Old 12-24-2011, 11:40 AM   #21 (permalink)
RC-TEK..
http://www.rc-tek.com/us_store/i%C2%...ead-p2256.html
JR9303 / JR9503 / Futaba10CHP
Old 12-24-2011, 01:24 PM   #22 (permalink)
Default Interested
Wow. Keep us updated
tjbooksandmore is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 01:29 PM   #23 (permalink)
Originally Posted by flyride View Post
Holy hell that thing is going to be HUGE!!!!
Have you ever checked out 1/4 scale helicopters? Now these are HUGE, some are almost 6 ft. long. Scroll down to the scale model forums and check out Rotor George's Bell,......unbelievable.
reALIGNed is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 02:49 PM   #24 (permalink)
That is a 10mm main shaft "600" head. Is yours a 12mm 700 head?
Tom
litespeed is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 03:08 PM   #25 (permalink)
Tom
The manufacturer offered to re-machine it to12mm for the build, but the design has been tried already with the blade set I want to use with no issues so I'll keep it as is.
The frame set I'm using @ present will only allow a 10mm shaft.
The prototype frames that would allow a 12mm main shaft have not been completed as of the present.
When they are...
If I decide to breach a 1000, build then I will have another made up with a 12mm shaft and 22mm grips.
Old 12-24-2011, 03:11 PM   #26 (permalink)
We'd like to see a little bigger jump. What's wrong with 1500 or so?
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 03:29 PM   #27 (permalink)
Nothing really except transportation
Not sure if the 900 build is going to fit inside my SUV
Seriously considering of a roof carrier at this point, could manage 4 big birds up there without a problem.
Old 12-24-2011, 04:04 PM   #28 (permalink)
nightflyr,
You are one crazy SOB.
And I mean that in the best possible way!
NRPY is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 04:57 PM   #29 (permalink)
if it doesnt blow itself up i want one!!!
Sponsored By:
MingDa Tech Helicopters, Astroid Designs
MKS Servos USA, Haiyin Lipos,
Scorpion Power packs USA
mattox is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 05:37 PM   #30 (permalink)
Originally Posted by NRPY View Post
nightflyr,
It's a hobby...so getting a little creative is just part of it
I doubt it will blow up, but it surely won't be doing any hard 3D....
More like a Super Cruiser
Old 12-24-2011, 05:45 PM   #31 (permalink)
Head is fitted and 0 out...
Might try it as a 800 setup before pulling the boom and torque tube..
ID:	275722   Click image for larger version
Old 12-24-2011, 05:59 PM   #32 (permalink)
Nightflyr,
Amazing as always. Keep up the great work!!
Sent from my VS910 4G using Tapatalk
T-Rex 600 LE V2, T-Rex 450 Pro, Blade 130x
Futaba 8FG/Spektrum DX6i
Freedom Isn't Free
conefree is offline        Reply With Quote Quick reply to this message
Old 12-25-2011, 08:55 PM   #33 (permalink)
Looking forward to seeing how the head holds up,I've been debating using it on a 800 build
Trex 500 12s vbar I2 bling
Furion 600 12s vbar I2 bling
trex 700edl vbar 12s I2 bling
Tdrex 800e 12s vbar I2 bling
Bank account EMPTY
growmaster4 is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 05:25 AM   #34 (permalink)
Starting the construct of the 900E...
As usual I will most likely be burned at the stake by the "purists" but here's a bit of news..
As you can see the stock 700 boom and the custom 900+ carbon fiber boom.
Now being 900+mm booms are not readily available that are usable for an ALIGN or similar design.
And considering the cost of having custom length carbon fiber booms, which is quite expensive for single digit production runs.
Just to try to ease the costs involved in this or similar project, I went looking for an alternative source to this problem..
And I happen to come across this...
Diameter is almost a perfect match to the ALIGN boom just slightly larger but the tail casing fits fine and it does fit into the boom block.
A minor issue.... the TT bearing holders are slightly loose with in.
Easily fixed by adding a short length if silicone bead material around the rubber bearing holder.
Now here is where I will be dipped in hot oil and set to flames by some....
The simple readily available source for this very inexpensive boom stock comes from no other than...
That's right a simple broom handle will do the trick..
Break out the wieners and marshmellows
ID:	275896   Click image for larger version
ID:	275897   Click image for larger version
ID:	275898   Click image for larger version
Old 12-26-2011, 12:34 PM   #35 (permalink)
......Crash , wait.... I just need to run down to Fred Myers and pick up another boom for my 900E, I be right back..
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 12-26-2011, 12:41 PM   #36 (permalink)
If it works....all the better
Old 12-26-2011, 12:43 PM   #37 (permalink)
Exaxtly.. Go for it!
Old 12-26-2011, 01:23 PM   #38 (permalink)
If it works???? Better be a carbon fiber broom handle....
Old 12-26-2011, 01:26 PM   #39 (permalink)
To tell you the truth both have the same amount of flex so as far as being able to handle the tail, I see no concern.
Old 12-26-2011, 01:56 PM   #40 (permalink)
Nightflyr..
This is, I have no doubt...Going to be a Magnificent 900... I love watching the photo's of it coming together!!
Excellent!!!
Steve
61Espo is offline        Reply With Quote Quick reply to this message
