nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help |
11-22-2012, 09:59 PM | #21 (permalink) |
It is louder, but only because the canopy acts as a resonant chamber (the reason speakers go in boxes). It is nothing to do with the canopy vibrating.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
11-22-2012, 10:26 PM | #22 (permalink) |
Mine is louder than stock without the canopy on. I will agree however that with the canopy on it makes it louder.
Don't really care though because I am loving my "Mild" brushless setup
- 130X & 130S - Oxy 2 uBrain2, 180 CFX / uBrain - Blade 350QX3, Nano CPS, Nano Quad, & Inductrix - DX8G2 and DX7S |
11-23-2012, 02:12 AM | #23 (permalink) |
Tested, you guys are indeed right! Not a huge difference, but defo more quiet without the canopy.
Also seems like it gets quieter after a while. Been running 80% (full speed) for a while now, seems like it's more broken in. Could it simply be the bearings? Hmmmm... maybe glue a thin layer of foam on the inside of the canopy?
Micro: OMP Hobby M1 Medium: Blade 330X 6S, SAB Goblin 380 Big: SAB Goblin 500 Radio: Spektrum DX8 Gen 1 |
11-23-2012, 02:54 PM | #24 (permalink) |
100 flights on my mild BL! I would have gone through at least a couple stock motors by now. Yes I am happy with BL. It has also taught me to be better with the TH. I stripped a main gear with BL and that never happened with stock motors.
11-25-2012, 11:49 AM | #25 (permalink) |
125 collective! Impossible without serious bogging. More like 75% - 81%. With linear servos you will have a difference between full and low stick.
Verstuurd van mijn GT-I9100 met Tapatalk
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro |
12-03-2012, 05:35 PM | #26 (permalink) |
The thing is amazing. Dylan really did a great job with the wild kit. I was flying in 20mph sustained winds yesterday. No tricks, just nose into the wind hovering with no problems.
Pics - http://imgur.com/a/8egEp#0 On a still day this thing is amazing. I am going to solder on a program port and reflash just because I want to tweak the governor gains to more my flying style. Not looking forwards to that. Flashing the XP3a is a chore. And if it isn't broke should I fix it anyway? Last edited by mikesbaker; 12-03-2012 at 09:01 PM.. |
12-07-2012, 10:38 PM | #27 (permalink) |
FINALLY !!!! My mild kit came today
The install was a breeze,the parts were perfect,the instructions clear. I just finished balancing and I must say my nano is better than I hoped,it is a completely different animal now.There is only one problem now I have to buy another nano, because I have to see what the wild kit is all about... Thanks Dylan,you do not disappoint... I can't wait to get this thing outside tomorrow..
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even. .Who is John Galt? |
12-07-2012, 11:47 PM | #28 (permalink) |
HOLY COW! I just installed the "wild" kit only because I did not want to wait
for the mild. First off…Hats Off to Astroid Designs! Second, I had NOOO frikin clue what a flashed BL was until I had to go problem solving. I'm not going to tell y'all how long it took me but I will tell ya that I just starting soldering not to long ago. This thing is Frickin is AMAZING…I finally got to test fly it around 11:30 p.m. and the pitch bumps are out frickin standing. Can y'all tell that I'm FRICKIN happy? Ok, tomorrows another bright day so I can really fly the thing then and I'll check back. THNX again Dylwad! Just frickin Awesome. |
12-08-2012, 12:01 AM | #29 (permalink) |
Well said..8 short hrs till daylight.
12-08-2012, 09:14 AM | #30 (permalink) |
Quick followup to my previous post:
WOW! Frickin WOW. This is truly a new world for me. I have only been flying now for about 8 months so I am still very green to most of the technology. So, when I mentioned in my post above that I had no idea what a flashed BL heli was…I wasn't kiddin. That being said, my nano now is sooooo FRICKIN sweet. Flips are tight and very responsive. I really like the fact that there is almost zero bog and that there is plenty of power when I need it. I have quickly learned to use the Throttle Hold and the flat throttle curve did not take long to get use to. This thing is frickin so kewl. I sure hope that Astroid makes tons of $ because this thing is FRICKIN awesome :-) Thnx to all on here for your posts...they helped alot. |
12-08-2012, 09:25 AM | #31 (permalink) | |
And I agree, it is quite an experience the first time going from stock to BL. I had mine on the mcpx. It's just as fun putting it together and making it work as it is flying it. The maiden flight after an upgrade is something special also. |
12-08-2012, 10:56 AM | #32 (permalink) |
Are you guys limiting your pitch when you go brushless? Sounds like many are leaving it at the full 100%.
12-08-2012, 11:39 AM | #33 (permalink) |
I have just got mine up and going. Seems to bog at 100% pitch. I need to figure out how to wire a plug for a toolstick. I got some playing around to do.
12-08-2012, 11:46 AM | #34 (permalink) |
Hey, glad you guys chimed in on pitch…not exactly the pitch setting (mine is set to 85 up & down) but rather the pitch curve. I have the "wild", FICKIN diggin it by-the-way, and was wondering what should I have my pitch curve set to? Oh, I have a dx6i.
thnx |
12-08-2012, 11:55 AM | #35 (permalink) | |
You can soften the curve if it feels "jumpy" 0-30-50-70-100 Or you can make it pop more with a more aggressive curve ,0-20-50-80-100..
12-08-2012, 01:07 PM | #36 (permalink) |
On my wild, I currently have the pitch curve linear.
However, I set the endpoint at about 85% right now. I still fine tuning it. Leaving at 100%, I can see bogging. At 85%, it pops quickly enough. But without the bogging. I've read many others are limiting their pitch curves. However, nobody is telling the first time brushless peeps and seems everyone is running at 100%. Thus my question. Hopefully we can get some guidelines for the mild and the wild kits. I suppose battery will come into play on the wild kits. What's the baseline? Hyperion 180? |
12-09-2012, 07:35 AM | #37 (permalink) |
I tried running 160's which are useless with the wild kit..since swapping to 550's with my bl mcpx, It left me with 4 pulse 300's. I figured they should work, so I modified the battery holder to accommodate the bigger cell, and swapped over the plug.
Extra weight is not an issue here, it doesn't even act like its carrying more weight. I am still playing with tx settings, but so far by turning down the pitch and throttle, it's very smooth with zero bogging..
Nano CPS, 180 CFX, G380, DX7s |
12-09-2012, 08:38 AM | #38 (permalink) |
Ok, 85% at the endpoint sounds like something I will try today. Concerning
the batteries - I am using my mcpx batteries. 1 - elite 200 mah 30c (they work ok) 2 - venom 250 mah 25c (about the same as elite..maybe a little better) 3 - MicroHeli 300 mah 35c (my Favorite) thnx for the info Daryoon |
12-09-2012, 03:19 PM | #39 (permalink) |
I'm at 0,25,50,70,85. Still a little poppy, but very little bog.
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5 |
12-09-2012, 06:44 PM | #40 (permalink) |
another satisifed mild customer
Spent yesterday evening installing the mild and then couldn't sleep all night waiting for daylight to try it out. Morning finally came and all is well, no shakes, no vibes, just smooth flight. Inverted flight, here I come.
Sam |
