Like Tree3Likes
Old 12-05-2011, 08:03 AM   #521 (permalink)
Originally Posted by Finless View Post
On a 450 use blue locktite. I have never needed red on a 450.
The problem with Align screws on the 450 is the hex size. The Align tools seem to fit the align screws better than much more expensive tools I have tried. I swear it's a conspiracy
There was a thread way back in the 450 forum where guys were measuring and comparing hex sizes between tool makers with calipers. The Aligns were slight larger in hex size. Maybe thats why. I am not telling you that you must get align tools only that I know they work well on Align screws.
Bob
I am going to have to try that out. I am in the middle of getting my snap on brand 1.5 hex driver replaced because I was swearing to my dealer that it was out of spec. Boy will I be embarrased if I find that to be the case. I'm going to order an align 1.5 today.
Most important though, Bob, I want to thank you too. Your videos and outstanding instruction are the only reason I am able to learn to fly helis. I can fly on the sim all day long, but without a PROPERLY set up bird, all my sim time was wasted. Trying to find people locally to help is next to impossible. Your teaching methods are great, and done at a level that we can all understand. THANK YOU! I am just barely moving in to forward flight, but with your help, I am very well versed at setup.
Thank You,
Greg
Greg Short
Compass Field Rep
Compass Odin 90 fbl, Compass 3d+
Compass 7HV
pete best is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 06:06 AM   #522 (permalink)
Red face Governor Set up for align
Hi Bob, could please give a help for the align governor set up T-Rex 600NFBL, with an 10C Futaba Radio + 8 channel Futaba receiver? Thank you. Ger.
Ger2010 is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 10:10 AM   #523 (permalink)
Team Taco VP
Here is a video I shot for setup of the Align gov
http://video.helifreak.com/?subpath=...e=aligngov.wmv
It's not with a Futaba radio but the principles are the same.
Bob
Old 01-08-2012, 10:57 AM   #524 (permalink)
I have a Detrum 40a Esc I have gone in to setup following bobs and the mfg's instructions. My manual tells me to wait for 5 "beeps". All I am getting is two beeps with about 15 really short beeps and it just keeps looping through that. Is there a way to reset there things? Or am I missing something?
mtbr00x is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 11:20 AM   #525 (permalink)
Team Taco VP
Sorry I know nothing about that ESC... Never had one. Best probably to make a post asking about this in the main forum where more people will see it and someone may know.
Bob
Old 01-08-2012, 11:24 AM   #526 (permalink)
Ok thanks.
Old 01-13-2012, 05:13 PM   #527 (permalink)
dct
Bob,,,
Question,, did you ever do a BeastX setup video?
Thanks Dan T
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote Quick reply to this message
Old 01-13-2012, 06:32 PM   #528 (permalink)
i think the only FBL that Bob flies is the MCPX FBL unit????
flyfishsick is offline        Reply With Quote Quick reply to this message
Old 01-14-2012, 11:09 AM   #529 (permalink)
Team Taco VP
I have only done Vbar but I did not do a video since there are spome already by Mr. Mel.
Bob
Old 02-15-2012, 11:43 AM   #530 (permalink)
Default soldering
Hi guys, I want to ask, about the building EXI 450/HK 450.
I am currently building one, and is on the soldering part. Do I really need to have a heat shrink tubing for the esc/speed controller? Because I don't have one. If anyone knows which heat shrink tubing to buy for, could you tell me? thanks a lot. I really appreciate it.
Fluckers is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 01:40 PM   #531 (permalink)
Yes, it is needed. I would go to a hardware store and buy some that is a tad larger than the wire. Slide it down the wire away from where you'll be soldering before you start. After you've soldered it, slide it up to cover the joint and apply heat to shrink.
Shane
OMP M4, OMP M1; Futaba
A bunch of planes
enahs is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 04:23 AM   #532 (permalink)
Usually you need for motor connector. Get a 4 and 5 mm if you're using 3.5mm connector.
You might also need for battery connector. Depend on the connector you are going to use. If you use Dean, you need one. 5 mm will do.
pinguin is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 09:53 PM   #533 (permalink)
Thanks everybody!
Old 03-05-2012, 10:13 PM   #534 (permalink)
Default Thanks
The first two videos were more informative than a month full of youtubes. Nice work, and thanks.
Vinny ///M3 is offline        Reply With Quote Quick reply to this message
Old 03-09-2012, 03:57 AM   #535 (permalink)
Added:
Radios
Spektrum DX8 Videos
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 03-10-2012, 01:25 PM   #536 (permalink)
Default Failsafe Throttle Curve
Bob,
I read a post by you regarding setting a 0 0 0 0 0 throttle curve and then rebinding the tx/rx for safety. Would you mind refreshing my memory? The post was very informative.
scw
Post found!
Thanks.
scwest is offline        Reply With Quote Quick reply to this message
Old 04-01-2012, 11:43 PM   #537 (permalink)
Default Heli Skills and Setup 101 - LOOK here first!
Bob (or anyone who can help),
I am rebuilding a Blade SR and want to save myself the headache of moving to a DX6i from the stock tx since Horizon won't give up the details about exactly how they programmed that tx. I watch your CCPM videos and like the way you set the head and servos up. My question is how to I set those servos to mid without a digital tx? You use the settings on the Futaba (I believe) to adjust the subtrim to set those servos to exactly 50% travel, and that isn't an option with the stock tx? Do I just use the standard trim adjustments? Any suggestions?
Thank in advance!
ryanjameshay is offline        Reply With Quote Quick reply to this message
Old 05-07-2012, 07:34 AM   #538 (permalink)
Default Sevro Center
Hi Bob, Thanks for all you have done! I am building a new Trex 450 Sport V2 and I have noticed that on my sevros when I move the stick say to the right and release, it goes to center and move it to the left and release, it goes back to center, BUT the centers are not the same. What would cause this? And do you know how to correct it? Also I have the Dx6i TX. Its not a big differance or maybe it is. Please help, WS
Wind Spirit is offline        Reply With Quote Quick reply to this message
Old 05-09-2012, 10:26 PM   #539 (permalink)
If this is on your tail servo and the gyro is in heading hold mode then it is normal and nothing to worry about - if it is on your swash servos then somethings wrong - bad gear or worn gimbals or servos.
John
Old 05-09-2012, 10:33 PM   #540 (permalink)
Thank in advance!
If you don't have subtrim then you just have to mechanically set the links to get an even swash as best you can and don't worry if the arms aren't quite square at mid stick - isn't usually a problem unless you're doing precise 3D - best to leave the trims to just correct inflight imbalances.
John
