Like Tree3Likes
Old 04-07-2014, 12:15 PM   #441 (permalink)
Originally Posted by Fooferdoggie View Post
so they don't come with gorilla gear? The bigger ball links were rubbing on the posts so that was another reason to move them forward.
They do come with gorilla gear skids, the same as for the 450 pro, they are even named 450pro on the MSH website.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 02:26 PM   #442 (permalink)
the cost is vastly different though gorilla gear are around 18.00 the align are 4.50
Fooferdoggie is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 02:39 PM   #443 (permalink)
Oh yeah, I thought they were all gorilla gear
I admit the gorila gear are really tough (I have yet to break any, though I'd like the black ones to break so I have an excuse to buy some colored ones ), and flexes nicely when needed which absorbs some impact force.
Not sure about the align ones as I've never had them.
Old 04-07-2014, 04:55 PM   #444 (permalink)
they do bend but they can stay bent too. had a set with the pipes on my x3 I had two crashes and they were bent where the are past the frame so they might as well be broken as they sagged so much. so there is good and bad with unbreakable skids.
Old 04-08-2014, 01:31 AM   #445 (permalink)
It's easy to bend them back. Just throw them in hot water for a bit, stir and cook until done
Tom
RCHN#233 | Lynx Heli Innovations Team
Goblin 700
Carbon |
Protos Max | Goblin 570
baui2000 is offline        Reply With Quote Quick reply to this message
Old 04-08-2014, 12:09 PM   #446 (permalink)
I will try that with one i have that is really gummy at the moment.
will let you know if it worked.
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 04:19 AM   #447 (permalink)
Nice Mini-P Foofer! Is that a 3S or 6S lipo?
thruster is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 01:57 PM   #448 (permalink)
Default 3-blade
Decided to try a little experiment. JR Forza 3-blade head on Mini Protos.
rablett is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 02:07 PM   #449 (permalink)
Ohhh that sure looks good, what is the length on those blades ?
Old 04-09-2014, 02:23 PM   #450 (permalink)
Niiiice! let us know how it works out! Were the swash and head a drop-in?
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 02:51 PM   #451 (permalink)
Definitely not a drop in. The servo configuration on the Forza is the opposite of the Mini Protos with the elevator servo in the back. So there's nowhere to put an anti-rotation bracket on the JR swash. So I fabricated an aluminum bracket and have the elevator pushrod in the front running up through a slot. I've only had time for a couple quick flights on it, one to track the blades which is more complicated and then the front belt pulley failed. So now I am waiting for parts to get it back in the air. So far, smooth and cool sounding but nothing to report regarding flight performance.
The JR blades are 325mm blades, very narrow (25mm) chord and thin airfoil.
Old 04-10-2014, 02:32 AM   #452 (permalink)
Woo! Unboxed my Mini P tonight. Can't wait for the electronics to start coming in so I can build it up.
First step, pull off all the Fususno stuff. Have a canopy, orange frames and fins, black skids and the whole flybarless setup to sell off. Hopefully I can use that to fund stock frames and canopy, and the yellow gorilla gear.
If any of you guys want this stuff, let me know! Since this is a picture thread:
Old 04-10-2014, 07:21 PM   #453 (permalink)
New Canopy from Lynx... What do you guys think?
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 07:25 PM   #454 (permalink)
hey you copied me the canopy works well.
Old 04-10-2014, 07:30 PM   #455 (permalink)
I did get almost all of the lynx stuff for mine too...
Boom band, servo mount, and fin... And the tail pitch bellcrank thing...
The boom supports too
Old 04-10-2014, 10:01 PM   #456 (permalink)
Default Share your Mini Protos Pictures and Videos!
Looks good (personally I am crazy for the original cano though, still). How does it fit the bigger-ish batteries? Have you flown the pitch lever yet? Big difference for me once I got it installed properly.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 10:10 PM   #457 (permalink)
My under the tree video is with the the new bell crank!
[ame]http://youtu.be/Vod4LzbnoCA[/ame]
I do like the stock canopy, but mine has suffered some damage, I continued to use it, but today the left side grommet finally broke off the little bit of fiberglass that was left holding it...
Old 04-10-2014, 11:52 PM   #458 (permalink)
I would be lucky if I could turn around in that space. to me it is work flying in a 100' space. I need bright colors I fly when it is gloomy too much and even bright colors can be dark.
Old 04-11-2014, 11:54 AM   #459 (permalink)
HF MR Support
Mini(s) and Max.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 01:25 PM   #460 (permalink)
That...is outrageous. Someday I hope to own something like that...then be too scared to ever fly it
