Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G6 / V120 Series
4G6 / V120 Series Walkera 4G6 / V120 Series Helicopter Support
Old 07-02-2014, 01:44 PM   #1 (permalink)
Default Main Gear Pin .
I have changed Main/Tail gears numerous times throughout my V120 ownership going back to orginal V120d02. It is simple process. However with my V120D02 V2 the pin looks shorter and its a super time fit on Main Gear. I used to be able to push out the pin and take off the main gear. Mines is so tight I can't take it off.
Anyone had this problem or did I get a bad one from factory?
Is there easier way to take off the pins from Main Gear and Rotorhead? I use to use a small pliers and pull it out but seems V2 has a much tighter fit.
torch8 is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 10:57 AM   #2 (permalink)
This can be really challenging. I have had luck using a pair of pliers and "pinching" one side of the pin while resting the other jaw of the pliers on the hub/inner most part of the black plastic main gear. This can move the pin a bit and hopefully get you going to be able to remove it fully. After getting it out, I've used a grinder to tapper one end of the pin before replacing it-to make insertion and removal easier in the future.
Hope that helps!
-b
Flying > Crashing
(well, I'm working on it...)
KDS Chase 360, Gaui X3L 3 blade head & tail, KDS Agile 7.2, Spektrum DX8g2. Citizen 740.
heli-b is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 05:23 PM   #3 (permalink)
some of them are just really tight torch8, heli-b has the right idea, a pair of pliers really helps, but even then some of them are a pita.
Rockin' the world and flying... that's where i live..
oxide1 is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 06:51 PM   #4 (permalink)
Thanks i still cant take it off but good news it still flies well!
Old 08-12-2014, 06:34 AM   #5 (permalink)
I sometimes had this problem with new main gears. The plastic wears in a bit over time but that bloody pin can be the bane of your existence. I broke a main gear hub trying to get one out once. Now I have a couple that fit nicely but I've gone through several. When you do find one that fits nice don't lose it. You could also try getting some piano wire that size and making one that fits better, or if possible sand the tight one a little if you ever get it out.
There was a thread on here a while back about using different metals to make a sheer pin to keep the tail gear from stripping out in a crash.
Devo 10 with Deviation Firmware (One to rule them all!).
| Compass ATOM 500 Flagship | V120D02S an X-treme kit and a stocker, MSRX - RKH and a stock | CopterX 450 Pro
geckgo is offline        Reply With Quote Quick reply to this message
