Old 08-19-2012, 05:38 PM   #61 (permalink)
Originally Posted by NickBee View Post
Any news/pics from ircha on the logo sx?
+1
Ive been waiting too, mikado site has not updated, once that happens I hope readyheli will be soon to stock
Hurry up SX!!!
Yes I miss the odd screw, so what
Trex 700N Vbar, Mikado LOGO 600SX, Trex 450 SportV2, Trex 250se-dfc, MCPX ...DX8...
kiwianaBrad is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 07:17 PM   #62 (permalink)
Originally Posted by mahbouni View Post
I want the low profile head for my 500. I'm keeping the standard length head on my 600.
Me too.
RCFlightStore has shortened main shafts already so...
http://rcflightstore.com/product_inf...oducts_id=4732
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 08:42 PM   #63 (permalink)
Originally Posted by GimpyGolden View Post
Me too.
Note how it says it's not suitable for the 600SE. I guess Mikado will not endorse a SE-ed sx.
NickBee is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 09:38 PM   #64 (permalink)
I wonder if you can use the SX gear and third bearing support and standard main shaft for a SE?
maarset is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 10:06 PM   #65 (permalink)
@ maarset,
"I wonder..."
Yes.
I also heard from a reliable source while at IRCHA that will at some point be an "update kit" for standard Logo 600 owners, should they want to modernize their machines by getting everything at once, rather than piece it together when the individual parts go in stock.
(-: Dave
dahld is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 10:11 PM   #66 (permalink)
Cool thanks Dave!
Old 08-20-2012, 04:13 PM   #67 (permalink)
Anyone know the length of the main shaft on the SX?
Chris
Blueabyss is offline        Reply With Quote Quick reply to this message
Old 08-20-2012, 04:40 PM   #68 (permalink)
Originally Posted by dahld View Post
@ maarset,
"I wonder..."
Yes.
(-: Dave
I did too, thought not at IRCHA
http://shop.mikado-heli.de/LOGO-600-...&c=6573&p=6573
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 08:28 AM   #69 (permalink)
HEL
When there will be available LOGO 600SX?
HEL is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 02:31 PM   #70 (permalink)
Read post #3.
The answer is SOON. No one knows the exact date.
Logo 600se
Redlight11 is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 02:50 PM   #71 (permalink)
Hey,
"The LOGO 600 SX will come out in September. Probably the first half of September."
Ralf Buxnowitz message found on the European forum mikado.
Good evening.
Buzz29Heli is offline        Reply With Quote Quick reply to this message
Old 11-14-2012, 08:32 AM   #72 (permalink)
HEL
Old 11-14-2012, 10:59 PM   #73 (permalink)
Looks good when you are done ensure to affix in some glue just a dab to the connectors for both the speed control sensor into vbar module and the vbar sensor tab as well into module, of course as well all inlet servo tabs.
Old 11-15-2012, 12:59 AM   #74 (permalink)
HEL,
Looks good. Gave me a few ideas on alternate wiring methods.
I did notice on your tail, like mine, that the M3x35 bolts don't quite engage the blue nylon lock in the nut. I purchased new 5mm longer M3x40 bolts to "fix" the problem. I also got some M3 stainless steel washers so the nut and head didn't chip off the nice orange paint. My mate converted his 600 to SX and the 600 tail already had 40mm bolts so he didn't have the same problem.
Regards, Jayson
Logo 800Xx Silverline, Pyro 850-40L, Kosmik 200, 14S, 157 & 256 @ 8v
Logo 400SE Silverline, Pyro 600-09, Jive 80+HV, 8S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote Quick reply to this message
Old 11-15-2012, 05:11 AM   #75 (permalink)
Also ground your boom. Full continuity from motor mount to tr shaft is required.
Old 11-15-2012, 09:46 AM   #76 (permalink)
Is it ? There were rumors with the new GF tail it is not needed to use the tail-to-boom cable but I did not understood what was the end conclusion.
LOGO 600SX: JIVE 100LV, HKIII-4025-1100, BLS451+BLS251, VBAR PRO, ZEAL 570, KBDD 105
GOBLIN 500: CC ICE75, QUANTUM-4115-1200, DS510M+DS650, MINI VBAR, SAB 500, SAB 85
Kalpazan is offline        Reply With Quote Quick reply to this message
Old 11-15-2012, 10:33 AM   #77 (permalink)
I can tell you for the few minutes it takes do it. On any belt heli IMO it's required. Check as is for continuity and if your good well then your good. Worst thing to experience on FBL systems is static it can wreak absolute havoc.
Old 11-15-2012, 11:44 AM   #78 (permalink)
GREAT JOB!!!
Also put some Hot Glue or shoo goo on the rpm sensor. Those connections are very fragile.
Mike
Old 11-15-2012, 06:51 PM   #79 (permalink)
I drilled and tapped an M2 thread into the motor mount ahead of the motor to achieve continuity from tail case to the motor mount.....
But shouldn't one also have continuity to the negative main battery of the ESC?
So that the positive of the main battery is at a potential 10S above that of the negative, regardless of any common mode static.
EEngineer is offline        Reply With Quote Quick reply to this message
Old 11-15-2012, 08:30 PM   #80 (permalink)
Just grounding to the motor mount is necessary.
