Old 10-07-2009, 03:00 PM   #21 (permalink)
Love it. Very powerfull and smooth.
I've picked up a 2nd engine and pipe this past week.
George
I don't crash. I land with style.
Bowtech and Hoyt
Tradhunt is offline        Reply With Quote Quick reply to this message
Old 10-08-2009, 03:34 PM   #22 (permalink)
Just looking for some advice from Novarossi 57 owners with the Novarossi pipe. I am getting a Trex 600 & swaying towards buying a 57. I fly fairly near houses so wanted to get your views on how noisy the Novarossi pipe is? If it is really noisy any suggestions/experience of alternatives. At the moment just basic sport flying/learning ff, 8's, rolls & flips so ultimate power isn't an issue ......Many thanks
scottd92 is offline        Reply With Quote Quick reply to this message
Old 10-09-2009, 09:20 AM   #23 (permalink)
Simple short answer - it's definitely louder than a standard 50 size.
500CF - 3650's, 3500G, Spartan, Stock ESC, Stock Motor, TP 6s Pro Power 2700mAh
PROTOS - 3650's, 3500G, Spartan, Scorpion 3026-880, ICE Lite 100, TP 6s Pro Power 2700mAh
600E - 8717's, 8900G, Spartan, Scorpion 4025-890, CC HV85, TP Pro Power 8s 3850mAh
Kasama Srimok - 8717HV's, 8900G, AR7100R, Spartan, YS 91SR, Hatori SB19
huskynox is offline        Reply With Quote Quick reply to this message
Old 10-09-2009, 11:08 PM   #24 (permalink)
The Novarossi pipe makes a higher pitch noise that is not cool and kinda annoying - like an angry moped
The Hatori 566 makes a deaper sound (cooler too)
The Funtech pipes are normally nice and quiet - so the OS powerboost pipe may be your best bet
Gryphon field rep
Jafa is offline        Reply With Quote Quick reply to this message
Old 10-14-2009, 11:32 PM   #25 (permalink)
Check out Dario Neuenschander's Compass flight with the 57HR at the Alpine Smackdown last weekend. This motor screeeeeams!
http://www.youtube.com/watch?v=TYKS5...layer_embedded#
Old 10-15-2009, 02:16 PM   #26 (permalink)
Anyone use exhaust gas cooler on NOVAROSSI or OS 50?? It help somethink?
Trex 700E 12s Pro DFC
Trex 600E 10s with Vbar
Trex 450 Pro with Vbar
Trex 250 with scorpion 3600Kv
VDFS is offline        Reply With Quote Quick reply to this message
Old 10-18-2009, 03:56 PM   #27 (permalink)
Default bolts between pipe and header
I am having trouble with the bolts that attach the pipe to the header - I have sheared four bolts already and damaged the aluminum inserts that reside in the rubber flanges. My fan/clutch is balanced and dial indicated but the small bolts cant stand the vibes.
Anyone else with this issue? This is one to keep an eye on for sure. Perhaps I jinxed myself, but when I put this together, I wasn't that optimistic about it. There is quite a load on the pipe slinging around in flight.
On the plus side, this engine/pipe combo provides great power.
DF
desert_flyer is offline        Reply With Quote Quick reply to this message
Old 10-22-2009, 03:08 AM   #28 (permalink)
can you tell me something .... is it easy to tune... also can i use enya 3 plug...
Also what about the shims?? when i want to go from 20 to 30 i have to change the shims?
I am asking cause i see a lot of problems about this engine...
With the shims with the plugs and all these on RR....
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 10-23-2009, 06:48 AM   #29 (permalink)
Noone??
BTW i ordered one with the nova exhaust...
i will use Enya 3 plugs is it ok??
Also can i use a carbsmart or not?
Old 10-24-2009, 08:16 AM   #30 (permalink)
Hi
enya 3 maybe is little warm, but you can try, normally the 57 like colder pugs O5, Align 4 or Novarossi HR3.
About the carb smart, sure you can, Novarossi sale a special Needles with clutch built in system that help greatifully the user in the setting becasue you don't need to disconnect the linkage to set it.
