Like Tree1Likes
  • 1 Post By One_eye
Old 12-26-2013, 01:19 PM   #1 (permalink)
Default Motor for logo 600 sx
Hi guys,
I am building a logo 600 sx with all the electronic I got from my Fusion 50 but I can't use the align 600mx motor because the distance between screws is not 30, so I am looking for a motor.
The setup will be sab 620 main blades, vbar silverline, and with batteries I have two options, use my 3700 60c 6s Gens ace I use on my x5 or the batteries I used on the Fusion at the beginning (4000 60c and 4500 45c) 5s for a 10s setup.
So my options are the scorpion 560kv or the align 530kv 750mx.
What do you think could be better option?
My flying style is sport flight with some tick tocks and trying to improve. Also to mention is I plan to use vbar governor.
I guess better option it is 12s setup and I bought the 12t pinion.
Enviado desde mi Galaxy Nexus usando Tapatalk 2
Soxos Strike 7.1
Minicopter Diabolo 700 UL and 550
Mikado Logo 600SX
Gaui X3
Arag_ is offline        Reply With Quote Quick reply to this message
Old 12-26-2013, 01:37 PM   #2 (permalink)
I swapped out my scorpion 4035 560 for the savox 600 class 560kv motor this fall and have not put the scorpion back in yet. The savox is a lot lighter and has almost as much power as the scorpion. The weight difference is noticeable in the air. You only really notice if you load the head for a long period. The savox is cheaper too. I have ran several different motors in the logo over the years and I think the savox will stay for awhile.
HeathH is offline        Reply With Quote Quick reply to this message
Old 12-26-2013, 02:25 PM   #3 (permalink)
But the 4035 has 25mm between screws, and the motor mount of the 600sx only admit 30mm distance between screws.
That was the reason I discard that motor.
By the way there is also the 700 class that looks pretty good too, the 5065 530kv.
Soxos Strike 7.1
Mikado Logo 600SX
Gaui X3
Old 12-26-2013, 03:19 PM   #4 (permalink)
http://www.ercmarket.com/counterbear...-mik-4148.html
http://www.ercmarket.com/metal-motor...-mik-4088.html
Unfortunately you won't be able to use the 3rd bearing plate, but you wouldn't need it with that motor anyway. You can shim the bottom of the main shaft with washers or a clamp ring MIK2385.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 12-26-2013, 06:25 PM   #5 (permalink)
they sell 2 motor mounts , one with 25 mm the other with 30 mm spacing , as ive had both on my 600 se..
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 12-30-2013, 12:42 PM   #6 (permalink)
The savox I have is 30 mm spacing.
Sent from my SCH-I545 using Tapatalk
Old 12-30-2013, 11:13 PM   #7 (permalink)
450-500 kV is better suited to 12s. The higher kV motors you suggested can work with an 11T and (likely) reduced throttle curves.
700L SXTS Neo | Goblin 700 KSE Neo | Goblin 380 KSE miniVBar | Nano QX
rando is offline        Reply With Quote Quick reply to this message
Old 12-31-2013, 05:38 AM   #8 (permalink)
Thanks a lot guys.
Finally I got the Scorpion 4035-560kv and will use with the 11T pinnion.
Soxos Strike 7.1
Mikado Logo 600SX
Gaui X3
Old 01-02-2014, 03:08 PM   #9 (permalink)
I'm running an Align 750. Fit perfectly and is 6g lighter than the 4035. Haven't had a second's worth of troubles.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 01-06-2014, 08:51 AM   #10 (permalink)
I have 2 logo 600sx, one with an Align 750mx 450kv and one with pyro 52L-450kv on 13T on 12S 3300 to 3700. Both motor fly great.
joecass2 likes this.
One_eye is offline        Reply With Quote Quick reply to this message
Old 01-06-2014, 10:30 AM   #11 (permalink)
The 750MX isn't too hard on the gearing? What esc/gov are you using?
maarset is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 05:00 AM   #12 (permalink)
I have a Logo 600sx with:
CC 80A / 10s / 560kv / 12T pinion
With this setup, I can't get governed well at 2200rpm, with 2100 it runs well with no headspeed drops.
To be well governed at 2200 or a little bit more, you can choose one of these setups:
1) 10s / ~600kv / 12T
2) 12s / 560kv / 11T
nivaldin is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 10:28 AM   #13 (permalink)
Or
3) Use an external governor (VBar, etc), if you have it
