Old 07-27-2014, 04:27 PM   #121 (permalink)
I went I hard today. The bolt for the tail pitch lever backed out while In flight Took out the canopy (it has been crashed more than once), main blades, landing skid, tail fin, boom, and main shaft. Around $170 for the parts. I hope to have it back up midweek.
Lynx Team Test Pilot
Heli's :, Gaui X3, Logo 480,
Vbar Control
Lu523 is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 08:26 PM   #122 (permalink)
Sorry to hear that. Definitely one of those screws I use red locktite on.
Wayne
Logo 480 / Logo 600sx / Logo 690 / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 08:31 PM   #123 (permalink)
Sounds like good advice. I flew it earlier in the day so did not think to check that screw. It won't happen again.
Vbar Control
Old 07-30-2014, 04:30 AM   #124 (permalink)
Dda
Originally Posted by Lu523 View Post
To run the Vbar governor you need the Pro. The YGE esc has a governor function also.
So, either way, you need to spend money...
vBar : upgrade to Pro
YGE : buy the programming card
Correct or not?
Dda is offline        Reply With Quote Quick reply to this message
Old 07-30-2014, 04:46 AM   #125 (permalink)
Dda
Another question is...
I've set the YGE governor function on (via TX stick) and how could I disengage it? I bet I could fly without a governor, can I? What's the down side for not flying with governor?
Old 07-30-2014, 06:21 AM   #126 (permalink)
Sure you can fly without gov. A good gov. will just give you a consistent HS, & therefore consistent performance throughout the flight. I fly my 325s without a gov. function, and I don't really notice a difference throughout the flight.
I use the YGE gov. on all my bigger heli's, program card is a good investment.
Chase 360, Protos380x3, Goblin500,
Raptor E700 x2
JETI DS-16, SKOOKUM & YGE
rcnorth is offline        Reply With Quote Quick reply to this message
Old 07-30-2014, 07:06 AM   #127 (permalink)
Originally Posted by rimaarts View Post
i have a question... would yge80A esc be enough for this heli? after my next protos rekit (which considering my luck with it will be quite soon), i think about switching to logo...
I would be hesitant to use the 80A mainly because the BEC on the YGE 90 powerbec edition is a lot beefier. However, this would completely depend on what servos you installed on the Logo.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 07-30-2014, 11:32 AM   #128 (permalink)
Correct or not?
I thin you can do the programing by the TX sticks. It is a lot easier with the card.
Vbar Control
Old 07-31-2014, 12:26 AM   #129 (permalink)
Dda
Thanks for the advise.
Old 08-02-2014, 04:22 PM   #130 (permalink)
Name:	Screenshot 2014-08-02 17.09.24.jpg
Should the Vbar governor hold the head speed a bit better than this? Any tips for tweaking would be nice.
Vbar Control
Old 08-02-2014, 06:51 PM   #131 (permalink)
I am going to change the governor gain and see what I get.
Vbar Control
Old 08-14-2014, 07:48 PM   #132 (permalink)
Could someone share the tail settings for me? I am getting a bad kick on hard collective climbs. I have been playing with it, but not sure what to tweak.
Vbar Control
Old 08-16-2014, 07:39 PM   #133 (permalink)
Just a quick update. I got most of the kick taken care of. Still a bit on a full collective climb from a hover.
Vbar Control
Old 08-17-2014, 12:29 AM   #134 (permalink)
What did you change? Which way was the tail kicking?
logo 600sx, 480, vcontrol ..mcpsbl
Dsss is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 08:39 AM   #135 (permalink)
Deadband: 5
Acceleration: 55
P Gain: 80
I Gain: 50
Stop Gain A: 20
Stop Gain B: 25
Torque Precomp:
Collective: 22
Cyclic: 9
That is where I am at now. I did run the optimizer again.It kicks a bit to the right. To start it looked like a bit to the left then hard right.
Vbar Control
Old 09-06-2014, 04:15 PM   #136 (permalink)
I finally got the tail dialed in good. I noticed a tick in the tail area. I am not sure if it the belt or where.
Tick on 480 (0 min 37 sec)
It can be heard at the start and again around 19 seconds.
Vbar Control
Old 09-06-2014, 05:31 PM   #137 (permalink)
if i had to guess the belt is loose? kinda hard to tell from the video.
Also on the kick issue how much pitch are you running? 0 at mid stick?
What tail servo?
Disconnect tail servo link and make sure its all smooth as butter.
Old 09-06-2014, 07:07 PM   #138 (permalink)
It could be a loose belt. I can pinch it from the top and bottom of the tail box and get it to touch. It does not do it all the time. That is what gets me.
As for the tail I am running the Savox SH-19MG. 0 at mid stick with 13 degrees. I have the tail so smooth that the if I fold the blades they will fall under their own weight.
Vbar Control
Old 09-06-2014, 08:15 PM   #139 (permalink)
That seems pretty loose.
I am not familiar with that servo.
Old 09-06-2014, 08:33 PM   #140 (permalink)
I will tighten it up some. I made a typo on the servo, it is a SG-1290MG.
Thanks for all your help
Vbar Control
