450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-05-2012, 11:23 PM | #1 (permalink) |
Setting up 450 pro v2
Quick setup question:
I received my swash leveler today and decided to go ahead and redo my setup. The problem is, no matter how perfect I get it, I always end up with a considerable amount of aft drifting. It is almost as if the COG is off. I have slid the battery forward as far as it will go. Have any of you chopper folks experienced similar? Btw, I had my first "incident" today. It was more like a violent explosion as I nailed the raspberry wire in the garden. Fortunately only a main shaft, flybar rod and main rotors. Pretty impressive considering. |
04-06-2012, 12:07 AM | #2 (permalink) |
Are you getting a good level swash at full high and low stick?
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC DX8 |
04-06-2012, 12:36 AM | #3 (permalink) |
Did you adjust the servo horns so that they are perpendicular to the main shaft @ mid stick?
- 6S TREX 450 Pro FBL - µBeast, MKS, Castle Creations - Goblin 500 - Kontronik Pyro 600-12, Jive 100lv, iKon, BK servos - TBS Discovery - Pixhawk - Spektrum DX7 |
04-06-2012, 08:09 AM | #4 (permalink) |
Yes to all the above. Used a step-by-step guide. Using a Trueblood swash leveler also. The only thing I can think of is my head geometry is slightly off. The mixing arms do not sit parallel. I think the servo links are too long even though I have set them to the recommended length.
04-06-2012, 04:11 PM | #5 (permalink) |
Reading your first post, i assume you are running 3gx Nothing to do with setup. Take a look in the 3gx forum... You're certainly not the only one. I hope you're one of the few who are able to solve it.
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6 |
04-06-2012, 08:30 PM | #6 (permalink) |
No. Flybarred.
04-06-2012, 10:09 PM | #7 (permalink) | |
All begins (Jun 2011)....... Next project: MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad |
04-07-2012, 12:21 AM | #8 (permalink) |
Servo links are all the same length.
04-07-2012, 10:35 AM | #9 (permalink) |
Have you watched the finless 450 build videos? He changes his link lengths from what the manual says they should be. (shortened I think)
I am currently building my first 450 pro v2 FB. And am about to be at the same point as you. Gatta re-watch those vids myself.
Blade 130x Align 250 Pro Align 450 Pro V2 w/ VBAR Align 600n w/ IKON DX8 Last edited by KableGuy; 04-07-2012 at 10:36 AM.. Reason: Rtard |
04-07-2012, 10:58 AM | #10 (permalink) |
Unfortunately I am unable to view those videos because of my Internet situation. The shortened swash links makes sense. I am planning on adjusting those first to level out the mixing arms, then finishing up with the grip links to ensure 0* at midstick. This also should correct the difference in + and - collective. Level swash goes without saying.
