2.4G JR Radios JR 2.4 Gigahertz Radios and Technology |
View Poll Results: Did your X9303 have wire chafing inside upon inspection | |||
Yes - My X9303 had a chafed wire | 104 | 49.52% | |
No - My X9303 had NO chafing and was fine | 106 | 50.48% | |
Voters: 210. You may not vote on this poll |
08-20-2008, 08:30 AM | #21 (permalink) |
add another to the list. mine is/was affected.
and, i'm not too sure about JR's fix either. routing the wires as suggested is simple. but, there's still some interpretation left as to exactly where the wires go from JR's small photos. what i discovered is that if i route the bundle so that the chaffed portion of the wire sits closer to the aileron gimbal as in their first photo.... the lower right portion (when looking at the photo) of the gimbal actually gets hung up on the wire at full deflection...so much so that there is added tension on the sticks near 100%. you can actually see in their own photo where the gimbal will pull on the wires. and, if i route the wire such that the gimbal does not interfere with the wire as in their 3rd photo from the top the chaffed portion is still extended out where the regulator chip can chafe. i've tried to route them so that there is neither binding on the gimbal nor chaffing on the chip. but, there's no way to tie down the wires with the recommended fix...there's still some wire freedom that will allow them to adjust over time. i'll be checking this again in a couple of weeks.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı |
08-20-2008, 09:51 AM | #22 (permalink) |
Registered User
How hard was it to open the radio and get to the issue for us that are kinda iffy about popping open a expensive radio to do some mods to it ourselves Cuda?
William James Crazy wife still trying to kill me. |
08-20-2008, 09:57 AM | #23 (permalink) | |
the side sliders and rubber thumb grips on the sides are prone to pop off, but they just slide back into their slots. there's also two connectors that need to be removed from the circuit board to remove the back cover completely. not mandatory to do but makes it a lot easier. really only a 5 minute project except for not being 100% sure that their mod will work.
08-20-2008, 09:58 AM | #24 (permalink) |
Team Taco CEO
It's just 6 phillip screws, I've open it several times to adjust the gimble tension. You just got to be careful of the battery wire that attached to the back of the case.
Kevin Don't Taco My Pack, Bro! , Why crash when you can POUND it! |
08-20-2008, 11:28 AM | #25 (permalink) |
And the two side levers are a pain when you put it back together.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
08-20-2008, 04:04 PM | #27 (permalink) |
Thanks for the info...gonna check mine asap. BTW...could the wires be wrapped with that black spiral plastic wire protector?
08-20-2008, 05:34 PM | #28 (permalink) |
Registered User
Those are very clear and good photos. I will be opening mine up later tonight or tomorrow. Thanks for the info everybody.
08-20-2008, 07:25 PM | #29 (permalink) |
the wires are a lot smaller than the photos make them look. you'd be hard pressed to wrap anything around them.
08-20-2008, 07:51 PM | #30 (permalink) |
holy cow batman
ok just opened my case up and my blue wire is 80% cut threwto think if it would of failed at ircha last week. i am sending it off to jr asap.. Do Check your radios!!!!!!!!!!!!!!!!!!!!
08-20-2008, 08:55 PM | #31 (permalink) |
Team Taco CEO
Yep, took mine and Bob's apart and ours were pretty much the same. Black wire eaten 80% through.
I didn't want to use goop and wait for it to dry. My fix is pretty much like JimLerch except I also cut down the plastic on the gimble unit.
08-20-2008, 10:19 PM | #32 (permalink) |
Did a check on my DSX9 last night. Lucky to say that there was not damage or any signs of abrasion on the wires. Anyway, I did the fix recommended by JR, and i'll check back in a few weeks time.
08-21-2008, 01:35 AM | #33 (permalink) |
Just Received my new X9303 yesterday.
15 minutes or so on the sim for testing when Laurens from the forum here mentioned this problem on my msn. Opened it and i could see that the problem was already starting on the isolation...jeez. Thanks Helifreak !!! Maurice |
08-21-2008, 04:35 AM | #34 (permalink) |
Registered User
Thanks for the photos Kevin.
08-21-2008, 03:20 PM | #35 (permalink) |
Just pulled mine apart, NO problem.
But I did mod it. I did what was to Goop the wire bundle to the gimble, so that it won't get out near the regulator. I will bevel the regulator also.
08-21-2008, 05:35 PM | #36 (permalink) |
Well, I am glad to say my radio was just starting to show wear and had not gone through the insulation yet. So thanks so much... by the way, don't you think that the person that originally figured out the problem and posted should get a very nice limited edition jr 12x 2.4 or what ever new radio they are working on at the moment as a big fat thank you for not having to say sorry to the loads of people that would have lost aircraft's??
I think so.. I would like to see a pole... it would perhaps help spread the news as well.. and who knows someone might listen... Any way...Random person who found this out...I thank you, my wallet thanks you, and my wife I think may wish to thank you as well because she knows how much this stuff cost...LOL |
08-22-2008, 04:13 AM | #37 (permalink) |
BTW I got an email from Horizon about the issue. Seems they are taking it VERY seriously.
08-22-2008, 07:42 AM | #38 (permalink) |
Inspected mine and it was showing coper on the blue wire. No fray cables, used liquid tape from star brite and moved the cables like JR says. Will check in a few weeks and do the other mod (sanding the plastic culprit) and covering cables with shoe goo. Thanks for the heads up, it really saved a crash. Double O
Trex 600N KME Diamond 60 engine w/ Hattori (18, for 90eng.) muffler, jr8717, Spartan 760/Futaba9256, 610mm Rotortech, AR7100r 8v. Logo 600 FBL w Pro-Bar & Spartan 760 on tail, Scorpion on 10S and Jazz ESC(big) JRX9303 TX. |
08-22-2008, 09:52 AM | #39 (permalink) |
Registered User
There is a POLL at the top of this thread now, so please vote.
08-22-2008, 11:57 AM | #40 (permalink) |
[ATTACH]60029[ I checked my wiring. I could see were it was rubbing, but it was not worn thru. Since I had the radio open, I decided to fix it anyway. I carefully cut a slit on the top of the slotted part of the gimble, and slid the wires out. I then epoxied the free end of the wire to the back of the gimble, and zip tied the excess wire at the base of the PC board. The wire has plenty of slack for freedom of movement, and doesnt come near anything that could chaf it.
