Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 05-30-2011, 11:05 AM   #1 (permalink)
Default X5 Canopy fits on a 425/550?
Hello, fits a Gaui X5 Canopy on a 452/550?
Got anybody Picture to see how it looks?
Sry for my bad englisch, german guy here
icepick is offline        Reply With Quote Quick reply to this message
Old 05-30-2011, 06:20 PM   #2 (permalink)
HF MR Support
Default 425/500/550
Here is a photo of my "550" with a TRex 550E canopy on it...Trimmed to fit and can run any size Batteries I have.
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 05-31-2011, 02:09 PM   #3 (permalink)
Thanky for Photo, but I dont like the 550 Trex Canopy. The Trex 600 Nitro Looks better on the Gaui 550
But i wont to know, fits the X5 Canopy on the Gaui. I want to by a Canomod X5 Canopy for my Gaui 425
Old 06-01-2011, 12:54 AM   #4 (permalink)
I have an x5 on the way. Ill drop the canopy onto my plastic and cf 550's to see how it goes and post a pic.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 06-01-2011, 10:49 AM   #5 (permalink)
awesome, cant wait to see it
Old 06-04-2011, 05:44 AM   #6 (permalink)
Hi nexgen, you get the X5 Canopy? cant wait of the result
Old 06-04-2011, 01:24 PM   #7 (permalink)
yup, got it. I'll do it when I get home tonight (im at work) and post a pic
Old 06-04-2011, 08:51 PM   #8 (permalink)
i kinda like the new X5 Lite canopy...would be cool if that would fit
Harder, Faster, Louder.....works for Me !
Brick is offline        Reply With Quote Quick reply to this message
Old 06-05-2011, 09:17 PM   #9 (permalink)
I'd like to know myself.
Blade 230s
esa3 is offline        Reply With Quote Quick reply to this message
Old 06-05-2011, 10:38 PM   #10 (permalink)
ok so heres the X5 canopy on my cf 550. I have to say it looks pretty good on there! The size is good, not too big not too small, it takes up roughly the same volume as the stock canopy, just in a different shape; taller instead of longer. the top of the canopy allows for venting on the motor, which is something that many, including myself were already doing to our stock canopies to keep the motor cooler. I can fit my 6s 3300 under there easier than with the stock one as there is more room because of the shape. the front portion of the battery touches the canopy as it is now, but the mounting adjustments below may fix that. On the plastic frame, it looks like it will still be a tight fit at the front of the battery when trying a 6s up on top, 3x3 up and down packs may fit better on this frame. heres the catch tho, the bottom..... The bottom of the canopy is an open design which, on the 425/550 is where the second mount point is typically located. It looks like you may be able to carefully mimic the 2 stage canopy post setup of the X5 using the X5 canopy posts, and dremeling a couple holes on the frames close to the front servo mounting locations. If you did this then the bottom being open would be irrelevant. Actually having the bottom open can help cool the esc if you have it under there like I do, or in the case of the plastic fantastic, running all 6 cells under-slung would be much easier as the opening would allow for more battery flexibility.
thumbs are clickable
Old 06-05-2011, 11:01 PM   #11 (permalink)
Looks great, Thank you.
Blade 230s
Old 06-05-2011, 11:16 PM   #12 (permalink)
thank you verry much. The size of the canopy looks like the same as the original from the gaui 425, or is theere moore room in the X5 Canopy for larger Lipos?
Old 06-07-2011, 03:48 PM   #13 (permalink)
Hi icepick
Originally Posted by nexgen View Post
...I can fit my 6s 3300 under there easier than with the stock one as there is more room because of the shape. the front portion of the battery touches the canopy as it is now, but the mounting adjustments below may fix that....
Frank M
ncc1701 is offline        Reply With Quote Quick reply to this message
Old 07-05-2011, 11:20 PM   #14 (permalink)
Default x5 canope
wow I really like the x5's canope too- was thinking of getting one also. I finally got my 425 setup the way I want it and this would just complete my make over sweet! thanks fellas
mightymouse is offline        Reply With Quote Quick reply to this message
Old 07-15-2011, 03:39 PM   #15 (permalink)
Hi nexgen, is there a way to fix the canopy on a plasticframe with all 4 mounting holes from the canopy?
I know i must fix 2 additional holder for the canopy on the frame in the front. Ist there a place for the holder to fix it or there are the holes from the servos or others mayby block to fix the holder on the frame?
Old 07-23-2011, 07:41 PM   #16 (permalink)
I ordered the X5 canopy- just gotta play the waiting game to get here ,when i get it i will post some pic's of it on my 425 and where and how I mount the posts
Old 07-24-2011, 12:33 PM   #17 (permalink)
Cool, cant wait of the report.
I want to buy a custom Fusono X5 Canopy
Old 07-26-2011, 11:08 PM   #18 (permalink)
Hi
I have the Gaui 425 and wasn't happy with the canopy so when I saw a secondhand X5 canopy on ebay I grabbed it for my 425.
It looks great if not just a tad too big. It also can move around a bit and I wouldn't want to go inverted with it as just may move up towards the blades too much. But easily fixed with some sort of mod to secure it better.
Regards,
Phil.
_______________________________________________
Lots of things that fly and crash!
FlyingFiz is offline        Reply With Quote Quick reply to this message
Old 07-27-2011, 11:15 AM   #19 (permalink)
thanks for report FlyingFiz, but we missed some pic´s
Old 07-31-2011, 10:48 AM   #20 (permalink)
Im Still waiting on mine - wish I would on read the small print up to 10 days before they ship --I flew my 425 yesterday aaah man I love this bird, just cant wait to put a new helmet on her !
