Old 11-25-2012, 09:11 AM   #141 (permalink)
using align 105mm for all flights today.
Bought some Torsion 106mm not realising they are much heavier than the aligns
I'll get some edge blades soon, but for now these is no vibe with the aligns so I'm not going to rush, will strip the tail after another couple of flights and check the washers I put in.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 09:15 AM   #142 (permalink)
Just an fyi Align will be going with a 1mm thick washer reason for this is to keep the shoulder part of the bolt in the tail hub if not you are relying on the head of the bolt to keep things lined up and allot of load on the threads so please don't get ahead of what we are testing to make sure there are no failures, i know this has fixed things for some of you
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 09:19 AM   #143 (permalink)
Default Thanks for the Intel :)
I have had a blast with the T-Rex 700E DFC however, I too have had serious tail moaning, humming during heavy loads. I dissected my tail to find serious washer cupping, and a lot of play between the tail hub and grips. I found some pretty thick washers in my spare heli parts stash, installed them, and no more humming/buzzing from tail. I have attached a pic of the washers I used. Yeah there pretty thick but problem is solved.
Thanks,
BigQ951 is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 09:43 AM   #144 (permalink)
yup those are thick did any of the shoulder of the bolt make it into the tail hub
Old 11-25-2012, 10:30 AM   #145 (permalink)
So, is HN7042 the current replacement part (for the shaft that tends to snap)? I just purchased a used 700V3 DFC and I want to make sure and go through with new parts and the washer check!
Synergy Field Representative / Team Scorpion / Team FBL Rotors / Team OptiPower USA
Chris Wall is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 11:27 AM   #146 (permalink)
the currant shaft is snapping at the tail hub due to what seems the washers cupping which can cause one of the grips to come out of track and cause the hum which then will snap the tail shaft off. so replace the washers with a thicker one and keep any eye on it. Align has a total tail solution coming and testing is on going cant release it just yet they want to fly it more at high head speeds 2400
Old 11-25-2012, 12:36 PM   #147 (permalink)
This is a great source for thicker washers. If you have experiences ANY buzzing I would replace you tail shaft just the same. If it has been fatigued any its just not worth the chance moving forward. http://www.mcmaster.com/#standard-flat-washers/=kbixf6
Jeff B
800E Trekker - 700E DFC - 550v2 - 500 DFC - 450 DFC - Goblin 630
RV_7A is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 12:45 PM   #148 (permalink)
Anyone know the exact dimensions of those washers?
TREX 800 DFC Pro, TREX 700 DFC v3, Goblin 700 3GX, TREX 550E v2 3GX, MCPX, MCPX-BL
brwilkins is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 12:49 PM   #149 (permalink)
Jeff B
Yes, that was my exact thought - replace the tail shaft and add better washers - so is there a specific tail shaft for the V3 or is the 700E shaft the correct one?
Old 11-25-2012, 12:50 PM   #150 (permalink)
Same as the other 700's.
Old 11-25-2012, 12:53 PM   #151 (permalink)
Originally Posted by Steemo View Post
Will do Lee
Have you decided on another 700 yet or are you holding off to see how the DFC tail situation pans out?
I have still not purchase my 700 DFC yet as I'm still waiting to see how this tail issue plays out and if align will issue upgrade tail parts in their new kits.
But I so badly want this heli!! Thinking about just taking the risk and getting one and leaving the tail off until Align come out with the official "Fix" although your solution with the thicker washers sound like a winner!!
Revolectrix Ambassador
Revolectrix.com 10% Discount All Products Code
LEESS17
Lee2782 is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 12:54 PM   #152 (permalink)
Post #45 in the 700E bent tail washers thread.
Jeff B
Old 11-25-2012, 01:01 PM   #153 (permalink)
Lee rest assured this will remedy the problem and put the ALIGN 700E DFC back at the top ranks of quality kits. I honestly can't say one other thing on the kit needs improvement. Once that kit arrives and you build it you will be so thrilled and proud. Then you just have to figure out how you want to layout your components which will challenge your creativity somewhat. It's almost Christmas baby don't wait !!!
Jeff B
Old 11-25-2012, 01:02 PM   #154 (permalink)
Jeff B
Thanks!
Old 11-25-2012, 01:17 PM   #155 (permalink)
Jeff B
your right Christmas is coming fast!! And I don't want to be left without a new 700 under the tree on Xmas day!!
LEESS17
Old 11-25-2012, 02:34 PM   #156 (permalink)
Ok guys at the field testing the new washers no good back up heli tail huming still have to try lighter tails main heli huming also not as bad as the back up both have the washers changed out and new align tail blades so its not the real fix and you still may have a small vid best way to see this is hover it at your high head speed and look at the bottom of the tail fin to see if its shaking i believe that once we release the total solution it will be the fix for all the tail hums
Please fly with caution Dino
Old 11-25-2012, 02:38 PM   #157 (permalink)
Dino did this tail ever hum? Have you replaced the tail shaft with a new one? I would then do your test again.
Jeff B
Old 11-25-2012, 03:09 PM   #158 (permalink)
Approx 1.38 MM of the shoulder makes it in the hub.
Old 11-25-2012, 03:27 PM   #159 (permalink)
the main heli never humed till a few weeks ago the back up has humed from day one with a ligher set of tail blades before changing the washers out no hum on the main heli
Old 11-25-2012, 04:01 PM   #160 (permalink)
One thing a lot are not thinking about...yes stock washer sucks...yes almost all tail failures have cupped washers buuuuuuuuuuuuuut these are probably damaged due to another issue. Putting thicker washers may fix the cupped issue buuuuuuuuuuuuut the vibs may still be there and still cause shaft failure. Whats damaging the washers may be the vibes so yes the thicker washers is one part of the fix but i think there's still more issues as Dino said with the tail. I would still be careful before you fly with new thicker washers.
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
