Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Old 11-29-2012, 04:47 PM   #1 (permalink)
Default My HC3sX and DX8 setup
I have numerous posts all over different threads regarding DX8 setup and it's hard for new people to get all info in one place; so in this thread I'll try to consolidate the information.
During my research, I found this helpful site:
http://www.myyosemite.com/logo-500se...-dx8-build-log
Download Danny's pdf file from the top of that page.
I've found out that just follow HC3sX new wizard and check Danny's instructions along the steps are enough for most people to setup a new HC3sX installation.
On my DX8, I physically switched Gear and Trainer switches.
Check post #24 here on how to open up your DX8:
https://www.helifreak.com/showthread...=254430&page=3
You only need to follow the first few steps to open it, then swap the switches, no wires cutting or soldering needed.
TIP: if you don't have a spanner type screwdriver, one easy way to open the switches: use a small flat screwdriver to hold the screw from outside, then use the other hand, hold and twist the switch from inside to loosen the screw. After that, it should be real easy to turn the screw.
Attached is my DX8 settings, with Trainer button as Captain Rescue and Rudder switch controlling flight modes.
File Type: pdf HC3sX & DX8 Setup v1.4 by FastRunner.pdf (252.9 KB, 3741 views)
Blade mCPX | TRex 550e | TRex 500DFC | DX8
Helix G700 17T, HC3sX, CY F270, GV1/SG, Century V2, Generator
FastRunner is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 04:49 PM   #2 (permalink)
Sticky!
Need more of these type of posts it's a pain searching for info.
Ian
7HV ULT TracX | 550U TracX | DX9
NZ Heli thread - https://www.helifreak.com/showthread.php?t=480630
Magnazan is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 07:11 PM   #3 (permalink)
I've requested this to be added as a sticky...
Team - "Self Interests" -
Old 11-30-2012, 08:10 AM   #4 (permalink)
I'm so glad this got sticky'd. Have a dx8 and hc3-sx on the way.
Great work FastRunner, thanks for doing all the figuring out and sharing it.
Khalil N.
Seaview Rotary Wings, Brooklyn NY.
nuroo is offline        Reply With Quote Quick reply to this message
Old 11-30-2012, 12:04 PM   #5 (permalink)
U R all welcome!
I hated bench time so the faster this helps people getting out in the field, the better.
Fly safe and remember to practice using CR every flight to train your reflexes.
...and thanks to Josh again, our officially nominated and accepted Captron cheerleader
Old 11-30-2012, 12:31 PM   #6 (permalink)
Originally Posted by FastRunner View Post
... our officially nominated and accepted Captron cheerleader
Hmmm... Not sure how to accept that?!
Only kidding folks. I don't lose any sleep over labels, just happy to help if/when I have anything of value to contribute.
Great job in providing this info, FastRunner!!
Old 12-09-2012, 11:58 AM   #7 (permalink)
I just finally have my inital setup in the HC3sX and will maiden when the wind stops, doesn't look like today. I have a problem after setting up the HC unit I went back and setup the CC75A throttle endpoints and they are different than before and now the throttle is still active in TH. Do I just need to redo the throttle setup?
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 11:59 AM   #8 (permalink)
Blades don't change pitch either in TH.
~Jim~
Old 12-09-2012, 12:13 PM   #9 (permalink)
I found the solution, just a noob mistake. I had to go to the F-MODE setup and set Hold to Hold. LOL makes sense. I'll have to remember that one.
~Jim~
Old 12-18-2012, 07:39 AM   #10 (permalink)
Few questions
Just setting up in Rigid Mode, till tuning is complete.
Goblin 630
HC3SX – Solid Red Light, I was expecting it to be Amber.
Tx
Rudd D/R in the 0 position-----For tuning, I’m guessing that this stays in the 0 position.
Flap Gyro in the 0 position
Below are my settings.
HC3SX RC page
Aileron : CH2
Elevator: CH3
c.pitch: CH6
Tail: CH4
Throttle/BEC: CH1
Output 2: 0
Tail gyro: CH5
Head gyro: CH7
DX8 System > Switch Select
Trainer: Inh
Mix: Inh
F Mode: Inh
Gyro: Inh
Gov: Inh
L Trim: Gyro
R Trim: Gov
Knob: Inh
DX8 > Function List
Gyro
Gyro (Control Tail Gain)
Use Gyro switch + L Trim button + Gyro menu to tune tail gain.
