nano CP X Blade nano CP X Helicopters Information and Help |
10-03-2012, 07:06 PM | #1 (permalink) |
How many of you are balancing your blades?
I have found a big difference in performance by balancing the main blades on the nano.
Mine came out of the box with an annoying slight vibe,it got better after a break-in period but even after 20 30 flights the tail fin would still vibrate in a hover,the tail had a slight twitch and I was getting cyclic oscillations when decelerating. So I took a small piece of electrical tape about 1/8" X 1/2" and moved it around from blade to blade to establish the light one,I then moved the tape around inward and outward to find the absolute best placement. The results are an amazingly smooth / quiet heli,the tail is much better than it ever was and the slight cyclic wobble I would get on deceleration has completely vanished..
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even. .Who is John Galt? |
10-03-2012, 07:11 PM | #2 (permalink) |
I am
Goblin 770 sport, Fast Devil 505 Oxy 3 Tereq edition 2017 Blade 360 cfx modified, Blade 360 cfx stock Blade 180 cfx ,Blade mcpx Trex 150 |
10-03-2012, 07:13 PM | #3 (permalink) |
Believe it or not the two pair I have at the moment are perfectly balanced right out of the bag, no tape needed. Normally I do balance my main blades though, quick and dirty style.
DX9black, Blade 70s, OMP M2 V2, Blade 230s v2....soon |
10-03-2012, 07:13 PM | #4 (permalink) |
How do you guys balance it? I have an Align 250 size blade balancer but the nano blades unfortunately don't fit!
Align TRex 600E Pro, 3GX v3.1; Align TRex 450 Pro DFC, 3GX v3.1; Align TRex 250 Pro DFC, 3GX v3.1, Blade mCPX BL |
10-03-2012, 07:34 PM | #5 (permalink) |
With a small heli like the nano,I spin it up in my hand,adjust tape until it feels smooth,then adjust till it's smoother..
Disclamer:::: This method can be dangerous,wear appropriate safety gear....Kids,don't try this at home,we are professionals.....
10-03-2012, 07:38 PM | #6 (permalink) |
I use an extreme magnetic balancer with the micro sized heli blade spindle.
http://www.wowhobbies.com/mageticbla...icrohelic.aspx
03-04-2014, 07:12 AM | #7 (permalink) |
I know raising the dead here...
What are people using to hold their blades strait for the soup cans / glasses balancing approach? Thanks |
03-04-2014, 07:42 AM | #8 (permalink) |
Toothpicks.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis Thanks to Oxy Heli and MSH-Direct.com Former Username: Code3Medic |
03-04-2014, 08:16 AM | #9 (permalink) |
Haven't balanced mine... I smack it into the ground too often
450X, 350 QX (GoPro H3B), 130X, Nano CP X, Nano QX, Hubsan X4, Proto X Nano Spektrum DX7s Phoenix Sim Aerial pics at http://foosyou.imgur.com |
03-04-2014, 11:57 AM | #10 (permalink) |
Sometimes vibes are caused by twisted blades. That's why vibes may go away after a few days of use
03-04-2014, 04:51 PM | #11 (permalink) |
You serious, Clark? They should definitely be balanced and don't bother doing it on a balancer. As others have said, do it dynamically and spool it up in your hand. That way the entire rotor head assembly is addressed. For extra points use an app on your phone to help like iSeismometer.
Go fly one! |
04-20-2016, 06:01 AM | #12 (permalink) | |
Does it come with the screws needed to balance Nano CPX blades?
What about MCPX BL and 180 CFX? Quote:
04-20-2016, 04:29 PM | #13 (permalink) |
Home Depot has a really good assortment of small metric screws.
They also sell aluminum angle pieces at a very good price and these make excellent balance points. I would assume Lowes, Menards, most hardware stores, etc. would similar stuff. And yeah, I always check the balance all my blades.
. . I have to turn the music down while driving so I can see better. |
04-20-2016, 05:56 PM | #14 (permalink) |
+ 1
I always balance mine, and again while doing any maintenance. I'm very particular about it too. With the micros especially if you want them to fly nice they have to be as close to perfection as your willing to get them. That is the difference between micros not being so great and being awesome.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 600N, 700N |
04-20-2016, 05:59 PM | #15 (permalink) |
^ This.
You hear people say it's not worth balancing blades on a micro. But, these things are so little, it doesn't take much for them to fly like crap. On my 4 blade mCPX (Aphrodite), I took extra care balancing all 4 blades. When I run shortened mCPX blades on her, you really can't even hear the blades.
05-13-2016, 07:33 AM | #16 (permalink) | ||
My homemade balancer
Team Scorpion Team Boca Bearing Team Revolectrix Check out my Heli Pilot Shirts https://teespring.com/stores/rc-heli-pilot-shirtsMy Youtube channel http://www.youtube.com/user/JJInvert...n?feature=mhee |
05-14-2016, 09:16 AM | #17 (permalink) |
^ Nice.
That's exactly what I did too. I did find some 1" aluminum angle at Home Depot later on for the uprights. Using an old main shaft is an easy way to find the CG point too.
05-14-2016, 09:25 AM | #18 (permalink) |
Been through a bunch of stock and different brand bullet and straight nano blades and never balanced any of them. Never had any vibes caused by blades even with cracked up blades that I glued back together.
Not enough weight or hs for it to matter unless they are horribly imbalanced. Only heli I could mix blades from different sets without balancing and not get any ill effects.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm ~Problem Child~ |
05-14-2016, 01:29 PM | #19 (permalink) |
Maybe I noticed a difference because I basically just hover in the garage.
08-02-2016, 10:34 PM | #20 (permalink) |
High altitude flying!
Anybody flying high altitude and know how to get the nano to work better other than the brushless upgrade and speaking of that does the brushless upgrade even help and I altitude I'm talking 5 to 7000 feet ???
Thanks! |
