Old 03-11-2014, 11:46 AM   #81 (permalink)
Originally Posted by baui2000 View Post
You can simply push the big "450" button in basic setup and it will fly ok with a touch of tail gain tuning Detailed setup won't help you anyway since it has to be tuned for every heli.
It was like that with the BeastX when I had one on the Mini Protos, but the defaults after clicking the magic "450" button were not so great.
Just looking for some help and examples. I know every heli is different and people have different flying styles.
Inconsistent piro and dolphin in FFF are my obvious problems
Anyway things seem to be getting better. Much more I gain for the tail and elevator, and reduced the agility.
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 09:31 PM   #82 (permalink)
A lot of people running tgy306s here. Would you reccomend these over the hs5065mg for mini p cyclic dutt?
Old 03-29-2014, 06:01 AM   #83 (permalink)
Well the tgy-306/kst215/kds n300, are rally good servos, better specs all around than the hs5065mg and cheaper ! and they don't strip gears easily (haven't stripped any in 3 crashes).
The only thing is that you have to take them apart when you get them to isolate the board from the metal casing :
4 : Tarot 450 Pro V2 Build : Turnigy S306G-HV Servos (13 min 55 sec)
I haven't had any issue with them in a 100 flights.
I have heard good 3D pilots say that they didn't notice a difference between the MKS DS95 and the tgy-306 so I figured I wouldn't either And since you can get 3 tgy-306 for the price of one DS95 the choice was quite easiy to make for me.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 03-29-2014, 03:03 PM   #84 (permalink)
Even better than the 5084. Are you running 4 of them or 3 and something different on the tail?
Old 03-29-2014, 05:19 PM   #85 (permalink)
I'm running a DS95i on the tail, it was my first build so I didn't want to have any issues with the tail.
Some other people here run it on the tail with good results though I believe.
Old 08-05-2014, 11:40 PM   #86 (permalink)
Got mine ready to maiden. Mounted the Mini Vbar on the boom block because it was the only way I could get wiring to work. There's a bit of a mess in front of the gyro, but that looks like how most people run it.
My favorite part is that the Mini Vbar matches the canopy lol
Old 08-06-2014, 02:42 AM   #87 (permalink)
Looking good
I also have my wiring like that, it doesn't look too messy, and I really couldn't be bothered to shorten the leads so much.
Old 08-23-2014, 02:34 AM   #88 (permalink)
Im surprised to find out that my mini p is heavier than the trex. I have noticed it is a little boggy in hard flights
Old 08-23-2014, 06:40 PM   #89 (permalink)
This has always been the issue with the Mini P, and was the first thing I noticed on mine.
In order to get max performance out of it, you have to really keep up on service, you will wear out belts and pinions, break Jesus bolts and kill bearings in the Y and the tension pulley...
There is no denying it is an awesome flying 450, but it is high maintenance and problematic...
The latest Lynx kit has helped new Y and new Idle pulley!
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 08-23-2014, 06:58 PM   #90 (permalink)
I always read that the protos was light weight. Assumed it would carry over to the mini. If yours was boggy on 3s too then I wont worry about mine. I'll dial the pitch back a little and save my pennies to go 6s, just didnt want to swap the motor shaft again since I run the warp pinion.
Then I'll stretch when I run put of tail booms.
Mine flies well other than bogging in tic tocs etc. I'll just keep up on the maintenance I guess
Old 09-30-2014, 10:59 AM   #91 (permalink)
I finally joined the Mini P club
I've only been able to fly 3 packs so far but I feel warm and fuzzy when i fly it I can't wait to fly it again.
3S stock motor, yep 40a esc, kst red servos all around and Mini V-bar.
Team Lynx Heli Field Rep
XL Protos 380
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 09-30-2014, 11:15 AM   #92 (permalink)
Congrats. Same setup as mine. Flies great as long as you aren't too hard on it. Mine gets a bit boggy compared to my rex.
Old 09-30-2014, 11:45 AM   #93 (permalink)
Try going into the Pro governor settings and increase collective add and cyclic add. That will make a difference. I haven't done anything for adjustments other than those 2 settings.
XL Protos 380
Old 09-30-2014, 12:17 PM   #94 (permalink)
I'm flying the yge gov for now. Part of it is probably that I refuse to run less than 3400, so it's only got about 5% overhead end of pack.
Old 09-30-2014, 12:29 PM   #95 (permalink)
Try one more on the pinion, maybe that will help and allow a little more overhead.
XL Protos 380
Old 12-20-2014, 06:17 AM   #96 (permalink)
Just flew mine 2 times. It's really quiet. This is my setup and it is 3rd hand:
mks ds95s
JR 3500g
mini vbar
spectrum sat
CC ice lite 50
scorp 1630kv
13 lynx pinion upside-down
no y support
Alex
Fleet: Miniprotos
Flock: cockatiel and congo african grey
dedados is offline        Reply With Quote Quick reply to this message
