Old 03-18-2013, 05:10 PM   #1 (permalink)
Default TT bearings
How many TT bearing are you guys using inside the tube. I had purchased a 600 kit that had part taken out if it. Im building it now and only have one bearing for the TT shaft. Should I add another? Thanks
Trex 700l Dominator. Microbeast
Futaba 10j Tx
Icharger 406Duo
chambers is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 05:24 PM   #2 (permalink)
Default Re: TT bearings
Have always used 1 on my 600 without any trouble
Sent from my DROID RAZR using Tapatalk 2
Trex 500 ESP(DFC) Ikon, Radix] [Goblin 700 CompBK, 4525, Ikon, Helix 695 ] [Rave ENV Nitro O.S 105-R,Ikon,Cyclone] Rave ENV Electric]Scorpion 4525,Ikon, Outrage, SAB [Goblin 500] Ikon Rails 516 ]Blade 180 CFX]Goblin 570 12S Xnova
Blade120 is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 05:30 PM   #3 (permalink)
Thank you
Futaba 10j Tx
Icharger 406Duo
Old 03-26-2013, 07:27 AM   #4 (permalink)
I've been on a quest to smooth out my 600 as much as possible. I recently had mine apart to check all the bearings. I found that my TT now had a slight wobble in it which was causing some vibration. I decided to add more "support" points to the TT to keep the new one from deforming overtime. I have 3 TT bearings in it now.
Mike A. is offline        Reply With Quote Quick reply to this message
Old 03-26-2013, 08:20 PM   #5 (permalink)
Thanks Mike, I had read your post about the vibe problem so since then I added another one to the TT. The kit I have was actually a nitro. I converted it to electric. Im almost done with the build now, just waiting on the tail servo and a few other little things.
Futaba 10j Tx
Icharger 406Duo
Old 03-26-2013, 10:54 PM   #6 (permalink)
I wonder if part of your vibration problem was that you didn't properly place your TT bearing. It says to mount fwd of the center point 5-7 cm. I didn't read the thread and may have been discussed, but that is something that comes to mind.
Just remember one thing, the more bearings you put in it, the more resistance you are creating. Also more chances for bearing seizure.
Trex 700L Ikon 2 / Trex 700L Ikon V. 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2
It isn't about if, it is about when!
Old 03-27-2013, 12:39 PM   #7 (permalink)
Ive been running one TT bearing for years without any issues..
Team Align
flyinghigh450 is offline        Reply With Quote Quick reply to this message
Old 09-16-2013, 12:14 PM   #8 (permalink)
Mine has always been fine with one
Kcaj is offline        Reply With Quote Quick reply to this message
Old 09-16-2013, 05:32 PM   #9 (permalink)
+1.
The system is designed for one bearing, properly placed.
The offset location of the bearing along the shaft is critical to avoid a harmonic vibration.
The added drag from extra bearings will impact your auto-rotation capability.
TREX 600ESP, Outrage G5, mCPX, CX3
Phoenix Sim - Mastering flight one crash at a time.
Cheetah62 is offline        Reply With Quote Quick reply to this message
Old 09-16-2013, 05:52 PM   #10 (permalink)
After about 300 flights I started getting some bad vibrations, turned out the TT started bending on its own. I hadn't crash it. That is why I added extra. There is very little resistance on those bearings.
Old 09-19-2013, 11:04 PM   #11 (permalink)
Exactly what I was thinking.
