Old 10-11-2014, 01:22 PM   #21 (permalink)
Originally Posted by Xrayted View Post
My update went without incident, other than getting a message that my LCD update failed. The screen on the LCD says it has 4.05FW, so obviously it didn't fail. I seem to remember a bug that was similar in past updates, where some would get an errant failed message, so make sure you check before chasing an issue that isn't real.
Its nice to not have the SK software opening up in a tiny box for me anymore
=] no need to consolidate sticky this one. delete V4 sticky now? Thanks!
Old 10-11-2014, 01:26 PM   #22 (permalink)
Originally Posted by anthony1 View Post
well managed to sort out the second one and now the third one is also misbehaving, when I confirm that I want to update I don't get the green and red flashing light, just solid red , when it works its green and red alternating......so 3 for 3
Anthony
=] Anthony, are we back to that forget the SW update prompt and only use the utility update menu?
Old 10-11-2014, 01:50 PM   #23 (permalink)
Sure, whatever you think needs to be done
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is online now        Reply With Quote Quick reply to this message
Old 10-11-2014, 02:56 PM   #24 (permalink)
only had the sk update prompt once , been using the update utility , I have all 3 working now so no big deal but I've never had a problem updating so if anyone else has the same problem maybe they could sort it out using the method I did.
Anthony
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 03:05 PM   #25 (permalink)
Anthony:
The cause of that problem is that win 8.1 throws data at the sk540 faster than it can save it. My guess is that the sk540's flash memory is a bit faster after you reformat it with the bind plug trick. We mostly solved that issue by rev 4.02 by slowing down the write, but it sounds like it should be a bit slower yet. It might be a good idea to just format an sk540 from the utility menu before updating.
Skookum is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 03:32 PM   #26 (permalink)
Default 4.05 is up!!!! + Release Notes READ!!
Originally Posted by Skookum View Post
Re the "new version of the R7003SB" not needing a resistor, I haven't tested that myself but I hope it's true.
What are the symptoms to look for to test on the bench?
I have a R7008SB RX on hand but my understanding was this issue only affected early version of R7003SB never the 8
You can install the new software on your pc and skip the firmware for now, if you prefer.
Will do
* Goblin 700C, iKON, Torq 9180/9188, Quantum 4530-500, Edge HV160, Cyclone 695
* Outrage Fusion 50, SK-540, Torq 9180/9188, Quantum 4135-530, Edge HV80, SAB 630 Blk 3D
* Align T-Rex 500E DFC, SK-540, ICE 75
* Futaba 14SG
Arcturus97 is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 03:39 PM   #27 (permalink)
Re whether you need a pull-down resistor for sbus2: "What are the symptoms to look for to test on the bench?"
There aren't any. It mostly works ok anyways. But if you look at it on an oscilloscope, the logic-low level is almost 1v, where the usual standard is around 0.7 v max. So it's floating on the edge of not working. Futaba seemed to expect the other side to have a fairly strong pull-down R.
Old 10-11-2014, 05:34 PM   #28 (permalink)
=] but seriously who fits an unspecified resistor to a RF cable?
Old 10-11-2014, 06:27 PM   #29 (permalink)
This guy probably would.
YS Powered Rave ENV Stretch Protos 500, Stretch Mini Protos, 180 Trio
gitbse is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 07:13 PM   #30 (permalink)
=] yeah, DSMXZzzzzz faaaaaaaastest X4098 bus requires a user component fit,,,,,
Old 10-11-2014, 07:22 PM   #31 (permalink)
Hey Guys,
Just updated the SK540 to 4.05 and I'm having the issue with the reversed tail servo??
Is there a work around?
Regards
Argy
Argy
MSH Protos Max V2, Synergy E7SE, Synergy E5, MA Furion 6 as night flyer, Fusion 50 as 550, Protos 500 Stretch
Argypak is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 07:29 PM   #32 (permalink)
Originally Posted by Argypak View Post
Hey Guys,
Regards
Argy
=] input manually,,,,,,,
Old 10-11-2014, 07:56 PM   #33 (permalink)
yes I've done that and it works, but, the notes said that this was fixed?
Argy
Old 10-11-2014, 08:54 PM   #34 (permalink)
Default Updated to 4.05
Don't think there is anything in the new update that will benefit me and my G770 but I did update to 4.05.
It went perfectly with no issues.
Thanks!
Velos Rotors<<SAB<<Compas<<Align<<Walkera <<Propel
A VIKING is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 09:27 PM   #35 (permalink)
With no changes to the flight characteristics no need to upgrade....
Jeti DS-16, Oxy 3, Goblin 380, 500, 630, and 700 competition, Airwolf 600 scale heli, Brain/Ikon 2, Spartan VX1e, Sk 720, YGE and Hobbywing.
Shogun71 is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 10:09 PM   #36 (permalink)
Maybe something about your tail IS backwards?
For what it is worth, it is fixed for me on three different helicopters and using two different transmitters.
SpeedTape is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 10:53 PM   #37 (permalink)
Its a SK540 on a Mini Protos with a Futaba S9257 Tail Servo. Using JR DSM2 satellite on a DX8. I have tried reversing the servo in the transmitter with the same issue. Tail servo is on the left side of the heli with the ball mounted on a wheel. The ball is at the top of the wheel.
Worked fine on 3.42.
Anyway I have a workaround for now...
Argy
Old 10-12-2014, 05:00 AM   #38 (permalink)
my dsmx has been working all along so I guess I will hold off updating. I hope to get out for a few flights today on the E5.
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 10-12-2014, 01:01 PM   #39 (permalink)
Thanks!
There was an gift there for me.
I see that all my issues in playback were corrected so now everything is 100% for me.
Thanks Art!!
Old 10-12-2014, 06:34 PM   #40 (permalink)
I just updated my 2nd one tonight on my goblin 500 and when I updated one yesterday I don't remember it being 4.15, isn't it 4.05? Everything seems to be working fine, I haven't test flown it yet. Going first thing tomorrow.
HELIDIRECT - HOBBYWING - XNOVA - XPERT - PULSE - ROTOR TECH
Colin Broughton is offline        Reply With Quote Quick reply to this message
