500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
07-13-2010, 07:23 AM | #1 (permalink) |
CC Phoenix ICE 75 BEC strong enough...
... for a T-Rex 500 3G? Or do I need a seperate BEC?
T-Rex 700 Pro DFC BEASTX | BLADE Fusion 270 | Spektrum DX18G2 |
07-13-2010, 10:59 AM | #2 (permalink) |
ICE 75
I think that will be all you'll need . I am getting a ICE75 ; coming this week. It has a built in bec so you should be fine. Wait for a few more replys to play it safe.
TBS Discovery / Nemesis 240 / Park Zone Sport Cub / Taranis X9D / Black Pearl 7' FPV Monitor / iCharger 206-B / Sony 2.8 FPV camera / GoPro Hero 3 Silver + |
07-13-2010, 11:01 AM | #3 (permalink) |
I beat the snot out of mine and have yet to make that cc ice 75 sweat, (see specs below) it is the best esc I have ever used, should be fine for fbl set up
Trex 600N SE FBL, YS50, Hattori pipe, Beastx, Quick Uk everything, JR 8717's on cyclic, 9254 on the tail, push glow, Castle Creations 20 amp BEC Pro, Model Avionics Throttle Jockey Pro. |
07-13-2010, 11:39 AM | #4 (permalink) |
Quite a fair few peeps run ICE 75/100's (both have the same internal BEC), and I have yet to hear of any issues with the BEC in a 500 size application.... you should be good to go
450 PRO, 500 ESP Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice. |
07-13-2010, 11:51 AM | #5 (permalink) |
Thanks.
Anybody with a flybarless setup (3G, BeastX, mini v-bar, ...) and the internal bec of the Ice 75?
07-13-2010, 01:05 PM | #6 (permalink) |
Are you guys running your BEC at 6V? I have heard that you can go up to 6.5V safely while getting a little more speed. Personally i have mine at 6.
BTW just in case you didnt know CC released the Quick Link so there is no need to keep pulling the esc wire from the TX for data logging and esc changes. Just ordered 2 today...the pins on my tx are real tired!
07-13-2010, 02:05 PM | #7 (permalink) |
RAGE,
I upgraded my Trex 500 to FBL first with a 3G and later with a Skookum SK 720 when the SK 720 hit the market. I had been using a CC Phoenix HV 85 ESC with a CC BEC. When I upgraded to the SK 720, I switched out the CC Phoenix HV 85 and CC BEC for a CC ICE 75. It doesn't need a separate BEC and works fine. You won't have any problems.
T-Rex 600 Nitro Pro T-Rex 500 T-Rex 450 Pro |
07-13-2010, 02:52 PM | #8 (permalink) |
About time Castle released that quicklink! Thanks for the headsup cmar143
BEC set at 6V. I like to run equipment within stated specs!
07-13-2010, 05:32 PM | #9 (permalink) |
Me matey Gary, from Bulgaria, is using the ICE 75 in his Logo 400 Vbar... no BEC
I have two in 500s, set to 6Volts, and they are flawless, but I have a flybar...
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too |
07-14-2010, 12:17 AM | #10 (permalink) |
My Trex 500 FBL 3G with stock ESC 60amp and 5 amp rec.output draws about 1.8amps in current draw during mild 3D max. So I wouldn't worry about it, but if your curious still I have a friend who is an EE and he has just manufactured a current draw monitor that can be utilized during flight and it just connect inline with whatever you want to measure. it can give you individual readings on each servo also. PM me if you want more info, it will be coming soon from Base Electronics/Base RC.
07-14-2010, 02:16 PM | #11 (permalink) | |
I also have an ICE 75 on my 3G 500 and no issues so far... Now that I've said that, just wait till this weekend... Mike |
07-14-2010, 03:27 PM | #12 (permalink) |
Superstitious?
07-14-2010, 10:57 PM | #13 (permalink) |
Not really, knock wood.
Mike |
07-16-2010, 11:43 AM | #14 (permalink) |
Here is the website if you would like to take a closer look. http://www.baseelectronics.com/base-rc.html
