Old 07-27-2006, 07:48 PM   #1 (permalink)
Default Fail Safe on a futaba 7c TX
How do you set a fail safe up on a futaba 7c radio? I have r138dp futaba rx, i know where to find it in my menu, i dont understand how you set it up. can anyone help me? Thanks
Jeff
helis101 is offline        Reply With Quote Quick reply to this message
Old 07-27-2006, 08:37 PM   #2 (permalink)
You do have the transmitter set to PCM mode? Failsafe menu only shows up when transmitter is set to transmit in PCM mode.
Page 41 of the 7C instruction manual
FailSafe (loss of clean signal and low receiver battery) submenu (PCM mode only) (F/S ): sets responses in case of loss
of signal or low Rx battery.
FailSafe (F/S ): instructs a PCM receiver what to do in the event radio interference is received.
Adjustability:
• Each channel may be set independently.
• The NOR (normal) setting holds the servo in its last commanded position.
• The F/S (FailSafe) function moves each servo to a predetermined position.
• NOTE: the setting of the throttle's F/S also applies to the Battery F/S (see below).
Examples:
• The F/S setting is used in certain competitions to spin the aircraft to the ground prior to flying away and doing potential damage
elsewhere. Conversely, may also be used to go to neutral on all servos, hopefully keeping the plane flying as long as possible.
• Competition modelers often maintain the NOR function so that brief interference will not affect their model's maneuver.
• Set the throttle channel so that the engine idles when there is interference (ACRO). This may give enough time to fly away
from and recover from the radio interference and minimize damage if crashed.
• For helicopters, NOR is typically the safest choice.
• We also recommend setting a gasoline engine's electronic kill switch to the OFFposition in the F/S function for safety reasons.
Updating F/S Settings: If you specify a F/S setting, the FailSafe data is automatically transmitted once each two minutes.
When you choose the F/S mode, check that your settings are as desired by turning off the transmitter power switch and
verifying that the servos move to the settings that you chose. Be sure to wait at least two minutes after changing the setting
and turning on the receiver power before turning off the transmitter to confirm your changes have been transmitted.
GOAL of EXAMPLE: STEPS: INPUTS:
Battery FailSafe (F/S ): a second battery low warning feature (separate from the transmitter low voltage warning). When
the airborne battery voltage drops below approximately 3.8V, the PCM receiverνs battery F/S function moves the throttle
to a predetermined position. When the Battery F/S function is activated, your engine will move to idle (if you haven't set
a position) or a preset position. You should immediately land. You may temporarily reset the Battery F/S function by
moving the THROTTLE STICK to idle. You will have about 30 seconds of throttle control before the battery function
reactivates.
Adjustability:
• NOR F/S setting for throttle results in Battery F/S going to the servo position reached by moving THROTTLE STICK to the
bottom with TRIM LEVER centered;
• POS F/S setting for throttle results in Battery F/S also going to the same throttle servo position as the regular F/S .
If using a 6V (5-cell) receiver battery, it is very likely that your battery will be rapidly running out of charge before
battery FailSafe takes over. It is not a good idea to count on battery Fail Safe to protect your model at any time, but
especially when using a 5-cell battery.
41
Change the receiver FailSafe command
for channel 7 (gasoline engine kill
switch) to a preset position.
NOTE: This is one of several functions
for which the radio requires
confirmation to make a change.
Where next?
Open the BASIC menu, then open
F/S function.
Choose Channel to change. (ex: Ch. 8)
Set and confirm fail safe command.
Repeat as desired.
Close.
for 1 second. (If ADVANCE, again.)
to F/S .
to Ch 7.
that controls channel 7 to desired
OFFposition.
for 1 second to store.
to F/S .
Wait two minutes and confirm F/S settings as described above.
Read below for information on Battery FailSafe.
Adjust END POINTs to gain proper F/S responses if needed: see p. 32.
Adjust SUB-TRIM to gain proper F/S responses
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 07-27-2006, 08:56 PM   #3 (permalink)
Yes i do have my transmitter set to pcm mode what i dont understand is do i leave all channels set to normal and failsafe for throttle channel and how do i set a predetermined command. What i want is the throttle to go to idle positon incase i lose the siginal. I have trex 600 is this how you set this up?
Jeff
Old 07-27-2006, 09:21 PM   #4 (permalink)
Set channel 3 to F/S ( failsafe) . Then pull the throttle stick to the bottom position (idle) and push set.
Page 41 of the manual explains how to set the function.
But you will need to pull the stick to idle position before you push the button to set the position.
You can check if it is working if the ESC has a light to show when throttle is only.
Unplug the motor from the ESC.
Then turn on TX, then turn on RX. Then push throttle stick all the way up. Light or something else on ESC should show full throttle to ESC. Now turn off TX. IF failsafe is set up properly. Light for throttle should go out on ESC.
Hope this helps
David
Old 07-27-2006, 09:29 PM   #5 (permalink)
Yes now i understand thanks for the info
Jeff
