Old 01-25-2009, 07:53 AM   #81 (permalink)
Minor bug - I believe that the MSH Protos main gear is 93T not 97T, see here: https://www.helifreak.com/showthread.php?t=110375
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 01-25-2009, 03:08 PM   #82 (permalink)
93 teeth on the Protos is correct
My HobbyCentral program also has a simple headspeed calculator
You can launch multiple copies of the function to compare different setups at the same time
You can type your target headspeed in and it will calculate the pinion for you
Use the right mouse button over the main gear field to get a list of popular e-Helis,
choose one to have the main gear entered for you...
http://rotarypower3.com/jafa/HobbyCentral.zip
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4
Gryphon field rep
Jafa is offline        Reply With Quote Quick reply to this message
Old 01-25-2009, 04:03 PM   #83 (permalink)
Nice alternative calculator, Jafa! Looks like a good addition to get multiple calculations for comparisons.
Kenneth, I got the gear size from someone else that claimed my previous value was wrong so I'll change it back to 93. When I was originally looking for the value it was hard to come by so I'll trust you on this one and then upload a new calculator.
Haven't been working on this much because of too many other distractions in life with work and personal stuff but it should be quick and easy to make a change and upload this quick fix later on.
Had lots of ideas about how to enhance this and make it plug into a networked dbase of motors, pinions, helis that could be updated by the user community but its just not in the priority queue at this time.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote Quick reply to this message
Old 01-25-2009, 04:35 PM   #84 (permalink)
Would be nice if one of these HS calcs allowed you to put in your Throttle curve and have it display what the HS will be.
Today they all just display (guessing here) what the HS is at 100% throttle, but I run a governed 85%. be an easy calc to say what the HS will be at 85%.
povern
Screw It, I'm gonna fly.
VControl, Neo, Hobbywing, Goblin 570(s)
povern is offline        Reply With Quote Quick reply to this message
Old 01-25-2009, 08:11 PM   #85 (permalink)
The problem in trying to achieve that is
it relies on people calibrating their ESC to the TX end points (many people don't do this)
and it's not always a linear response - we would need a lot of data on every ESC
It's just not worth the effort considering how easy it is to sort out at the field
All the hot 3D setups on small heli's tend to need and use all available power
so knowing what HS you will get at 100% throttle is what we want.
Also, keeping the ESC wide open at 100% keeps it cool
Gryphon field rep
Old 02-13-2009, 01:58 AM   #86 (permalink)
Added version 1.0.10 of the calculator tonight.
Modifications are:
1. Added motor and gearing for the Trex 250
2. Added gearing for the Mikado Logo 600 mod 1.0 (106T)
3. Corrected the MSH Protos gearing (now 93T)
Can be downloaded here:
http://www.brucerc.com/downloads/HSCalc.zip
with a description of the changes here:
http://www.brucerc.com/software/hscalc/version/
Still haven't added any new features... way too many other things going on.
TRex 450SE
Spektrum DX7
Old 02-13-2009, 02:31 AM   #87 (permalink)
Yeah - I'm working on a program too - very much work in progress
Gryphon field rep
Old 02-13-2009, 05:17 PM   #88 (permalink)
great work here on these calculators , just the type of thing i need
jimheli is offline        Reply With Quote Quick reply to this message
Old 05-28-2009, 09:42 AM   #89 (permalink)
Default HSCALC....
Hi Bruce...
Just found your calculator after using the online ones....I like it very much.
As an old application programmer myself, I would certainly add a tab to the interface
that would allow folks to input their own data (common type i.e. motors gears etc.) to help suppliment
your installed data. This would be very easy to do and would eliminate that sort of maintenance for you...
Remeber Bruce, the best programmers are lazy ! ;-)
Just a thought,
Ty
Tyree is offline        Reply With Quote Quick reply to this message
Old 05-28-2009, 10:42 AM   #90 (permalink)
I love the battery calculator feature which makes it easy to calculate flight times!
A big help would be if the applacation could remember the last input of the capacity!
Greetings from Austria
Martin
Libelle is offline        Reply With Quote Quick reply to this message
Old 05-28-2009, 12:26 PM   #91 (permalink)
Thanks for the suggestions. I've been planning a feature to add/edit custom information and even download community supported information but its taken a back seat to other priorities.
Libelle, I thought it would remember battery capacity but I'll need to look into that and see what's happening.
I'm hoping this summer will give me more time to tinker.
Also, I started looking into porting it to the Google G1 phone. Anybody out there have one and interested? Seems I can make it easily work with that porting process on the iPhone as well.
Thanks for using the calculator,
Bruce
TRex 450SE
Spektrum DX7
Old 05-30-2009, 12:31 PM   #92 (permalink)
You are right Bruce, it was my mistake!
You have to close the application with the [OK] button, if you close it with the red [X] it does not remember the last settings!
Martin
Old 12-27-2010, 09:58 AM   #93 (permalink)
Great tool guys. keep up the nice work.
I see there are certain motor included by default like scorpion.
I suppose you can never add them all but since the scorpion 4025 is a widely used motor there are still some configurations that are not in there like the 550KV.
Maybe you can add this one?
these are the specs:
Specifications
Stator Diameter40 mm (1.56 in)
Stator Thickness25 mm (0.98 in)
No. of Stator Arms12
Magnet Poles8
Motor Wind14 Turn Delta
Motor Wire18 - Strand 0.29mm
Motor Kv550KV RPM / Volt
No-Load Current (IO)0.9 Amps @ 10v
Motor Resistance (RM)0.035 Ohms
Max Continuous Current65 Amps
Max Continuous Power2850 Watts
Weight326 Grams (11.50 oz)
Outside Diameter48.9 mm (1.9 in)
Shaft Diameter4.98 mm (0.19 in)
Body Length51.5 mm (2.01 in)
Overall Shaft Length83.7 mm (3.30 in)
Max Lipo Cell12s
Motor Timing5deg
Drive Frequency8kHz
Ermax is offline        Reply With Quote Quick reply to this message
Old 05-05-2015, 02:22 PM   #94 (permalink)
Default Best head speed calculator for if
This is the best one that I've seen for the iPhone
https://itunes.apple.com/us/app/rc-h...987943017?mt=8
Old Guys Rule
Zaneman007 is offline        Reply With Quote Quick reply to this message
Old 05-06-2015, 09:12 AM   #95 (permalink)
Default HS
it looks great but i could not get it to work
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 05-07-2015, 10:13 AM   #96 (permalink)
apparently it requires iOS 8.0 or above.
Old Guys Rule
Old 04-08-2017, 04:04 AM   #97 (permalink)
Cant believe I only just discovered this! Thank you!
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 07-09-2017, 09:15 AM   #98 (permalink)
Great stuff, thanks
Nikki
Rave90ENV - Frenzy 600/700 E DFC- Align Trex 500E - Copterx 360 BA DFC
Nikki5 is offline        Reply With Quote Quick reply to this message
