Glad you got her down without too much damage Heli biggie. Well done
But, I wouldn't have thought connectors become loose by themselves in just one flight . ( It does happen, but unlikely, IMO.)
I would check there are no other underlying issues eg, signs of heat, batt short etc. Check your logs too, if you haven't already, before putting it down to bad luck alone.
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 05-18-2014, 02:25 PM   #3 (permalink)
The one esc plug in question was loose with all lipo connectors. So I was told that sometimes the inside with the slits sometimes get pushed together more, so I carefully stuck a small hex head driver in the middle and that did the trick , hard as hell to pull off now, just another thing to add to the list of things to check before flight, I will be doing a pull test EVERY flight now. Hopefully just a 40 dollar lesson well learned, I will also be wrapping them together with velco for double protection.
Old 05-21-2014, 09:19 PM   #4 (permalink)
Default Power glitch # 3
Ok guys I REALLY need help now. I had another power glitch after I swapped out to castle connectors. The 1st flight today went perfect, the 2nd flight had the power glitch .
Please help. I'm not sure what's going on except I must fix it.
align trex 800 power glitch 2 (2 min 9 sec)
Old 05-21-2014, 09:32 PM   #5 (permalink)
post your esc settings. Especially motor timing.
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Reply With Quote Quick reply to this message
Old 05-21-2014, 10:33 PM   #6 (permalink)
Gov mode set rpm
Gov gain low 15
Cutoffs auto lipo
Current limit norm
Current cutoff type soft cutoff
Auto lipo volts. 3.2
Motor start power medium 59
Motor timing normal 5
Pwm rate out runner
Old 05-21-2014, 10:54 PM   #7 (permalink)
I have my Current limit set to (insensitive 280A)
PWM 12khz
Sounds as though it's going into Soft cut off
Old 05-21-2014, 11:02 PM   #8 (permalink)
try putting your gov gain at 11-12. Sounds like it went into soft cutoff. PWM at 12 you have yours on outrunner.
Slow & Steady!
nmdesertracer is offline        Reply With Quote Quick reply to this message
Old 05-21-2014, 11:10 PM   #9 (permalink)
I have my Gov gain at 15 also.........
Old 05-21-2014, 11:50 PM   #10 (permalink)
Yeah, try running not in outrunner, but 12pwm instead, and see if you can touch the motor for more than 5 seconds after a flight (how hot it gets)
Old 05-22-2014, 06:46 AM   #11 (permalink)
Thanks so much guys , I thought I had everything default / correct. Have a wonderful day! More flight testing this weekend. But a little nervous.
Old 05-22-2014, 10:56 AM   #12 (permalink)
Just take it easy for the first couple of flights after changing parameters. Maybe a bit ott but I'd check logs after 2-3 mins and at the end of the first flight just to ensure alls well.
Good luck
Old 05-24-2014, 07:16 PM   #13 (permalink)
Thanks so much guys, everything worked as it should today, no power glitches.i am so happy. I changed everything but the gov gain was left at 15! So nice to be able to trust the 800 again. So much to still learn. Got my half piro flips down on all helis also! Yehaw!
Old 05-24-2014, 07:58 PM   #14 (permalink)
That's great news
Doing demos for the school kids too, by the looks of the pic
Old 05-25-2014, 04:38 PM   #15 (permalink)
So the motor is still really hot after flight??? Can't touch for more than a second. But again today great flights with no glitches. Charging batts for more fun after this rain!
Old 05-25-2014, 04:42 PM   #16 (permalink)
high motor temp is sometimes ok (high esc temp is not so good). Are your outside weather/air temps above ~75F?
My motor gets where I can touch it for 5 seconds, but no longer than 5sec, at 70F day temps. I think that's normal.
The only real test is with a temp gun.
Your ESC log above shows a max of 150F I think, so thats fine.
Old 05-25-2014, 04:54 PM   #17 (permalink)
I live in ga so today I was sweating while just unloading helis, lol, I'll check my logs again when I get bored,thanks
I also noticed during pitch pumps that I had a bit of a front to back bobble , how to tweak that?
Old 05-25-2014, 10:03 PM   #18 (permalink)
likely a setting in your gyro
Old 05-27-2014, 08:55 PM   #19 (permalink)
Pots gain setting or what, I noticed it more at lower head speed like 1700 but not 1800 but I like to run 1700 sometimes or lower. More info would be great help?! Other than that this heli is awesome!
Old 05-31-2014, 02:09 PM   #20 (permalink)
If I had to guess I would say worn head dampers and/or CoG not perfect.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
