Like Tree4Likes
Old 12-17-2007, 08:27 PM   #161 (permalink)
but what pakcs are you going with,
don't know if u know anything about thunder power, but will the TP 22.2v 2200 mAh packs fit and work??? :0
spencer737 is offline        Reply With Quote Quick reply to this message
Old 12-17-2007, 08:30 PM   #162 (permalink)
Team Taco VP
Yes those should work fine.
I am going to be using 6S 2500ma FlightPower packs.
Bob
Old 12-17-2007, 09:16 PM   #163 (permalink)
just a quick question what does the manual say for. "tools needed"
Old 12-18-2007, 06:01 AM   #164 (permalink)
Someone PMd me for the part numbers for the DuBro hrons.
So I looked them up. According to the Tower page, the LONG ones (Part Num 672) have holes at 15 mm for the Short and Medium horns, and the Normal ones (Part Num 675) have holes at 16mm for the Long, Dual and Triple horns.
I am home sick, so I should be able to check them again, if my brain allows me to remember.
OK, I checked, BUT sets of horns have holes at what I measure at 16.25mm. The better ones for helis would be the #675 horns. The #672 horns are super heavy duty and more for Giant Scale types. Tower calls the #672 Long, but they are Super Heavy Duty.
The 675 set has two longer horns that will work, plus the double and triple arms ones that you can cut the extra amrs off. There are 4 short ones, that are too short.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 08:07 AM   #165 (permalink)
Only the Tail left to build right?
Tomorrow i get my T-rex 500 I cant wait for it.
PiccoZ06 is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 01:58 PM   #166 (permalink)
Hi bob,
Instead of using shoo goe, can I use a thin piece of hot glue ?
Cédric
Never Underestimate The Power Of Stupid People In Large Groups
jurassic5 is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 02:47 PM   #167 (permalink)
Team Taco CEO
Originally Posted by jurassic5 View Post
Hi bob,
Cédric
Hot glue stick to wires good but don't stick to shinny flat surface very well. Shoo goo stick to almost everything.
Kevin
Don't Taco My Pack, Bro! ,
Why crash when you can POUND it!
fireup is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 03:12 PM   #168 (permalink)
I went for a little piece of hot glue, like 1mm; should be fine
I got 5245MGs for the cyclic; seems the box is missing two spacer for the elevator servo. Maybe we don't need them.
In fact the spacers on the aileron servos are necessary cause both servos don't fit in the frame; we need to space them to make them fit.
The HS metal gear make a PERFECT 90° at middle stick.
Cédric
Old 12-19-2007, 04:33 PM   #169 (permalink)
What is Shoo Goo?
I guess it is some kind of universal glue, but does it have a more "international name"
that can be understood "on the other side of the pond" as well?
Peter
psindrup is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 04:34 PM   #170 (permalink)
Shoo goo is what I was using to put on my old vans when skateboarding This prevent from the grip to scratch your shoes
Cédric
Old 12-19-2007, 06:30 PM   #171 (permalink)
Team Taco VP
Yep... Align needs to put in another set of spacers for the HS5245 servos because the elevator ball link is not straight up and down. So now I gotta show how to make a set of spacers
If you cant find shoe goo then the best substitute is rubber or contact cement!
Bob
Old 12-19-2007, 09:18 PM   #172 (permalink)
bob, will a 450 size heli pitch gauge work on these blades? that's all i have but i doubt the 500 blades will fit easily. if i'll need another pitch gauge could you recommend one?
chuckk is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 09:50 PM   #173 (permalink)
Team Taco VP
Hmmm I dont know... I will see when I can and let ya know.
Old 12-19-2007, 10:31 PM   #174 (permalink)
If you have the align pitch gauge (that is the only small one I have) it will fit the 425 blades without any problems. I use it for my lepton.
Best Regards
Furron
MKS USA, Pulse Ultra, Canomod
wicked_n_raw is offline        Reply With Quote Quick reply to this message
Old 12-19-2007, 10:40 PM   #175 (permalink)
Team Taco VP
Yep just checked myself and you can use it.
Bob
Old 12-19-2007, 11:00 PM   #176 (permalink)
Originally Posted by psindrup View Post
What is Shoo Goo?
Peter
Builders adhesive (No Nails) or similar - which seems rubber based also works well
John
Old 12-20-2007, 04:57 AM   #177 (permalink)
Team Taco VP
Step 7A is up using HS-5245MG servos!
Finally I can move on
Bob
Old 12-20-2007, 05:08 AM   #178 (permalink)
Bob
Thanks so much again Bob!
Mikrokopter building photos and heli x-ray images: www.x-ray-heli.com
/ Blade mCX
/ Blade CX extreme / Hurricane 200 / Mini Titan E325 /
T-Rex 500 / Logo 500 3D / Trojan T-28 / Super Mini Cub / MPX Blizzard
Mikrokopter Cayman 500 /
Mr. Slumber is offline        Reply With Quote Quick reply to this message
Old 12-20-2007, 05:23 AM   #179 (permalink)
And nice long servo wires this time
(Almost reason enough to choose this servo over the other)
Peter
Old 12-20-2007, 07:46 AM   #180 (permalink)
Talking about the missing spacer trouble for the HS-5245-MG wouldn't these spacers fit?
http://www.readyheli.com/H60074_Carb...0_p/h60074.htm
What do you think?
/ Blade mCX
