Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
10-06-2014, 10:25 AM | #21 (permalink) | |
And on the subject of the Turnigy. yes it works as advertised.. Suggestion. TOTALLY REDO the BINDING FIRST, with NOTHING plugged in... Disconnect , then connect again. Disconnect. THEN, plug the servo leads to the Turnigy, connect again and set the first set of parameters ie speed etc of the servos to make sure you don't burn them up. Disconnect...THEN connect again and let the servo's center themselves... then continue the set up..
DJI MIni, XK K110 120, previously Protos 500, Goblin 570/700. |
10-07-2014, 12:06 PM | #22 (permalink) |
Hi guys,
I saw HarryR reposted my post from Rcgroups here. I'm also not an expert for the 3D-H, but as I went through the process recently... watho 46, do yourself a favor and grab the Beastx V3 manual. It is well written and covers everything you need to know. But you are talking about using a standard receiver. So, the light shouldn't be purple, but off. The 3D-H is by default set to accept standard receivers. This means you don't need to go through the receiver setup procedure at all. Best would be to just power up your receiver first (without servos or 3D-H), insert your bind plug and then switch on your radio and bind it with your receiver. After this, power down the receiver and make your connections: Just connect everything like it is shown in the manual. Orange (or white) wires up, brown (or black) wires down on the 3D-H. On the Spektrum receiver it should be the other way round. Dark cables on top. Don't be afraid to connect your servos before doing the setup. The 3D-H is at 50Hz (Analog) at factory default. Now just power up your radio and then your heli. For safety reasons you should disconnect the motor first. Let the 3D-H initialize. Then press the button on the 3D-H until the light for step A lights solid. Now go through all the setup steps according to the manual. Hope this helps... Edit: Found a picture showing the wiring with a Spektrum receiver: http://www.rcheliaddict.co.uk/attach...i-dsc02070.jpg
HK450 V2 FBL with Turnigy 3D-H v2 Blade mCP X, AXN Floater-Jet Radio: Spektrum DX6 | Simulator: Heli-X () |
10-11-2014, 05:22 PM | #23 (permalink) |
Hi guys
been watching some vids on the beastx https://www.youtube.com/watch?v=bkRw...FF891A&index=5 been great. Where I seem to get stuck is tx on power heli with the button pressed A flashes set main light to purple spectrum,press button briefly B flashes main light solid red, nothing, system freezes, on the vid he states main light will go blue but mine is a solid red have no idea what is going on, so I can't get into system menu until this is done ?? thanks again Cheers Watho
Master CP devo 7E Walkera 450 DO3 Blade 4503D conv to FBL Spectrum DX6i Building 550x and a phoenix sim fly,crash,order parts,repair and repeat |
10-11-2014, 05:37 PM | #24 (permalink) | |
10-12-2014, 05:01 PM | #25 (permalink) |
Hi guys
Well I tried the spectrum rx and also the orange dmx2 both where unsuccessful I have contacted HK to get them to check it out buggered if I know Thanks again for all your help Cheers watho
10-14-2014, 02:13 AM | #26 (permalink) |
watho 46: once again, are you trying to use a satellite receiver or a standard receiver?
Some posts go you clearly wrote about an AR6115, which is a standard receiver. When using this, you don't need to set nothing receiver-wise in your FBL unit. Just connect it and start programming...
10-16-2014, 02:50 AM | #27 (permalink) | |
Hi guys OK so I'm using a spectrum AR6115e everything is bond and plugedin set to spectrum rx unplug turn everything off, turn on tx and plug rx in get main light flashing red and other lights running from A to G, will not bind press button for short time main light goes solid red and small light goes to J ????? press button again and nothing ???? So START again red flashing small light running around press button main light blue and no other lights freeze unplug and try again we go back to first senerio ??? there is something missing or the unit is #***##" thanks again for any help but I think this might be a warranty job still waiting to hear from HK ????? cheers mark
10-17-2014, 01:42 PM | #28 (permalink) |
Watho, you don't need to set it to Spektrum as it is a so-called "standard receiver".
I'd recommend resetting (hold the button for more than 10 sec while in Setup Menu) the 3D-H to factory default and start from the beginning again. Just follow the Beast manual step by step. As you are using a standard receiver, you can start at chapter 6.
10-20-2014, 03:14 PM | #29 (permalink) |
Hi guys
Well where talking ( 3D-H) when reading and retreading the turnigy needed to be set to off as is the standard rx not purple as this is for spectrum sat Anyway all is good and I'm half way through the programming One thing I'm not sure of is the servos as I'm using some cheap digital servos from Rcmart and I'm unsure of frequencies and pulse rates ?? Can anyone give me some safe settings for this ?? Anyway thanks again for putting up with all my rants Cheers watho
10-20-2014, 03:28 PM | #30 (permalink) |
pix
Waltho.. here is something for you
10-20-2014, 05:14 PM | #31 (permalink) | |
http://www.beastx.com/deu/servoliste.php There is a translate button. This is the list of most of them. If they are not on there , you would need to talk with RCMart and see what they can tell you. If you can not find anything about them.. Use the red flashing or red for the cyclic..You will need a DECENTLY fast Tail Servo... you want you tail to be solid and the cyclics typically are not fast enough.
10-21-2014, 02:32 AM | #32 (permalink) |
Thanks again Harry masjo and others
Obviously the sat was where I was going wrong I have a look at the site and they aren't mentioned so I will have a talk to the boys at Rcmart, I'm so happy I have got this thing to work I have ordered another as they had them on the global site for $34 so I couldn't resist I also got 2 sats seeing I got it so cheappppp Your heli looks great it looks like you have the standard servos ??? Thanks so much for allll your patience hopefully will be flying in no time Cheers watho
10-21-2014, 10:20 AM | #33 (permalink) | |
You will love it. It flies just like the AR7200. Which sats did you buy??/ DMX I hope so you can run at 11 ms?? Yep, I have the OEM Servos but I have another upgrade set just in case .
10-22-2014, 02:40 PM | #34 (permalink) | |
Still haven't had time to get back to the bench to finish the settup work has just been mad The sat's in got where orange rx 100 dxm2 hope they will do the job on the next build ?? On the other hand is there some safe settings I can use for the not so expensive digital servos I have in the turnigy ??? Cheers watho
10-23-2014, 11:57 AM | #35 (permalink) | |
DMSX Sat
So I am suggesting you move to the DMSX version which runs at 11 ms if you want to plan for the future. The Spektrum version DMSX - NEW - is about 30 some dollars. You may want to do some reading and see what you want to plan.
10-28-2014, 06:19 AM | #36 (permalink) |
OK guys need help again
I have got everything working well but the servos I have will not work with the turnigy ???? Cheap I looked at putting the old blade servos back in but I found 1 or2 have striped gears BUGGER So I am asking for help again looking for some servos that won't blow the budget ?? Something from HK auz would be great as I won't have to wait a life time lol The tail servo seems good but I think I will replace all of them ( Thanks again for all the help Cheers watho We will be flying buy Xmas lol promise
10-28-2014, 06:27 AM | #37 (permalink) |
Watho I bought the HK939MG when I built my 5 bladed HK450V2. Don't know if they are in AUS warehouse. I haven't checked.
What componants you install and your flying skills is what make a good flying heli. |
10-28-2014, 10:01 AM | #38 (permalink) |
Watho, what means "servos will not work with the Turnigy"?
Which servos you have and how you found it out?
10-28-2014, 10:40 AM | #39 (permalink) | |
10-28-2014, 10:41 AM | #40 (permalink) | |
