Old 05-11-2016, 09:07 PM   #1 (permalink)
Default phoenix dongle /R7
Tell me where I went wrong.
I used a R7 receiver set to PPM positive 20ms output and phoenix dongle.
I cut the stereo jack off the dongle and soldered the white wire as signal and red as ground to a servo lead. Connected on sat1
Powering receiver with battery.
Now here is the weird part. Phoenix says transmitter not connected
unless I'm pressing on the servo output pins with my finger. found that by accident.
I assume I'm grounding something.
It works correctly when pressing on the servo pins so I know I have missed something simple.
Let me know what you think
buzzcut44 is offline        Reply With Quote Quick reply to this message
Old 05-12-2016, 02:22 AM   #2 (permalink)
Maybe the two wires are reversed...
Groucho_ is offline        Reply With Quote Quick reply to this message
Old 05-12-2016, 04:11 AM   #3 (permalink)
This could help:
Mirco
gelatmi1 is offline        Reply With Quote Quick reply to this message
Old 05-12-2016, 06:28 AM   #4 (permalink)
Originally Posted by gelatmi1 View Post
This could help:
Nice!
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot
jmackey is offline        Reply With Quote Quick reply to this message
Old 05-13-2016, 01:09 AM   #5 (permalink)
I see in the PDF file you coonect the red cable from the usb cable and the Black and white cable from the cable that would normaly go to the transmitter.
How did you identify the cables inside the box? Mine are sealed with apoxy, or did you just strip the cables outside the box and make the connections there?
Necroscope is offline        Reply With Quote Quick reply to this message
Old 05-13-2016, 01:30 AM   #6 (permalink)
Not all units are identical.
Some are covered in that black compound more than others.
Mine is essentially solid-state.
I put it back in the box and got a cheap all-in-one dongle from some Chinese site instead.
Old 05-13-2016, 01:48 AM   #7 (permalink)
Mine is pretty heavy with the apoxy.
Would doing the white and black connection on the TX cable and powering the receiver wiith a battery work?
Old 05-13-2016, 04:39 AM   #8 (permalink)
Mine is pretty heavey with the apoxy.
Well, if you do manage to cut into the cables, I would eliminate the use of a battery.
No point in having one, when there's 5v coming in through the USB connection.
So Red wire from USB cable side to red wire in your servo connector.
Black wire from anywhere to black wire in your servo connector.
and White wire (signal) from TX cable side to white wire in your servo connector.
See if you can just scrape some epoxy and insulation off the wires, enough to expose the actual wires, and tin those points. Then put a ready-tinned servo cable in there and solder in place.
Old 05-13-2016, 08:56 AM   #9 (permalink)
I could not get it to work as the drawing shows and still does not work
Im going to be as clear as i can
I did cut wires back from each side of dongle box.
So i will say usb side for before the dongle and rx side for after dongle just because there are the same color wires used.
Red wire from usb going to rx(power 5.1v)
Rx side of dongle white wire is signal ( thats the tip of the stereo plug.)
There are 3 wires on the rx side of dongle one signal (white)
One red wire (jeti web site says that is ground, middle part of stereo jack)
Last is shielded stranded wire surrounding red and white wires.(Inside part of stereo jack)
Here is where one of the problems are. I only have two wires to choose from.
If i hook up red wire from usb ( 5v power)to rx center pin on servo connector and red wire as ground from rx side of dongle to ground pin i get no power to rx.
If I hook up the shielded wire to ground on servo connector (red wire not connected) I get power to the rx BUT the dongle is no longer recognized by phoenix as being plugged in. So shielded wire has to be a ground for usb
Now if i unhook usb power and use red wire from rx side of dongle for ground and power rx with battery the sim will see the dongle as connected but not the transmitter UNLESS(and i dont understand it) im holding on to that loose red wire coming from center pin of the rx( the one that was connected to usb side but is now not connected to anything) everything works as long as i touch that wire.
I cant explain it but let me know what u think.
Joel
I will take some photos later today.
Old 05-13-2016, 09:46 AM   #10 (permalink)
Have you tried PPM negative, that's what I had to use when I made my RealFlight dongle.
My bet is that PPM negative with the signal and ground wired as per the PDF in this thread would work.
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 05-13-2016, 02:09 PM   #11 (permalink)
I got it figured out. All works as it should. Thank you to all who helped.
It is PPM negative
Also need to tie red wire and shielded ground to ground servo wire.
Also the usb side red (5.1v ) is connected
Whoo i can sim again
Old 05-19-2016, 10:34 PM   #12 (permalink)
I can't seem to figure out this wireless sim with the Jeti. I soldered up a usb dongle with a R4L receiver and bound it to my tx. I'm using RF and after I match up the channels I cannot get any movement. I'm set to ppm negative. What am I missing?
T-Rex 700 Dominator vx1e, Goblin 570 vx1e, T-Rex 600N DFC vx1e, Jeti Ds-14
NSFlyer12 is offline        Reply With Quote Quick reply to this message
Old 05-20-2016, 01:37 AM   #13 (permalink)
How do you have it wired? A photo might help us see if there's anything obvious wrong.
Old 05-20-2016, 06:00 PM   #14 (permalink)
Here is a pic. I have the RF interlink controller.
[IMG][/IMG]
Old 05-20-2016, 09:58 PM   #15 (permalink)
Which port are you connecting to on the R4L? PPM out will only be possible on port 4.
Old 05-20-2016, 10:34 PM   #16 (permalink)
Yup connected to port 4.
Old 05-21-2016, 06:48 AM   #17 (permalink)
Remember, some port 4 is actually mislabled as port 3. I think this was on the R4L. Try it in the other port. Did it bind to the transmitter? Wherever you put the bind plug and made it work is port 4.
Dan
Old 05-21-2016, 08:11 AM   #18 (permalink)
Dan
Yup did bind to tx with port 4.
Old 05-23-2016, 01:33 PM   #19 (permalink)
So I went ahead and soldered the Jeti receiver jumper to the interlink controller and now I'm getting movement with my Jeti. One thing I can't seem to figure out is why I cannot lift off, it just spools up. I can see everything moving correctly. Below are my setting for tx and RF.
Servo Assign:
1 Throttle
2 Roll
3 Elevator
4 Pitch
5 Yaw
RF Channels:
1 Throttle
2 Aileron
3 Elevator
4 Blank
5 Rudder
6 Flaps
7 Smoke
8 Mode
I have enabled software and dual rates unchecked. When I check them I get no spool but movement.
