Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
04-19-2010, 09:55 PM | #442 (permalink) |
Team Taco VP
YES!
Had I known that I would have gone 8V servos on the Velocity! Might have to upgrade Maybe I will go that route on the MA Fury 55 build coming up next Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
04-24-2010, 06:39 PM | #443 (permalink) |
lipo capable too?
just a little question, is the Sanwa RX-1011FS the same as the 10ch Airtronics receiver you wrote could be used with 2S lipo?
bjørn |
04-28-2010, 01:58 PM | #444 (permalink) |
Bob,
I have seen a reference to an SD-10G video showing a complete heli setup. Have you done this yet and can you provide a link? Thanks |
04-29-2010, 04:26 PM | #445 (permalink) |
Team Taco VP
Yes go look at my Pantera build vids and I am also doing it on the Velocity 50.
Bob
05-06-2010, 03:59 AM | #446 (permalink) |
Sanwa SD 10G Pitch reverse
Hi Bob
I am Felix from Germany and my englisch is not so good but maybe you can help me with my new Sanwa. I programmed my heli with instruction from your vids and it helpt me a lot the only problem i have is when a friend of mine would like to Fly my heli i have a problem to reverse the pitch stick. Please tell me how to do this Thanks Felix |
05-06-2010, 05:47 AM | #447 (permalink) |
Save the model memory to another slot in the radio, reverse the slave setting for Pitch in the SWH menu and then reverse the throttle servo in the Surface menu and reset the throttle endpoints and you should be good to go.
TM |
05-08-2010, 09:02 AM | #448 (permalink) |
Any firmware/software updates out yet for the SD10G? If so, where would I find them?
Thanks! |
06-22-2010, 07:56 PM | #449 (permalink) |
Team Taco VP
Just posted a update video. I got the AT stick stops and a 6 channel 92224 RX. I shot a video on how to install the stick stops and a little look-see about the new 6C 92224 RX.
It's in the first post in this thread at the bottom. Enjoy! Bob
06-22-2010, 08:09 PM | #450 (permalink) |
Bob you need to fix that video link it says
File does not exist please contact the systems administrator
Jeff |
06-22-2010, 08:10 PM | #451 (permalink) |
I get the same problem.
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol The heli virus has infected me and i hope that there is NO CURE! |
06-22-2010, 08:22 PM | #452 (permalink) |
Team Taco VP
Ooops sorry.... in a hurry and left out a underscore character. Should be fixed now!
Bob
06-24-2010, 01:24 AM | #453 (permalink) |
phoenix cable.... not working
Hello... I got the esky cable mentioned earlier in this thread (here) and just tried to plug it into phoenix and it didnt work. I don't have to modify the esky adaptor at all to make it work?
I just got my sd10g. I made a new model called 'sim', heli type. The swash is set at 'normal' (is that the same as single servo?), and the modulation is ppm8. Phoenix is not even recognizing that theres a tx attached! thanks for any help. Ben |
06-24-2010, 01:58 AM | #454 (permalink) |
sim working, but not with sd10g
Ok, so I just reattached my dx7, and after fiddling around, phoenix works again with that tx. But, when I change the cable to the sd10g, the program does not sense that a tx is connected.
Maybe I'll have to take apart the adaptor I have and check with wiring? I dont really know how to tear apart one of these, except to, well, tear it apart! any comments appreciated. Ben |
06-24-2010, 09:31 AM | #455 (permalink) |
If you have a multimeter, use the continuity tester to see what pins go where. It should be wired like the photo in this thread:
https://www.helifreak.com/showthread.php?t=196435 -Farrell |
06-24-2010, 07:05 PM | #456 (permalink) |
Stick Stops
Bob
Is there a part number for the Stick Stops? I can't find them under "Stick Stops". Thanks for all you do. Brad |
06-24-2010, 07:34 PM | #457 (permalink) |
654A51008A - Screw
618A21401A - Stopper Order 2 of each for both ends of the stick travel. TM |
06-24-2010, 08:10 PM | #459 (permalink) |
Sorry about that. I cut and pasted from an email.
TM |
06-25-2010, 05:34 AM | #460 (permalink) |
Just read the whole thread. What a lovefest, I gotta have one.
A few questions. V-Bar and SK-720 use with sats will never be a possibility with this radio? It has to be run with its dedicated receiver? The 10 vs. 7 channel receiver option. Currently using an AR7000, so the smaller 7 channel RX (and lower price) appeal more to me. Is a programmable fail-safe option the only thing I'll be giving up beside the 3 extra channels? It is also LiPo compatible? Any new full featured RXs smaller than the 10 channel pending release? If so maybe I'll hold off a bit. Does Airtronics make a tail servo? I always liked their servos, but the servo prices are still high like they always were, unlike the surprising value the SD10G is.
LHS Piuma Tandem X20S HW150v5 iKON 2 |
