Old 11-12-2011, 07:14 PM   #41 (permalink)
Well this is progress so far. Ignore the fact that I put the KDE motor mounts on backwards. Its fixed now. The 3rd bearing block will be a good addition to this frame. Its pretty flexible at the bottom without it. Those of you with 800 booms. When spacing your torque tube bearings on the torque tube. Did you use the 700 specs for the distance? Not that its super critical. Im just wondering. I'd like to keep tail vibes to a minimum.
Trex 700N, Trex 450PRO
"Why buy one when you can buy two for twice the price"
A.Delaney is offline        Reply With Quote Quick reply to this message
Old 11-12-2011, 07:44 PM   #42 (permalink)
Ok, upon further review of my 700 boom. I noticed the bearings were spaced evenly across the distance of the torque tube. For some reason. I was thinking the distance wasnt equal in order to keep vibes from traveling down the tube into the tail.
Old 11-12-2011, 09:10 PM   #43 (permalink)
Airframe about done.
Old 11-12-2011, 10:01 PM   #44 (permalink)
I got about as far as you plus the motor and servos. I added some stock Trex hex spreaders behind the anti rotation guide and in the 3rd bearing hole because these areas felt weak to me. I'm going to order the KDE third bearing block kit because I think this needs it. I'm blown away how small this frame is compared to the stock frame. With the 800 boom it really dwarfs the frame even farther. Should be finished tomorrow but have to wait for castle to send me a new esc since mine burst into flames. Not sure if I can hold out.....might just have to buy another.
Tom
litespeed is offline        Reply With Quote Quick reply to this message
Old 11-12-2011, 10:37 PM   #45 (permalink)
I think the bearings should not be evenly spaced. If they are evenly spaced, each section of the torque tube will resonate at the same frequency multiplying the effect of the vibration and creating a more severe vibration at that one resonant frequency. If they are unevenly spaced, each section will resonate at a different frequency resulting is less severe vibrations.
That's just my thoughts on the subject.. Anybody care to second it?
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote Quick reply to this message
Old 11-12-2011, 10:51 PM   #46 (permalink)
Originally Posted by A.Delaney View Post
Ok thanks Dave. I ordered the 11t pinion and some other parts from you for this build. Im still thinking about the motor. I was reading some of your other posts about your 800. Did you end up testing a few different motors? Any conclusion?
sorry, I missed this post..
Thanks for your support, its much appreciated. . Wish we would have had the 800 blades and boom in for you at the time of your order, would have saved you the trouble of ordering from multiple shops.. We got them in now finally..
To answer your motor question, I have only flown it with the HKIII 500KV. Its really great, but I really think the 450KV with the 11T would be perfect. As soon as I get a new 90E machine to put the 500kv in, I will then be grabbing a HKIII 450kv for my 800.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 11-12-2011, 11:20 PM   #47 (permalink)
A Scorpion 5020-450 works very well in this application
Though with the frame set your using, not 100% sure of the fit.
JR9303 / JR9503 / Futaba10CHP
Old 11-13-2011, 12:08 AM   #48 (permalink)
I thought about going with a large motor but to be honest, its just going to suck more mah, and shorten the flights. I am happy with the HKIII and would not want or need any more than that. I beat the snot out of my machine when it was a 700 and that motor was amazing. But im sure its a grunter with that size can.
I'm actually using less amperage as an 800 than I was as a 700. the headspeed and gearing make it easier on the motor. My ESC was getting up to 190f+ with 693's, its around 30-40 degrees cooler on average with the 800's. So a larger motor is not needed. It has to do with disc loading I believe.
GAUI X5 / X7 *
Old 11-13-2011, 02:20 AM   #49 (permalink)
Hey thanks guys for the input. I want to also consider here that with these frames. I may have to use smaller packs to get the COG right. I just want to make sure I can get some decent flight times with the motor I choose.
Dave, can you get the HKIII 450kv? I didnt see it on your website.