Pos 0: 50%
Pos 1: 50%
Pos 2: 50%
Ch: Gear (CH 5)
Sw: Gyro
Governor
Governor (control Horizon Gain or HC3sX modes)
In Rigid mode (no self-level/bailout), use Rudder switch + R Trim button + Gov menu to tune gain.
After switching to Horizon mode, Rudder switch controls flight modes.
Pos 0: 0% -Normal flight
Pos 1: 60% -self-level
Pos 2: -100% -Captain Rescue
Ch: Aux 2 (CH 7)
Sw: Rud D/R
Praztek is offline        Reply With Quote Quick reply to this message
Old 12-18-2012, 08:01 AM   #11 (permalink)
From what I understand you need at least 20% on both the head and tail gains or the light stays red.
Recommendation (EDIT; for initial flight) is that the gains be set at 50% in you tx which you can control via your trim tabs in your setup.
~Jim~
Old 12-18-2012, 09:32 AM   #12 (permalink)
Ok, I now have 50% in Gov Menu - Pos 0
Amber light is on !
When I'm in the gyro menu, and moving the L trim button , should I be seeing the numbers change on the Dx8 screen ?
Same goes for the Gov menu, but using the R trim button.
Tail gyro gain can be tuned using L Trim button and Gyro menu
Governor gain can be tuned using Rudder switch + R Trim button + Gov menu
Thank You
Old 12-18-2012, 10:08 AM   #13 (permalink)
Better choice of screens is in the model screen click your roller and roll to the very bottom and select the monitor screen. Look at the monitor and push your L-trim and see which one moves that should be your tail gain. The R-trim should be controlling your head gain.
Don't have my tx handy as I'm at work. When flying have the tx screen on this view that way you can see what your doing.
~Jim~
Old 12-18-2012, 10:37 AM   #14 (permalink)
In the monitor screen, L or R trim buttons don't change anything, sure there's something I'm missing.
Old 12-18-2012, 11:49 AM   #15 (permalink)
I received my setup from taosgraveyard, the tail gain is on the knob and the head is on the R-trim.
It would be easy to switch the knob to L-trim (setting couldn't be bumped off as easily as the knob) and I've been considering doing it, I just have other fish to fry right now.
I can send the set up to you this evening. I'm still new back to RC after 30+ year absence, so the computer tx and the HC programming is new and a big learning curve. I have mine set up and if functions just fine, I just maidened mine Sunday afternoon and had some tail bearing issues which I solved and flew it again last evening for about 5 minutes and still trying to get the tail gain right, I put in fastrunner's initial settings last night as some of my gains were making it too quick.
I can't fly again until probably Saturday, its suppose to snow 3-6" tomorrow and tomorrow night and then be windy the next two days.
I'll post the settings that I used.
~Jim~
Old 12-18-2012, 11:56 AM   #16 (permalink)
Yeah, I'm not sure why the L or R trim buttons are not working.
On the power on screen , when pressing either , LT displays on the top left, and RT on the top left.
Old 12-18-2012, 12:58 PM   #17 (permalink)
click the roller and then use the roller to scroll down to the monitor screen and click it then see if the Ger and the Gov channels are moving when your clicking the R-trim or the L-trim tabs.
Not on the initial model (power on) screen.
~Jim~
Old 12-18-2012, 01:27 PM   #18 (permalink)
They don't move on the monitor menue either.
Originally Posted by KSHeli View Post
click the r
Old 12-18-2012, 01:51 PM   #19 (permalink)
I just created a new model with these settings , the L and R trim buttons are working correctly.
I'll complete the setup and rebind, and see what happens.
Old 12-18-2012, 02:23 PM   #20 (permalink)
Figured it out.
In System Setup > Trim Setup
I had all of the following as seen in the picture set to 0, when changing it back to the default of 5, the buttons now work. I saw an online video of the dx8 setup for heli, and they set them all to 0, which is why I did.
Should I just leave them all at 5 ?
Thanks Again