About mix tuning is easy , but different to OS, ASLO as we tell to every one Novarossy engine come from standard super tuned, than like each engine tuned like run at the specific RPm that was designed for.
The 57 run very good between 17000 to 19000 perfect for heavy 3D in your 50 size heli.
About temerature , don't use OS one reference, but use the Novarossi than back plate 50 / 55 and head 110 / 120 and enjoy you.
BTW here a new video that we make during the Alpine Heli Smachdown.
[nomedia="http://www.youtube.com/watch?v=5CoS4KW0p-o"][YOUTUB"]YouTube - Broadcast Yourself.[/nomedia]http://www.youtube.com/watch?v=5CoS4KW0p-o[nomedia="http://www.youtube.com/watch?v=5CoS4KW0p-o"][/YOUTUB"]YouTube - Broadcast Yourself.[/nomedia]
Luca Invernizzi
Lynx Heli Innovations
OXY HELI
ininverno is offline        Reply With Quote Quick reply to this message
Old 10-24-2009, 10:44 PM   #31 (permalink)
Anyone running this motor in a Raptor 50? The motor is actually just a little big for the motor mount! Wondering if you are running it yourself or even know someone, and if you do did they dremel the motor mount to get it to fit?
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!
XL 700 Specter V2. Xera 500kv motor, Tesla cyclic servos, Tesla tail, HW 200amp ESC, Ikon 2 FBL. XL Protos 380, Torq servos, HW esc, Egodrift motor, Ikon 2
Blades345 is offline        Reply With Quote Quick reply to this message
Old 10-25-2009, 07:19 PM   #32 (permalink)
Dear For the new raptor we discovery that the lower part of our engine have too many ribs, we designe it using a older engine mount and we was screwed.
Now we will modify the crank case, but per istance as many user already do, you can dremmel out the extra ribs in the lower crank case side and fit it into the new raptor engine mount.
Hope my explain come right to you.
Frendly
Luca
Luca Invernizzi
OXY HELI
Old 10-26-2009, 09:26 PM   #33 (permalink)
Are these temps taken with a infrared temp gun on the back plate?
kpete is offline        Reply With Quote Quick reply to this message
Old 11-01-2009, 03:53 PM   #34 (permalink)
i have a question about the low needle..
Is there any issue when exactky will be the throttle when i setup the low needle?
Fro example if i setup it when its fully close or when its on idle is there a difference??
Old 11-03-2009, 02:05 PM   #35 (permalink)
Has anybody found the new throttle arm in the US, I can't even find it listed anywhere.
ChuckL is offline        Reply With Quote Quick reply to this message
Old 11-03-2009, 06:37 PM   #36 (permalink)
Mast0ras... Skyped you back.
ChuckL.... It's listed on the Lynxheli site here... About half way down the page..
http://www.lynxheli.us/index.php?opt...d=15&Itemid=13
Give the part # to you're dealer and they can order you one.
George
Bowtech and Hoyt
Old 11-05-2009, 07:49 AM   #37 (permalink)
someone with 20 fuel and OS 8 plug to tell me his settings...
this engine is untunable...
But it has a lot of power... any help will be appreciated..!
thx!
Old 11-05-2009, 09:44 AM   #38 (permalink)
MaSt0RaS,
You should probably lower the compression (add head shims). My Rex .91 needed much more than the manual stated for 20% (Rotor Rage). I'm running an Enya #3 plug as well. The motor didn't run well at all until I experimented with the head shims. I'm currently running .4 mm, and it seems very happy.
J.B. Jones
head_node is online now        Reply With Quote Quick reply to this message
Old 11-06-2009, 10:25 AM   #39 (permalink)
ι have 0.4 shims too with 20% more than enough..!
Old 11-06-2009, 10:52 AM   #40 (permalink)
Well, .4 is enough for me in Mississippi with my combination of fuel and plug. It's very well possible that in your climate .4 isn't sufficient for the fuel/plug combo that you're using. Just an idea, but if it were mine, I'd shim it until it ran correctly and go from there.
J.B. Jones