Old 11-13-2011, 08:29 AM   #50 (permalink)
Well I just verified that 2 Zippy 40C 5000's will NOT fit under the stock Align canopy. Just wondering if they would if need to balance out the 800 boom. I did try my Logo 600SE canopy and the batteries do fit under that. Might have to do a custom Align CHP 800 canopy just for looks. All up weight was 11 lbs on the 40C 5000 Zippies ready to fly. Going to my Gens Ace 4000's is going to drop the weight down to to 10 lbs 1 oz......that is just going to be wild once I get this thing up in the air. That was adding 5 oz to the weight in for the Castle 120 HV which I plan to run since the 80HV went up in flames. I suppose my actual weight might vary.....Crazy other thing is this heli is shorter than my logo 600SE which has always been the shortest heli I have owned. The smallest I have seen was the Compass 6HV but I think this 800 might compare to that???
Tom
ID:	266588   Click image for larger version
ID:	266589   Click image for larger version
ID:	266590   Click image for larger version
Old 11-13-2011, 09:59 AM   #51 (permalink)
Have you checked the COG with the 5000's? Im curious to know if it will be real nose heavy. I can handle using a logo canopy. I did notice after building the airframe how much shorter it looked than the Align frame.
Old 11-13-2011, 10:32 AM   #52 (permalink)
It appears without the weight of the esc it's balances right on right now. I'll prolly put the esc on the side in a neutral point if I use the 5000's or move it forward and run the 4000's. Read; Velcro and a strap! I don't want to put the CC 120 under the batteries in case there is a fire.....Just saying! I'll put the CC bec under the batteries instead. Actually I'm thinking asbestos shield around the esc just in case. :-P Ventilated battery bag maybe?
Tom
Old 11-13-2011, 10:41 AM   #53 (permalink)
Come on Tom. What are the odd's that CC esc will go up in flames. Now im wondering if I should mount my esc in a more neutral location also. Im not worried about a fire but the COG. I'll just have to check it and see once its together. I have an old CC pheonix 110 that I ran on my 700e for the last couple years. It should do the trick.
Old 11-13-2011, 11:06 AM   #54 (permalink)
I was thinking about going to a 110 also but they are few and far between. Being that they weigh in at about 5 oz it's make sense to use it as the COG fine tuner.
When is your suspected maiden date? Where about is Streator, IL?
Tom
Old 11-13-2011, 06:55 PM   #55 (permalink)
Im not sure when I will have it ready to maiden. Im still waiting on parts and the weather has been really windy lately. Winter is coming fast. I'll still fly if its cold and not windy. Im quite a drive from Missouri. Im at least 2 hours north of Springfield IL.
Old 11-14-2011, 11:49 PM   #56 (permalink)
Scorpion HKIII 4035-450KV motor is on its way. Thanks to Dave at AnythingHeli for the great buy.
Old 11-22-2011, 07:40 AM   #57 (permalink)
I can't wait to see this finished. I'm thinking about doing the same thing too my 700E
ssproud is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 09:29 PM   #58 (permalink)
Just scored a brand new Castle 120HV V2 for 100 bux (hopefully not a fire bomb!) so my 800 will be up on it's maiden on Thursday. It just showed up today so here are some pictures ready to fly minus the esc.
11 lbs ready to fly with 12s Zippy 5000 40C batteries. 10 lbs 4 oz with my Gens Ace 4000's.
Tom
ID:	268529   Click image for larger version
ID:	268530   Click image for larger version
ID:	268531   Click image for larger version
ID:	268532   Click image for larger version
ID:	268534   Click image for larger version
ID:	268535   Click image for larger version
Old 11-23-2011, 01:12 AM   #59 (permalink)
Tom, Did you end up getting the 450kv Scorpion? I thought you were running the Align motor? She's a beauty. Are those the Edge 115's on the tail?
Old 11-23-2011, 02:43 PM   #60 (permalink)
Yea I got the HKIII 4035-450 really cheap so figured what the hell. Yes and those are Edge 115's.
Wish me luck.
Tom
