Old 12-11-2010, 06:12 PM   #61 (permalink)
Everything was ok for my YS91SR also except the fact..
that the copper ring which attached on the upper position of the sleeve
was bigger than the diameter of the head's flange so ..
it was not sealed completely flat and I had a small oil leak just underneath the spark plug.
I kept running the stock head ...
Now I think of removing a small part of the outter perimeter of the copper flange to test again the head..
Bill
Esprit Model Flying, TDR Rigid x2
F9 Fiberglass Europe Canopies
billiano is offline        Reply With Quote Quick reply to this message
Old 12-11-2010, 07:55 PM   #62 (permalink)
Does the sleeve fit ok ?
I mean if the sleeve fits perfectly so it is not a machining problem. Sometimes the shims doesn't seat perfectly and it gets squashed in between with a consequent leak. It happened on my stock SR once.
The nice thing about this head is that it works on the old SR and the new 3DS
6HV, BLS451, Quark+MKS BLS990, Jive 80HV+Compass 540KV
3D+, Savox 1258TG, Spartan DS760+MKS BLS990, OS55HZ+Funtech B320
Rave ENV, Savox 1267MG@6.6V, BeastX+MKS BLS990, YS91SR+Hatori SB19
All controlled by a DX8
Pulento is offline        Reply With Quote Quick reply to this message
Old 01-19-2011, 08:26 PM   #63 (permalink)
Default ys head
hey pulento how is the performance?how many gall?
betta2500 is offline        Reply With Quote Quick reply to this message
Old 01-20-2011, 05:44 AM   #64 (permalink)
Does it fit the latest YS ? the SRS/SR-3DS ?
~Roei~
TooLy is offline        Reply With Quote Quick reply to this message
Old 02-03-2011, 09:17 AM   #65 (permalink)
Yes it fits. I installed it on one of my 3DS and it works just fine. Haven't flied it too much since I was on vacations and my ENV is waiting some spares. The few flights I made I was running a rich mid, this head delivers a bit more power on mid.
And I have to check RPMs since the ENV has 8.12 instead of 8.21 of the T700.
Old 07-12-2012, 10:31 AM   #66 (permalink)
Default ys 120
any one interested in a dual plug head for this engine?
Old 07-12-2012, 01:05 PM   #67 (permalink)
what about os 105/55hzr would def try that
Vcontrol-Vbar-Nitro Gov
Whip Nitro 105 Awaiting V2 Conversion
Synergy N7 105
*Perspective is key*
jgalen0025 is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 01:36 PM   #68 (permalink)
Smile os 105 an 55
Im working on the drawing right now!
Old 07-12-2012, 02:35 PM   #69 (permalink)
Would the 50 hyper would benefit from the duel plug?
stupid question but is the hyper 50 and the 55 the same head?
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote Quick reply to this message
Old 07-13-2012, 11:36 AM   #70 (permalink)
Hi, I'm looking for a dual plug head for my ys 91 SR and am told the Viper head is not a good fit with the new YS engines. Can anyone here recommend one or have one for sale?
thanks,
John
Dr.J is online now        Reply With Quote Quick reply to this message
Old 07-13-2012, 11:51 AM   #71 (permalink)
Originally Posted by Jafa View Post
Cars and various engines use multiple spark plugs to get the flame front to travel sideways faster and then start pushing the piston down
You can get a smoother running engine
You can use two different heat ranges - makes the idle really smooth on one plug and the stunt mode really smooth on the other plug
Some argue that it's also a bit of a safety against a flame out due to loosing the plug in flight
Indeed:
Cgarr is offline        Reply With Quote Quick reply to this message
Old 07-13-2012, 11:51 AM   #72 (permalink)
Default ys sr 91
I have a few in stock so let me know!
Old 07-13-2012, 11:52 AM   #73 (permalink)
betta, I e-mailed you via the address at the beginning of this thread, but received no response. What is your e-mail?
Yes, I'm interested.
thanks,
John
jsjb@sympatico.ca
Old 07-13-2012, 12:05 PM   #74 (permalink)
Default ys sr 91
Betta2500@aol.com
Are u jhon?
If so i did receive an email and i did responded it!
Any way let me know!
Thank u!
Old 07-13-2012, 08:11 PM   #75 (permalink)
In the old days we used dual plug heads on the OS50
We never noticed any benefit
It's only on the 90's that we noticed benefits
I assume it would work well on the OS105/YS120
Gryphon field rep
Jafa is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 09:10 AM   #76 (permalink)
Why is that it benefits only 90 size and not 55
Synergy N7 105
Old 07-14-2012, 09:33 AM   #77 (permalink)
I have no idea why - that was our experience
Gryphon field rep
Old 08-29-2012, 01:23 PM   #78 (permalink)
Default ys heads
finally anodize!
what u think?
ID:	344603   Click image for larger version
ID:	344604   Click image for larger version
ID:	344605   Click image for larger version
Old 08-29-2012, 03:18 PM   #79 (permalink)
Are you doing any for the YS 120.....
jwatts007 is offline        Reply With Quote Quick reply to this message
Old 08-29-2012, 03:23 PM   #80 (permalink)
Default ys heads
Yes,pretty soon!
